Home » Eclipse Projects » Rich Client Platform (RCP) » Product export: where have to put required features???
Product export: where have to put required features??? [message #633079] Fri, 15 October 2010 05:58 Go to next message
I have to build a product that contains one feature "featureA" (with application plugin) that requires another feature "featureB"
I know that this feature have to exists before export the product but I don't know where and how to do this.
of course I'm not able to export the product because of missing this requirement of featureB.
where I have to put featureB to correclty export the product?
[Updated on: Wed, 20 October 2010 05:35] by Moderator
Re: Product export: where have to put required features??? [message #633088 is a reply to message #633079] Fri, 15 October 2010 06:31 Go to previous messageGo to next message
I've forgotten to say I'm using Eclipse Helios 3.6.1
[Updated on: Mon, 18 October 2010 08:43] by Moderator
Re: Product export: where have to put required features??? [message #633857 is a reply to message #633079] Tue, 19 October 2010 11:51 Go to previous messageGo to next message
In FeatureA if you go to the MANIFEST there is a tab called "Include Features" or something like that. You can put featureB in there.
Re: Product export: where have to put required features??? [message #634015 is a reply to message #633857] Wed, 20 October 2010 05:35 Go to previous messageGo to next message
thanks eshvar but I don't want to put that feature as included but as required, the differnece is that if I put it as included I can0t updated it without updated also the main feature, instad using required this is possible!!
Re: Product export: where have to put required features??? [message #634057 is a reply to message #634015] Wed, 20 October 2010 08:00 Go to previous message
> possible!!
You can still update the features individually. As part of your build
process, use the director to re-install the same feature that's part of
your product. That will make it a "root IU" and that can be updated
separately.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:How to modify/extend the Next View/Previous View Dialog (Ctrl+F7/Ctrl+Shift+F7)
Next Topic:remove "Open Perspective" button
Current Time: Sun Jul 27 02:17:39 EDT 2025
Powered by FUDForum. Page generated in 0.05009 seconds
