Home » Eclipse Projects » Virgo » Error on startup for Virgo M6(Exception thrown on startup)
Error on startup for Virgo M6 [message #632874] Thu, 14 October 2010 10:37 Go to next message
I'm just in the process of migrating from dm Server to Virgo. I've installed Virgo Web Server M6 and on launching I get the following exception:
<HD0002E> Hot deploy failed for file 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation.par'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: listFiles() failed for file C:\java\springsource\virgo-web-server-2.1.0.M06-incubation\work\org.eclipse.virgo.kernel.deployer_2.1.0.M06-incubation\staging\global\par\org.eclipse.virgo.apps.repository\2.1.0.M06-incubation\org.eclipse.virgo.apps.repository-2.1.0.M06-incubation.par\
    at org.eclipse.virgo.kernel.install.artifact.internal.StandardInstallArtifactTreeInclosure.createInstallTree(StandardInstallArtifactTreeInclosure.java:130)
    at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:140)
    at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:123)
    at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:187)
    at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeploymentFileSystemListener.java:174)
    at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeploymentFileSystemListener.java:186)
    at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeploymentFileSystemListener.java:87)
    at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:245)
    at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:166)
    at org.eclipse.virgo.kernel.deployer.hot.WatchTask.run(WatchTask.java:58)
    at java.lang.Thread.run(Thread.java:619)
Caused by: org.eclipse.virgo.util.io.FatalIOException: listFiles() failed for file C:\java\springsource\virgo-web-server-2.1.0.M06-incubation\work\org.eclipse.virgo.kernel.deployer_2.1.0.M06-incubation\staging\global\par\org.eclipse.virgo.apps.repository\2.1.0.M06-incubation\org.eclipse.virgo.apps.repository-2.1.0.M06-incubation.par\
    at org.eclipse.virgo.util.io.FileSystemUtils.listFiles(FileSystemUtils.java:237)
    at org.eclipse.virgo.util.io.FileSystemUtils.listFiles(FileSystemUtils.java:268)
    at org.eclipse.virgo.kernel.artifact.fs.internal.FileArtifactFSEntry.getChildren(FileArtifactFSEntry.java:50)
    at org.eclipse.virgo.kernel.install.artifact.internal.ParPlanInstallArtifact.findChildArtifacts(ParPlanInstallArtifact.java:95)
    at org.eclipse.virgo.kernel.install.artifact.internal.ParPlanInstallArtifact.<init>(ParPlanInstallArtifact.java:86)
    at org.eclipse.virgo.kernel.install.artifact.internal.ParPlanInstallArtifactFactory.createParPlanInstallArtifact(ParPlanInstallArtifactFactory.java:75)
    at org.eclipse.virgo.kernel.install.artifact.internal.PlanInstallArtifactTreeFactory.createParTree(PlanInstallArtifactTreeFactory.java:97)
    at org.eclipse.virgo.kernel.install.artifact.internal.PlanInstallArtifactTreeFactory.constructInstallArtifactTree(PlanInstallArtifactTreeFactory.java:88)
    at org.eclipse.virgo.kernel.install.artifact.internal.StandardInstallArtifactTreeInclosure.constructInstallArtifactTree(StandardInstallArtifactTreeInclosure.java:156)
    at org.eclipse.virgo.kernel.install.artifact.internal.StandardInstallArtifactTreeInclosure.createInstallTree(StandardInstallArtifactTreeInclosure.java:124)
    ... 10 common frames omitted
The directory referred to exists, has files in it, and is readable, so I'm a bit mystified.
Deploying artifacts and plans by dropping them into the pickup directory doesn't seem affected by it (the problems I'm getting there lie elsewhere), so for now it doesn't seem to be a showstopper for me, but I haven't seen any other reports of similar.
I haven't yet filed a bug report in JIRA as the frontpage seems to suggest not to until the release happens.
If there's any more info I can look for, let me know and I'll try to dig a bit deeper.
John
Re: Error on startup for Virgo M6 [message #632878 is a reply to message #632874] Thu, 14 October 2010 10:44 Go to previous messageGo to next message
Could it be the dreaded "path too long" on windows issue?
This is a shot in the dark, but try moving your server to root of c: and shorten the name to just "virgo". Remove as many characters as possible.
The path that you specified is 253 characters.
Re: Error on startup for Virgo M6 [message #632883 is a reply to message #632874] Thu, 14 October 2010 10:53 Go to previous messageGo to next message
Hi John
You've run into a slightly toxic combination of poor I/O subsystem implementation in Java and a side-effect of long pathnames on Windows.
See this bug for a workaround.
Glyn
Re: Error on startup for Virgo M6 [message #632885 is a reply to message #632874] Thu, 14 October 2010 10:55 Go to previous message
John McLaughlin wrote on Thu, 14 October 2010 15:37
Feel free to raise bug reports (using bugzilla), but please could you indicate what wording suggested not to do this until the release happens?
Previous Topic:When does Virgo register the ApplicationContext service?
Next Topic:Deploy Spring MVC application on Virgo Web Server?
Current Time: Sat Jul 26 21:36:22 EDT 2025
Powered by FUDForum. Page generated in 0.03940 seconds
