Home » Modeling » M2T (model-to-text transformation) » [Acceleo] How to traduct s.Fields ->collect(field|field.name='toto').notEmpty()
[Acceleo] How to traduct s.Fields ->collect(field|field.name='toto').notEmpty() [message #632631] Wed, 13 October 2010 12:14 Go to next message
I don't undurstand how to know if a collection contains a specifics elements.
I want to traduct this ATL fonction in Acceleo :
Re: [Acceleo] How to traduct s.Fields ->collect(field|field.name='toto').notEmpty() [message #632741 is a reply to message #632631] Thu, 14 October 2010 02:59 Go to previous messageGo to next message
You should try something like this:
s.Fields.name->includes('toto')
which is exactly the same as:
s.Fields->collect(f | f.name)->includes('toto')
Stephane Begaudeau, Obeo
Re: [Acceleo] How to traduct s.Fields ->collect(field|field.name='toto').notEmpty() [message #632746 is a reply to message #632631] Thu, 14 October 2010 03:02 Go to previous messageGo to next message
--------------040701010005030008010105
This is an OCL question rather than an Acceleo one.
"know if a collection contains a specific element" is not made through
"collect" in OCL ... and I am surprised your function works at all with ATL.
- s.Fields <= retrieve all fiels contained by "s"
- s.Fields->collect(field|field.name='toto') <= if a field's name is
"toto", add "true" to the collection, otherwise add "false" to it. If
you have fields named "tata", "toto", "titi", you then get a collection
containing "false", "true", "false" (the result of "field.name='toto'".
This is true in both ATL and Acceleo as it is basic OCL.
- s.Fields->collect(field|field.name='toto').notEmpty() <= returns true
if "s" contains at least one field, false otherwise, whatever the result
of "collect" as it does not alter the collection size.
"Testing if a collection contains a specific element" is done with
"exists", not "collect". You need to use :
- s.Fields->exists(field.name='toto')
where "exists(expression)" means "return true if at least one of the
elements in the collection validates 'expression'".
See also the OCL documentation we provide with Acceleo :
http://help.eclipse.org/helios/topic/org.eclipse.acceleo.doc /doc/html/ocl_operation_reference.html
Laurent Goubet
Obeo
poltrox wrote:
> elements.
> Thanks
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040701010005030008010105--
Re: [Acceleo] How to traduct s.Fields ->collect(field|field.name='toto').notEmpty() [message #632775 is a reply to message #632746] Thu, 14 October 2010 05:02 Go to previous messageGo to next message
Sorry , but my question is how to traduct because in my acceleo template I can't use there ocl action on my object Fields.
Autocompletion do not take me exist() or collect() or includes() propositions. I have only acces at econtains, econtents .... and i dont find in this list an equivalent to exists.
s.fields is in my model a list of 0 * reference of Field.
Is it possible in a template to write an expression like s.Fields->exists(field.name='toto') ?
Re: [Acceleo] How to traduct s.Fields ->collect(field|field.name='toto').notEmpty() [message #632778 is a reply to message #632631] Thu, 14 October 2010 05:05 Go to previous message
I have find.
I haven't see before today as operating -> is works in template . I always use .
Thanks for your response.
[Updated on: Thu, 14 October 2010 05:10] by Moderator
Previous Topic:[XPAND] Workflow problem
Next Topic:[Xpand] problem to launch a workflow from another one
Current Time: Sat Jul 26 20:43:15 EDT 2025
Powered by FUDForum. Page generated in 0.05715 seconds
