BIRT publishes xml parser an crashes second webapp [message #548574] |
Thu, 22 July 2010 07:52  |
When I deploy BIRT on the same web application as the web application BIRT should generate reports for
and restart the other web application the other web application fails to start.
The other web application is running without problems until BIRT.
The used Server is Websphere 6.1(Servlet 2.4) on Windows or AS400.
I tried BIRT Versions 2.3.2.1, 2.5.2 and 2.6.
In the other web application JSF is added manually because the server does not support the required version.
It seems that BIRT loads an XML-Parser or sets some settings that cause the problem.
00000028 config W JSF1056: Unable to create InputSource for URL 'wsjar:file:/C:/Programme/IBM/SDP70/runtimes/base_v61/profiles/AppSrv01/installedApps/ws016155Node01Cell/ibp_ear.ear/ibp.war/WEB-INF/lib/jsf-impl-1.2_14.jar!/com/sun/faces/web-facesconfig_1_1.dtd'.
0000001f WebApp E Exception caught while initializing context
com.sun.faces.config.ConfigurationException: CONFIGURATION FAILED! java.sun.com
at com.sun.faces.config.ConfigManager.initialize(ConfigManager.java:214)
at com.sun.faces.config.ConfigureListener.contextInitialized(ConfigureListener.java:199)
at com.ibm.ws.wswebcontainer.webapp.WebApp.notifyServletContextCreated(WebApp.java:652)
(more...) and0000001f ServletWrappe E SRVE0100E: Nicht erfasste Ausnahme für init() wurde von Servlet {0} ausgelöst: java.lang.IllegalStateException: Application was not properly initialized at startup, could not find Factory: javax.faces.context.FacesContextFactory
at javax.faces.FactoryFinder$FactoryManager.getFactory(FactoryFinder.java:725)
at javax.faces.FactoryFinder.getFactory(FactoryFinder.java:239)
at javax.faces.webapp.FacesServlet.init(FacesServlet.java:164)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.init(ServletWrapper.java:226)
(more...)
Anyone an idea?
[Updated on: Mon, 26 July 2010 05:11] by Moderator
FUDForum. Page generated in 1.04997 seconds
