Home » Modeling » UML2 » Re: How retrieve DefaultValue of a Property
Re: How retrieve DefaultValue of a Property [message #632591] Wed, 13 October 2010 10:13 Go to next message
Tom,
This sounds like a UML2 question that's best asked on the UML2
newsgroup, which I've added to the "to" list of the reply, so no need to
repost. I bet if you used the debugger (your best friend) to look at
the instance you'd know which field stores the value and then you could
look at the source code to see which method returns that field...
Tom Brandenburg wrote:
> Hello,
> currently I convert XMI files, to be processed in Eclipse. Following
> extract of the XMI:
> <ownedAttribute xmi:type="uml:Property" name="testAttr2"
> xmi:id="BOUML_0x27617_1" visibility="public">
> <defaultValue xmi:type="uml:LiteralString"
> xmi:id="BOUML_VALUE_0x27617_1" value="56"/>
> </ownedAttribute>
> evaluates to the following tree structure of the LiteralString:
> obj (LiteralStringImpl)
> +- eContainer (PropertyImpl)
> +- defaultValue (LiteralStringImpl)
> +- value ("56")
> But with what method of "obj" I get the value "56" of the defaultValue?
> Thanks in advance and best regards
> Tom
Re: How retrieve DefaultValue of a Property [message #632652 is a reply to message #632591] Wed, 13 October 2010 13:15 Go to previous messageGo to next message
Hi Tom
I'm not a major UML expert, but it looks as if defaultValue is not part
of the model, just the meta-model, so:
At the modeling level you need an OCL ability to navigate the meta-model
that is not currently available (under discussion).
Pragmatically, you can just create a new object and see what value it
gets by default.
Using Ecore reflection you can navigate to the EClass and then the
EAttribute where the default value is reified.
Ed Willink
On 13/10/2010 15:13, Ed Merks wrote:
> Tom,
> repost. I bet if you used the debugger (your best friend) to look at the
> instance you'd know which field stores the value and then you could look
>> Hello,
>> extract of the XMI:
>> </ownedAttribute>
>> +- value ("56")
>> Tom
Re: How retrieve DefaultValue of a Property [message #632707 is a reply to message #632591] Wed, 13 October 2010 21:28 Go to previous messageGo to next message
Tom, this is some code from the TextUML Toolkit Graphviz-based renderer for showing the default value for a property:
                if (property.getDefaultValue() != null) {
			ValueSpecification defaultValue = property.getDefaultValue();
			String basicValue = defaultValue.stringValue();
			if ("String".equals(property.getType().getName()))
				basicValue = "\"" + basicValue + "\"";
			w.print(" = " + basicValue);
You can also just use property.getDefault().
Rafael
http://abstratt.com
Re: How retrieve DefaultValue of a Property [message #638480 is a reply to message #632707] Thu, 11 November 2010 07:57 Go to previous message
Hello guys,
I just saw that this topic was moved to this newsgroup now. So here is what I've written in the old thread:
Hello all,
ok I found it Smile Unfortunetely my previous search started at "LiteralStringImpl". Now I saw that already "Property" has a method called getDefaultValue Smile
Thanks and bye
Tom
Nevertheless thank you for your answers and help!
Bye Tom Smile
Previous Topic:defaultValue of an EnumerationLiteral is discarded
Next Topic:How to create property value of a Slot
Current Time: Wed Jul 23 10:47:18 EDT 2025
Powered by FUDForum. Page generated in 0.07068 seconds
