| Eclipse freezes on show view [message #632254] |
Tue, 12 October 2010 06:11  |
Hello
I have a problem opening views in Eclipse on a certain computer. Switching perspectives is possible, but opening a view is impossible, Eclipse freezes. This is, of course, the same with any RCP application. I attached here the log file.
Could someone please help me?
Greetings
Alexandra.
!SESSION 2010-10-12 11:36:54.682 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0_21
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.epp.package.rcp.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.rcp.product
!ENTRY org.eclipse.ui 4 0 2010-10-12 11:39:32.700
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Widget is disposed)
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:3969)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:340)
at org.eclipse.swt.widgets.Widget.getData(Widget.java:554)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:62)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3819)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3795)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.openInActivePerspective(PackageExplorerPart.java:431)
at org.eclipse.jdt.internal.ui.wizards.JavaProjectWizard$1.run(JavaProjectWizard.java:103)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
... 22 more
!ENTRY org.eclipse.ui 4 0 2010-10-12 11:41:16.394
!STACK 0
at org.eclipse.swt.widgets.Control.isActive(Control.java:1609)
at org.eclipse.swt.widgets.Shell.updateModal(Shell.java:1940)
at org.eclipse.swt.widgets.Display.setModalShell(Display.java:4482)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1827)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1206)
at org.eclipse.jface.window.Window.open(Window.java:797)
at org.eclipse.jface.dialogs.MessageDialog.open(MessageDialog.java:334)
at org.eclipse.jface.dialogs.MessageDialogWithToggle.open(MessageDialogWithToggle.java:114)
at org.eclipse.jface.dialogs.MessageDialogWithToggle.openOkCancelConfirm(MessageDialogWithToggle.java:209)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.promptOnExit(IDEWorkbenchWindowAdvisor.java:198)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.preWindowShellClose(IDEWorkbenchWindowAdvisor.java:162)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowShellClosing(WorkbenchWindow.java:1344)
at org.eclipse.ui.internal.WorkbenchWindow.canHandleShellCloseEvent(WorkbenchWindow.java:816)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:686)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:308)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1665)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4162)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1598)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2038)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4873)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2454)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:497)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4251)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2459)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3655)
!SESSION 2010-10-12 11:46:24.522 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2010-10-12 11:46:39.948
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ui 4 0 2010-10-12 11:47:51.620
!STACK 0
at org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHandler.java:162)
at org.eclipse.ui.handlers.ShowViewHandler.openOther(ShowViewHandler.java:106)
at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHandler.java:74)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.ShowViewMenu$3.run(ShowViewMenu.java:144)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
!ENTRY org.eclipse.ui 4 0 2010-10-12 11:48:15.473
!STACK 0
FUDForum. Page generated in 0.03953 seconds
