| URGENT: Eclipse won't start [message #265270] |
Mon, 06 October 2008 14:02  |
PLEASE HELP! I'M UNDER A VERY STRICT DEADLINE
Been using Eclipse for 6 years with very few glitches.
Suddenly, when I start Eclipse, it won't and tells me to look in the log
file.
See below for the message I find in the log.
It seems lot of people experience this problem:
http://tapestryjava.blogspot.com/2004/10/worst-eclipse-crash -ever.html
And the solution that seems to work for most people is to remove this file:
\.metadata\.plugins\org.eclipse.core.resources\.snap
and
\.metadata\.plugins\org.eclipse.core.resources\.root\.marker s.snap
But I have neither of them!
I also tried the Workspace Rebuilder listed on this page:
http://www.eclipse.org/eclipse/platform-core/downloads.html
But when I run the command line:
eclipse -application org.eclipse.core.tools.restorer.application
I see the Eclipse splash screen for a few seconds, then it goes away. If I
restart Eclipse after that, still crashes. I also tried the -data option:
eclipse -application org.eclipse.core.tools.restorer.application -data
myworkspace
giving it both the name of the workspace ("eclipse_workspace" in my case)
and the full path ("D:\Documents and Settings\Desiletsa\My
Documents\eclipse_workspace") and neither of them did anything.
What can you suggest.
Thx
Alain Désilets
--- Log file message
!ENTRY org.eclipse.osgi 4 0 2008-10-06 13:46:02.205
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:107)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
An error occurred while automatically activating bundle
org.eclipse.core.resources (39).
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in
org.eclipse.core.resources.ResourcesPlugin.start() of bundle
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 23 more
Caused by: org.eclipse.core.internal.resources.ResourceException: Problems
reading workspace tree.
at
org.eclipse.core.internal.resources.WorkspaceTreeReader_1.re adTree(WorkspaceTreeReader_1.java:171)
at
org.eclipse.core.internal.resources.SaveManager.restoreTree( SaveManager.java:916)
at
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:647)
at
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1319)
at
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1949)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1713)
at
org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPl ugin.java:363)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
... 28 more
| Re: Eclipse won't start [message #632552 is a reply to message #265270] |
Wed, 13 October 2010 08:08  |
Hi Alain,
Even I have been struggling with this problem. Did you get teh solution to it? I too don't have the .snap file. I am presently using Eclipse 3.2.1 to work on compatibility issue of a plugin.
My log file contents are as follows-
!SESSION 2010-10-11 15:37:06.148 -----------------------------------------------
eclipse.buildId=M20060921-0945
java.version=1.6.0_21
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 4 0 2010-10-11 15:37:11.163
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (45).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.compatibility.PluginActivator.star t() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1010)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
at org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:383)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
at org.eclipse.core.internal.resources.MarkerTypeDefinitionCach e.loadDefinitions(MarkerTypeDefinitionCache.java:132)
at org.eclipse.core.internal.resources.MarkerTypeDefinitionCach e. <init>(MarkerTypeDefinitionCache.java:63)
at org.eclipse.core.internal.resources.MarkerManager.<init>(MarkerManager.java:32)
at org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1878)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1653)
at org.eclipse.core.resources.ResourcesPlugin.startup(Resources Plugin.java:367)
at org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:31)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:991)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:985)
... 26 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2010-10-11 15:37:11.178
!STACK 1
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.resources.IContainer
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
... 14 more
Only when the plugin is deployed in Eclipse, it is unable to start. If I remove the plugin from the plugins folder, everything works fine. I understand that the plugin is trying to access some jar which is not present in 3.2.1. But then how is it not showing me any build path errors?
FUDForum. Page generated in 0.08231 seconds
