Home » Modeling » M2T (model-to-text transformation) » [Xpand] Debugging
[Xpand] Debugging [message #630960] Tue, 05 October 2010 12:04 Go to next message
Hey,
I'm using XpandFacade to programmatically invoke Xpand Templates and XtendFacade to programmatically invoke Xtend Extensions.
But it seems that debugging does not work. At least debugging Eclipse does not stop at breakpoints in the templates/extensions.
Is there any possibility to use debugging?
Thanks for help
Stephan
Re: [Xpand] Debugging [message #632417 is a reply to message #630960] Tue, 12 October 2010 16:09 Go to previous messageGo to next message
what about writing a mwe workflow for the debugging?
~Christian
Re: [Xpand] Debugging [message #632526 is a reply to message #632417] Wed, 13 October 2010 06:16 Go to previous message
Assuming that you're invoking Xpand/XtendFacade inside an OSGi container as a bundle (e.g., when running the plugin inside a 2nd Eclipse instance), you could try and switch on the debugging of the OSGi container itself by adding -debug (or -osgi.debug=true) to the VM arguments of the launch configuration.
Previous Topic:[Xpand/Xtend] Type problem with packages
Next Topic:[XPAND] Workflow problem
Current Time: Sun Jul 27 02:08:39 EDT 2025
Powered by FUDForum. Page generated in 0.03994 seconds
