Home » Modeling » EMF » MissingResourceException when using EMF in standalone mode
MissingResourceException when using EMF in standalone mode [message #632244] Tue, 12 October 2010 05:12 Go to next message
I'm using EMF in standalone mode, more specifically inside an ANT
script. The ANT script does load and validate a GenModel and thereby
also the referenced Ecore model.
I get the following exception:
java.util.MissingResourceException: The string resource
'_UI_EClassifierInstanceTypeNameAnalysisResult_diagnostic' could not be
located
at
org.eclipse.emf.common.util.DelegatingResourceLocator.delega tedGetString(DelegatingResourceLocator.java:487)
at
org.eclipse.emf.common.util.DelegatingResourceLocator.getStr ing(DelegatingResourceLocator.java:392)
at
org.eclipse.emf.common.util.DelegatingResourceLocator.getStr ing(DelegatingResourceLocator.java:506)
at
org.eclipse.emf.common.util.DelegatingResourceLocator.getStr ing(DelegatingResourceLocator.java:498)
at
org.eclipse.emf.ecore.util.EcoreValidator$EGenericTypeBuilde r.getString(EcoreValidator.java:4960)
at
org.eclipse.emf.ecore.util.EcoreValidator$EGenericTypeBuilde r.createDiagnostic(EcoreValidator.java:4945)
at
org.eclipse.emf.ecore.util.EcoreValidator$EGenericTypeBuilde r.parseInstanceTypeName(EcoreValidator.java:4219)
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenBaseImpl.getT ype(GenBaseImpl.java:1323)
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenBaseImpl.getT ype(GenBaseImpl.java:1278)
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenBaseImpl.getT ypeArgument(GenBaseImpl.java:3443)
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenBaseImpl.getT ype(GenBaseImpl.java:1355)
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenTypedElementI mpl.getQualifiedListItemType(GenTypedElementImpl.java:352)
I'd guess the plugin.properties file in
org.eclipse.emf.ecore_2.6.1.v20100914-1218.jar, which contains the
requested property is not resolved correctly.
Does anyone know what might cause this exception?
Any help is very much appreciated.
Mirko
Re: MissingResourceException when using EMF in standalone mode [message #632281 is a reply to message #632244] Tue, 12 October 2010 08:27 Go to previous messageGo to next message
Mirko,
I'd expect that to work. Maybe you can trace what's happening in
DelegatingResourceLocator.doGetString?
Mirko Seifert wrote:
> be located
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Best regards,
> Mirko
Re: MissingResourceException when using EMF in standalone mode [message #632615 is a reply to message #632281] Wed, 13 October 2010 10:56 Go to previous messageGo to next message
--------------040106010403030901090809
Hi Ed,
I've created a small class that reproduces the problem. It's attached.
After compiling the class you can run it as follows:
java -cp
.../bin:../libs/plugins/org.eclipse.emf.ecore_2.6.1.v2010091 4-1218.jar:../libs/plugins/org.eclipse.emf.common_2.6.0.v201 00914-1218.jar:../libs/plugins/org.eclipse.emf.ecore.xmi_2.5 .0.v20100521-1846.jar:../libs/plugins/org.eclipse.emf.codege n.ecore_2.6.1.v20100914-1218.jar:../libs/plugins/org.eclipse .emf.codegen_2.6.0.v20100914-1218.jar
emf.StandaloneEMFTest "file:/home/ed/test/Ecore.genmodel"
Of course, you'll need to adjust the paths ("../libs/plugins" and
"/home/ed/test/"). Also, you need to extract "Ecore.genmodel" and
"Ecore.ecore" to /home/ed/test.
When you run the example, the exception mentioned earlier is thrown.
Actually a different property cannot be found, but the exception is the
same.
Thanks a lot in advance!
Mirko
12.10.2010 14:27, Ed Merks:
> Mirko,
>> Hi,
>> be located
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Best regards,
>> Mirko
name="StandaloneEMFTest.java"
filename="StandaloneEMFTest.java"
cGFja2FnZSBlbWY7DQoNCmltcG9ydCBvcmcuZWNsaXBzZS5lbWYuY29kZWdl bi5lY29yZS5n
ZW5tb2RlbC5HZW5GZWF0dXJlOw0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5j b2RlZ2VuLmVj
b3JlLmdlbm1vZGVsLkdlbk1vZGVsUGFja2FnZTsNCmltcG9ydCBvcmcuZWNs aXBzZS5lbWYu
Y29tbW9uLnV0aWwuRUxpc3Q7DQppbXBvcnQgb3JnLmVjbGlwc2UuZW1mLmNv bW1vbi51dGls
LlRyZWVJdGVyYXRvcjsNCmltcG9ydCBvcmcuZWNsaXBzZS5lbWYuY29tbW9u LnV0aWwuVVJJ
Ow0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5lY29yZS5FT2JqZWN0Ow0KaW1w b3J0IG9yZy5l
Y2xpcHNlLmVtZi5lY29yZS5FUGFja2FnZTsNCmltcG9ydCBvcmcuZWNsaXBz ZS5lbWYuZWNv
cmUucmVzb3VyY2UuUmVzb3VyY2U7DQppbXBvcnQgb3JnLmVjbGlwc2UuZW1m LmVjb3JlLnJl
c291cmNlLlJlc291cmNlU2V0Ow0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5l Y29yZS5yZXNv
dXJjZS5pbXBsLlJlc291cmNlU2V0SW1wbDsNCmltcG9ydCBvcmcuZWNsaXBz ZS5lbWYuZWNv
cmUuRWNvcmVQYWNrYWdlOwoNCnB1YmxpYyBjbGFzcyBTdGFuZGFsb25lRU1G VGVzdCB7DQoN
CglwdWJsaWMgc3RhdGljIHZvaWQgbWFpbihTdHJpbmdbXSBhcmdzKSB7DQoJ CWlmIChhcmdz
Lmxlbmd0aCA8IDEpIHsNCgkJCVN5c3RlbS5vdXQucHJpbnRsbigiVXNhZ2U6 IGphdmEgU3Rh
bmRhbG9uZUVNRlRlc3QgPFVSST4iKTsNCgkJCXJldHVybjsNCgkJfQ0KCQly ZWdpc3RlckZh
Y3RvcmllcygpOw0KCQkNCgkJVVJJIHVyaSA9IFVSSS5jcmVhdGVVUkkoYXJn c1swXSk7DQoJ
CVJlc291cmNlU2V0IHJzID0gbmV3IFJlc291cmNlU2V0SW1wbCgpOw0KCQlS ZXNvdXJjZSBy
ZXNvdXJjZTsKCQl0cnkgewoJCSAgICByZXNvdXJjZSA9IHJzLmdldFJlc291 cmNlKHVyaSwg
dHJ1ZSk7DQoJCX1jYXRjaCAoUnVudGltZUV4Y2VwdGlvbiBlKSB7CgkJICAg IGUucHJpbnRT
dGFja1RyYWNlKCk7CgkJICAgIHJldHVybjsKCQl9CgkJaWYgKHJlc291cmNl ID09IG51bGwp
IHsNCgkJCVN5c3RlbS5vdXQucHJpbnRsbigiQ2FuJ3QgbG9hZCByZXNvdXJj ZSBmcm9tICIg
KyB1cmkpOw0KCQl9DQoJCUVMaXN0PEVPYmplY3Q+IGNvbnRlbnRzID0gcmVz b3VyY2UuZ2V0
Q29udGVudHMoKTsNCgkJZm9yIChFT2JqZWN0IGVPYmplY3QgOiBjb250ZW50 cykgew0KCQkJ
VHJlZUl0ZXJhdG9yPEVPYmplY3Q+IGFsbENoaWxkcmVuID0gZU9iamVjdC5l QWxsQ29udGVu
dHMoKTsNCgkJCXdoaWxlIChhbGxDaGlsZHJlbi5oYXNOZXh0KCkpIHsNCgkJ CQlFT2JqZWN0
IGNoaWxkID0gYWxsQ2hpbGRyZW4ubmV4dCgpOw0KCQkJCWlmIChjaGlsZCBp bnN0YW5jZW9m
IEdlbkZlYXR1cmUpIHsNCgkJCQkJR2VuRmVhdHVyZSBnZW5GZWF0dXJlID0g KEdlbkZlYXR1
cmUpIGNoaWxkOw0KCQkJCQlTeXN0ZW0ub3V0LnByaW50bG4oIlJldHJpZXZp bmcgUXVhbGlm
aWVkTGlzdEl0ZW1UeXBlIGZyb20gIiArIGdlbkZlYXR1cmUpOw0KCQkJCQln ZW5GZWF0dXJl
LmdldFF1YWxpZmllZExpc3RJdGVtVHlwZShudWxsKTsNCgkJCQl9DQoJCQl9 DQoJCX0NCgl9
DQoNCglwcml2YXRlIHN0YXRpYyB2b2lkIHJlZ2lzdGVyRmFjdG9yaWVzKCkg ew0KCQlFUGFj
a2FnZS5SZWdpc3RyeS5JTlNUQU5DRS5wdXQoR2VuTW9kZWxQYWNrYWdlLmVO U19VUkksDQoJ
CQkJR2VuTW9kZWxQYWNrYWdlLmVJTlNUQU5DRSk7DQoJCUVQYWNrYWdlLlJl Z2lzdHJ5LklO
U1RBTkNFLnB1dChFY29yZVBhY2thZ2UuZU5TX1VSSSwNCgkJCQlFY29yZVBh Y2thZ2UuZUlO
U1RBTkNFKTsNCg0KCQlHZW5Nb2RlbFBhY2thZ2UuZUlOU1RBTkNFLmdldEdl bkNsYXNzKCk7
DQoJCUVjb3JlUGFja2FnZS5lSU5TVEFOQ0UuZ2V0RUNsYXNzKCk7CgkJUmVz b3VyY2UuRmFj
dG9yeS5SZWdpc3RyeS5JTlNUQU5DRS5nZXRFeHRlbnNpb25Ub0ZhY3RvcnlN YXAoKS5wdXQo
DQoJCQkJImVjb3JlIiwNCgkJCQluZXcgb3JnLmVjbGlwc2UuZW1mLmVjb3Jl LnhtaS5pbXBs
LkVjb3JlUmVzb3VyY2VGYWN0b3J5SW1wbCgpKTsNCgkJUmVzb3VyY2UuRmFj dG9yeS5SZWdp
c3RyeS5JTlNUQU5DRS5nZXRFeHRlbnNpb25Ub0ZhY3RvcnlNYXAoKS5wdXQo DQoJCQkJImdl
bm1vZGVsIiwNCgkJCQluZXcgb3JnLmVjbGlwc2UuZW1mLmVjb3JlLnhtaS5p bXBsLkVjb3Jl
UmVzb3VyY2VGYWN0b3J5SW1wbCgpKTsNCgl9DQp9DQo=
--------------040106010403030901090809--
Re: MissingResourceException when using EMF in standalone mode [message #632676 is a reply to message #632615] Wed, 13 October 2010 16:39 Go to previous messageGo to next message
Mirko,
I installed the SR1 modeling package, generated a model (from
Library.xsd as in the tutorial) and also generated the tests. Then I
copied your class into the tests project and ran it as a java
application. It ran fine. I also added this
Diagnostic result =
EcoreValidator.EGenericTypeBuilder.INSTANCE.parseInstanceTyp eName( "a#b");
System.err.println("###" + result);
And it prints this:
###Diagnostic ERROR source=org.eclipse.emf.ecore.model code=42 Analysis
result for the instance type name 'a#b'
data=[org.eclipse.emf.ecore.impl.EGenericTypeImpl@e28b9 (expression: ?),
a#b] [Diagnostic ERROR source=org.eclipse.emf.ecore.model code=42 The
'#' at index 1 is not expected data=[1]]
So the messages are definitely being loaded...
I suspect that the issue is the ../blah you're using to specify the
path. I'm not sure Java will resolve that to an absolute path. EMF will
definitely rely on the path being absolute when it asks Java for the
jar's URL.
> Hi Ed,
> java -cp
> ../bin:../libs/plugins/org.eclipse.emf.ecore_2.6.1.v20100914 -1218.jar:../libs/plugins/org.eclipse.emf.common_2.6.0.v2010 0914-1218.jar:../libs/plugins/org.eclipse.emf.ecore.xmi_2.5. 0.v20100521-1846.jar:../libs/plugins/org.eclipse.emf.codegen .ecore_2.6.1.v20100914-1218.jar:../libs/plugins/org.eclipse. emf.codegen_2.6.0.v20100914-1218.jar
> the same.
> Mirko
>> Mirko,
>>> Hi,
>>> be located
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Best regards,
>>> Mirko
Re: MissingResourceException when using EMF in standalone mode [message #632831 is a reply to message #632676] Thu, 14 October 2010 08:31 Go to previous messageGo to next message
Hi Ed,
I replaced the ../ parts of the classpath with absolute paths, but exception remains. Any other ideas?
Mirko
Re: MissingResourceException when using EMF in standalone mode [message #632931 is a reply to message #632831] Thu, 14 October 2010 13:15 Go to previous messageGo to next message
Mirko,
What exactly does your classpath look like?
Try doing exactly what I described. With that approach, Eclipse sets
up your classpath and you can look closely at how it's specified in the
debug view looking at the properties of the terminated application. You
can also trace why this stuff is failing. I.e., determine what's the
getBaseURL computed for the Ecore jar...
> Hi Ed,
> Best regards,
> Mirko
Re: MissingResourceException when using EMF in standalone mode [message #632951 is a reply to message #632931] Thu, 14 October 2010 14:54 Go to previous messageGo to next message
Hi Ed,
my classpath looked like this:
java -cp /home/hudson/build_server/output:/home/hudson/build_server/l ibs/plugins/org.eclipse.emf.ecore_2.6.1.v20100914-1218.jar:/ home/hudson/build_server/libs/plugins/org.eclipse.emf.common _2.6.0.v20100914-1218.jar:/home/hudson/build_server/libs/plu gins/org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846.jar:/hom e/hudson/build_server/libs/plugins/org.eclipse.emf.codegen.e core_2.6.1.v20100914-1218.jar:/home/hudson/build_server/libs /plugins/org.eclipse.emf.codegen_2.6.0.v20100914-1218.jar emf.StandaloneEMFTest "file:/home/hudson/build_server/build/Ecore.genmodel"
I did what you suggested on my windows machine where it worked fine as you suspected. I took the classpath from the properties view of the terminated applicated and converted it to be usable on linux (the ANT script runs on a Linux box). I replaced ";" with ":" (the path separator) and the path my Eclipse installation on windows with the path to Eclipse on linux (/home/hudson/build_server/libs). I exchange "javaw.exe" with "java" and removed the encoding parameter (-Dfile.encoding=Cp1252).
Now the classpath is slightly longer:
java -classpath /home/hudson/build_server/output:/home/hudson/build_server/l ibs/plugins/org.eclipse.core.runtime_3.6.0.v20100505.jar:/ho me/hudson/build_server/libs/plugins/org.eclipse.osgi_3.6.1.R 36x_v20100806.jar:/home/hudson/build_server/libs/plugins/org .eclipse.equinox.common_3.6.0.v20100503.jar:/home/hudson/bui ld_server/libs/plugins/org.eclipse.core.jobs_3.5.1.R36x_v201 00824.jar:/home/hudson/build_server/libs/plugins/org.eclipse .core.runtime.compatibility.registry_3.3.0.v20100520\runtime _registry_compatibility.jar:/home/hudson/build_server/libs/p lugins/org.eclipse.equinox.registry_3.5.0.v20100503.jar:/hom e/hudson/build_server/libs/plugins/org.eclipse.equinox.prefe rences_3.3.0.v20100503.jar:/home/hudson/build_server/libs/pl ugins/org.eclipse.core.contenttype_3.4.100.v20100505-1235.ja r:/home/hudson/build_server/libs/plugins/org.eclipse.equinox .app_1.3.1.R36x_v20100803.jar:C:\Projects\Eclipse-Workspaces \EMFText-DEV\library\bin:/home/hudson/build_server/libs/plug ins/org.eclipse.emf.ecore_2.6.1.v20100914-1218.jar:/home/hud son/build_server/libs/plugins/org.eclipse.emf.common_2.6.0.v 20100914-1218.jar:/home/hudson/build_server/libs/plugins/org .eclipse.emf.ecore.xmi_2.5.0.v20100521-1846.jar:/home/hudson /build_server/libs/plugins/org.junit_4.8.1.v4_8_1_v20100427- 1100\junit.jar:/home/hudson/build_server/libs/plugins/org.ha mcrest.core_1.1.0.v20090501071000.jar:/home/hudson/build_ser ver/libs/plugins/org.eclipse.emf.codegen_2.6.0.v20100914-121 8.jar:/home/hudson/build_server/libs/plugins/org.eclipse.emf .codegen.ecore_2.6.1.v20100914-1218.jar emf.StandaloneEMFTest file://home/hudson/build_server/build/Ecore.genmodel
Unfortunately, I do still face the exception. Maybe there is problem due to the forward slashes used on Linux? What can I do to nail the problem further down?
Thanks for your help!
Mirko
Re: MissingResourceException when using EMF in standalone mode [message #632964 is a reply to message #632951] Thu, 14 October 2010 16:03 Go to previous messageGo to next message
Mirko,
Comments below.
> Hi Ed,
> you suspected.
That's good.
You really only need EMF's jars.
> java -classpath
Yes, don't use \ on Linux.
Figuring out what EcorePlugin.INSTANCE.getBaseURL() returns is
important. Try a simple single class that prints out that value...
> Mirko
Re: MissingResourceException when using EMF in standalone mode [message #633313 is a reply to message #632964] Sat, 16 October 2010 04:42 Go to previous messageGo to next message
Hi Ed,
calling EcorePlugin.INSTANCE.getBaseURL()
yields the following exception:
Exception in thread "main" java.util.MissingResourceException: Missing properties: org/eclipse/emf/ecore/plugin/plugin.properties
at org.eclipse.emf.common.util.DelegatingResourceLocator.getBas eURL(DelegatingResourceLocator.java:206)
at emf.StandaloneEMFTest.main(StandaloneEMFTest.java:18)
I guess that's not bringing us closer to figure out what's wrong? What else can I do?
Mirko
Re: MissingResourceException when using EMF in standalone mode [message #633372 is a reply to message #633313] Sun, 17 October 2010 00:33 Go to previous messageGo to next message
Mirko,
Can you step through the method with the debugger?
> Hi Ed,
> at
> else can I do?
> Best regards,
> Mirko
Re: MissingResourceException when using EMF in standalone mode [message #633622 is a reply to message #633372] Mon, 18 October 2010 10:53 Go to previous messageGo to next message
Hi Ed,
I started a remote debugging session and sadly I had to realise that there was a modified version of the EcorePlugin class in the classpath. I had created this earlier to figure out what was wrong. Unfortunatly, what was supposed to resolve the problem, caused the problem - since this modified class was not in the EMF jar, the properties file could not be found.
I removed my modified version of the EcorePlugin class and now everything works fine.
Thank you for your support and I apologize for any confusion I might have caused.
Mirko
Re: MissingResourceException when using EMF in standalone mode [message #633651 is a reply to message #633622] Mon, 18 October 2010 12:31 Go to previous message
Mirko,
Not only do we help address problems, we take confessions and grant
absolutions. :-P
> Hi Ed,
> have caused.
> Best regards,
> Mirko
Previous Topic:[EMF-OCL-Java] OCL Query on Ecore model from Java.
Next Topic:Re: Data type and configuring to existing DB
Current Time: Tue Sep 23 17:11:14 EDT 2025
Powered by FUDForum. Page generated in 0.14922 seconds
