Home » Modeling » OCL » [OCLInEcore] Change default error messages
[OCLInEcore] Change default error messages [message #552198] Wed, 11 August 2010 04:17 Go to next message
Hi all,
finally, I've been able to use OCLInEcore and Eugenia without any
problema. My question is related to the message shown when the editor
validate the constraint. The default message is: The <nameofConstraint>
constraint is violated on <model element>.
I'd like to customize this message in order to explain the problem
better. Is there any way to do this with [OCLInEcore]?
Thanks in advanced,
Toñi
Re: [OCLInEcore] Change default error messages [message #552206 is a reply to message #552198] Wed, 11 August 2010 04:48 Go to previous messageGo to next message
Hi Toni
No messages are not customisable; well I'm sure they are if you modify
enough code intelligently. But it is a very sensible request.
I've been considering suggesting a change to the Complete OCL grammar
for e.g.
inv nameOfConstraint: bodyOfConstraint
to allow:
inv nameOfConstraint(reason): bodyOfConstraint
where 'reason' is a string-valued expression that an implementation may
choose to evaluate to explain the constraint failure.
OCLinEcore would of course then have a corresponding syntax.
I'll submit the OMG issue now.
This should then make OCL-based validation in the editors and other
tools user-friendly.
Ed Willink
On 11/08/2010 09:17, Toñi Reina Quintero wrote:
> Hi all,
> Thanks in advanced,
> Toñi
Re: [OCLInEcore] Change default error messages [message #552213 is a reply to message #552206] Wed, 11 August 2010 05:58 Go to previous messageGo to next message
Ok, Ed,
thanks for the info.
El 11/08/2010 10:48, Ed Willink escribió:
> Hi Toni
> for e.g.
> to allow:
> Regards
> Ed Willink
>> Hi all,
>> Thanks in advanced,
>> Toñi
Re: [OCLInEcore] Change default error messages [message #556535 is a reply to message #552198] Wed, 01 September 2010 12:47 Go to previous messageGo to next message
Hi Toni,
could you help me out using Eugenia und OCLinEcore together? I thougth, i had to use emfatic for this. Is it possible to use Eugenia only with OCLinEcore?
Simon
Re: [OCLInEcore] Change default error messages [message #632664 is a reply to message #556535] Wed, 13 October 2010 15:24 Go to previous messageGo to next message
As an example of how to do this, you might want to take a look at Check (from the Itemis guys), which has a flexible way to get exactly the error message you want.
Jos
Re: [OCLInEcore] Change default error messages [message #632730 is a reply to message #632664] Thu, 14 October 2010 01:40 Go to previous messageGo to next message
Hi Jos
Work in progress uses OCL for the OCL validation and implements issue 15412:
"Suggest add an optional argument to the (not-optional) constraint name.
e.g.
inv ConstraintName('Unable to find ' + self.target.name): ..."
I am keen to share as much OCL as possible from the OCL spec in order to
debug the spec. Xtext will already execute OCL-based validation.
Ed
> Jos
Re: [OCLInEcore] Change default error messages [message #633214 is a reply to message #632730] Fri, 15 October 2010 12:40 Go to previous messageGo to next message
In Check the error message is simply an OCL expression of type String. This allows full access to information from the model, not just one element. You could write
inv ConstraintName('Unable to find ' + self.target.name + ' for ' + self.kindName + ' in model ' + self.model.name):
   <<the invariant in OCL>>
I think this just a logical extension of what is proposed already. And it only uses OCL, nothing else as you rightfully want.
Re: [OCLInEcore] Change default error messages [message #633294 is a reply to message #633214] Sat, 16 October 2010 01:13 Go to previous message
Hi Jos
I'm not fond of Check or Xpand, since they use a hybrid Java-like
OCL-like language.
I can see an argument for a different OCL syntax that fixes the "->"
surprise, but not one that fails to realize other important OCL
characreristics.
My challenge is to make MDT/OCL sufficiently robust and re-useable to
encourage non MDT/OCL Eclipse projects to migrate. Making the Standard
Library model-driven may allow a Check syntax to use MDT/OCL tooling.
A Complete OCL document should provide similar capabilities to Check in
standard form; we just need to solve the problme of how a tool using a
model with an associated meta-model discovers the complementing Complete
OCL. For embedded OCLinEcore this is all much easier.
Your example of an arbitrary String expression was exactly what I'd
intended. My only uncertainty is whether the string expression is
evaluated in the scope of the declaration or the scope of the failed
invariant, which could allow re-use of already computed let variables
and prevailing iterator content. If 'invalid' is relaxed to behave as,
rather than be, a singleton, then 'invalid' (just like an exception)
could carry a reason and/or exception trace from the point of creation
of an invalid value to the point of analysis of that invalid value.
Ed Willink
Previous Topic:[OCL-Java] java.lang.NoClassDefFoundError: lpg/runtime/RuleAction
Next Topic:[OCL-ECORE-JAVA] OCL Queries on Ecore model from Java code.
Current Time: Sat Jul 26 02:19:57 EDT 2025
Powered by FUDForum. Page generated in 0.08577 seconds
