Home » Archived » BIRT » Internal exception with Highlight, 2.6.1
Internal exception with Highlight, 2.6.1 [message #632293] Tue, 12 October 2010 09:28 Go to next message
I have created some highlights on a crosstab cell:
data["fixhours_Group/priority_Group1/Month"] > 5 && data["priority"] == 'Priority 1' Is True
and 5 similar others. If I try to edit one of them by double-click I get:
An unexpected internal exception occurred. Please see log for detail.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID:org.eclipse.birt.report.designer.ui
Version:2.6.0.v20100531
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:Caused by java.lang.NullPointerException.
Happens in 2.5 too.
Lee
Re: Internal exception with Highlight, 2.6.1 [message #632294 is a reply to message #632293] Tue, 12 October 2010 09:34 Go to previous messageGo to next message
It seems to be the Is True setting that is causing the grief.
Lee
Re: Internal exception with Highlight, 2.6.1 [message #632380 is a reply to message #632294] Tue, 12 October 2010 13:30 Go to previous messageGo to next message
Lee
Do you have the same issue if you break up the expression into two
highlight rules?
Jason
> Lee
Re: Internal exception with Highlight, 2.6.1 [message #632834 is a reply to message #632293] Thu, 14 October 2010 08:35 Go to previous messageGo to next message
Jason
Thanks for the reply. I think it's ok if I do break it up but I want to have several joint conditions to highlight in the same crosstab.
Eg if we have different color widgets and want to highlight when the number sold exceeds a particular value, where the value is different for each widget:
sales of yellow widget > 5 set background yellow
sales of blue widget > 10 set background blue
sales of red widget > 20 set background red
I need to have a combination expression to do this don't I?
Lee
Re: Internal exception with Highlight, 2.6.1 [message #632868 is a reply to message #632834] Thu, 14 October 2010 10:09 Go to previous messageGo to next message
Lee,
Can you try running the attached report? Look at the highlight rule on
the xtab. I used an "&&" and a "is true" and did not get the error.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build &lt;2.5.2.v20100210-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<text-property
name="displayName">CUSTOMERNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTLASTNAME</property>
<text-property
name="displayName">CONTACTLASTNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTFIRSTNAME</property>
<text-property
name="displayName">CONTACTFIRSTNAME</text-property>
</structure>
<structure>
<property name="columnName">PHONE</property>
<text-property name="displayName">PHONE</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE1</property>
<text-property
name="displayName">ADDRESSLINE1</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE2</property>
<text-property
name="displayName">ADDRESSLINE2</text-property>
</structure>
<structure>
<property name="columnName">CITY</property>
<text-property name="displayName">CITY</text-property>
</structure>
<structure>
<property name="columnName">STATE</property>
<text-property name="displayName">STATE</text-property>
</structure>
<structure>
<property name="columnName">POSTALCODE</property>
<text-property
name="displayName">POSTALCODE</text-property>
</structure>
<structure>
<property name="columnName">COUNTRY</property>
<text-property
name="displayName">COUNTRY</text-property>
</structure>
<structure>
<property
name="columnName">SALESREPEMPLOYEENUMBER</property>
<text-property
name="displayName">SALESREPEMPLOYEENUMBER</text-property>
</structure>
<structure>
<property name="columnName">CREDITLIMIT</property>
<text-property
name="displayName">CREDITLIMIT</text-property>
</structure>
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property
name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property
name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property
name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property
name="displayName">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property
name="displayName">COMMENTS</text-property>
</structure>
<structure>
<property
name="columnName">CUSTOMERNUMBER_20</property>
<text-property
</structure>
<structure>
<property name="columnName">ORDERNUMBER_21</property>
<text-property
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE_26</property>
<text-property
</structure>
<structure>
<property name="columnName">PRODUCTNAME</property>
<text-property
name="displayName">PRODUCTNAME</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTLINE</property>
<text-property
name="displayName">PRODUCTLINE</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTSCALE</property>
<text-property
name="displayName">PRODUCTSCALE</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTVENDOR</property>
<text-property
name="displayName">PRODUCTVENDOR</text-property>
</structure>
<structure>
<property
name="columnName">PRODUCTDESCRIPTION</property>
<text-property
name="displayName">PRODUCTDESCRIPTION</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYINSTOCK</property>
<text-property
name="displayName">QUANTITYINSTOCK</text-property>
</structure>
<structure>
<property name="columnName">BUYPRICE</property>
<text-property
name="displayName">BUYPRICE</text-property>
</structure>
<structure>
<property name="columnName">MSRP</property>
<text-property name="displayName">MSRP</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">12</property>
<property
name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">14</property>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="position">15</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">16</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">17</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">18</property>
<property name="name">STATUS</property>
</structure>
<structure>
<property name="position">19</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">20</property>
<property name="name">CUSTOMERNUMBER_20</property>
</structure>
<structure>
<property name="position">21</property>
<property name="name">ORDERNUMBER_21</property>
</structure>
<structure>
<property name="position">22</property>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="position">23</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">24</property>
<property name="name">PRICEEACH</property>
</structure>
<structure>
<property name="position">25</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
<structure>
<property name="position">26</property>
<property name="name">PRODUCTCODE_26</property>
</structure>
<structure>
<property name="position">27</property>
<property name="name">PRODUCTNAME</property>
</structure>
<structure>
<property name="position">28</property>
<property name="name">PRODUCTLINE</property>
</structure>
<structure>
<property name="position">29</property>
<property name="name">PRODUCTSCALE</property>
</structure>
<structure>
<property name="position">30</property>
<property name="name">PRODUCTVENDOR</property>
</structure>
<structure>
<property name="position">31</property>
<property name="name">PRODUCTDESCRIPTION</property>
</structure>
<structure>
<property name="position">32</property>
<property name="name">QUANTITYINSTOCK</property>
</structure>
<structure>
<property name="position">33</property>
<property name="name">BUYPRICE</property>
</structure>
<structure>
<property name="position">34</property>
<property name="name">MSRP</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="name">SALESREPEMPLOYEENUMBER</property>
<property
name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTNAME</property>
</structure>
<structure>
<property name="nativeName">PRODUCTLINE</property>
</structure>
<structure>
<property name="nativeName">PRODUCTSCALE</property>
</structure>
<structure>
<property name="nativeName">PRODUCTVENDOR</property>
</structure>
<structure>
<property
name="nativeName">PRODUCTDESCRIPTION</property>
</structure>
<structure>
<property name="nativeName">QUANTITYINSTOCK</property>
</structure>
<structure>
<property name="nativeName">BUYPRICE</property>
</structure>
<structure>
<property name="nativeName">MSRP</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from
CLASSICMODELS.CUSTOMERS,
CLASSICMODELS.ORDERS,
CLASSICMODELS.ORDERDETAILS,
CLASSICMODELS.PRODUCTS
where
CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER=CLASSICMODELS.ORDERS. CUSTOMERNUMBER
and
CLASSICMODELS.ORDERS.ORDERNUMBER=CLASSICMODELS.ORDERDETAILS. ORDERNUMBER
and
CLASSICMODELS.ORDERDETAILS.PRODUCTCODE=CLASSICMODELS.PRODUCT S.PRODUCTCODE]] ></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>CONTACTLASTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>CONTACTFIRSTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>PHONE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:position>6</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE1</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE2</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:position>8</design:position>
<design:uiHints>
<design:displayName>CITY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>9</design:position>
<design:uiHints>
<design:displayName>STATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>POSTALCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:uiHints>
<design:displayName>COUNTRY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMBER</design:name>
<design:position>12</design:position>
<design:uiHints>
<design:displayName>SALESREPEMPLOYEENUMBER</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>SALESREPEMPLOYEENUMBER</design:label>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>13</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>CREDITLIMIT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>14</design:position>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>15</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>16</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>17</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:di
Re: Internal exception with Highlight, 2.6.1 [message #632886 is a reply to message #632868] Thu, 14 October 2010 11:01 Go to previous messageGo to next message
Sorry Jason but I can't see the whole XML in this message.
Lee
Re: Internal exception with Highlight, 2.6.1 [message #632895 is a reply to message #632293] Thu, 14 October 2010 11:30 Go to previous messageGo to next message
Oddly enough I just created a single highlight condition where a column Is Null and once I had created that, I was unable to open it and got a similar error to last time. Hmnnnn
Lee
[Updated on: Thu, 14 October 2010 11:30] by Moderator
Re: Internal exception with Highlight, 2.6.1 [message #632936 is a reply to message #632886] Thu, 14 October 2010 13:30 Go to previous messageGo to next message
--------------010100080206070508060203
Lee
Can you get the attachment?
Jason
> Lee
Content-Type: text/xml;
name="Highlightxtab.rptdesign"
filename="Highlightxtab.rptdesign"
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.5.2.v20100208 Build &lt;2.5.2.v20100210-0630></property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="6">
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set" id="7">
<structure>
<text-property name="displayName">CUSTOMERNUMBER</text-property>
</structure>
<structure>
<text-property name="displayName">CUSTOMERNAME</text-property>
</structure>
<structure>
<text-property name="displayName">CONTACTLASTNAME</text-property>
</structure>
<structure>
<text-property name="displayName">CONTACTFIRSTNAME</text-property>
</structure>
<structure>
</structure>
<structure>
<text-property name="displayName">ADDRESSLINE1</text-property>
</structure>
<structure>
<text-property name="displayName">ADDRESSLINE2</text-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<text-property name="displayName">POSTALCODE</text-property>
</structure>
<structure>
<text-property name="displayName">COUNTRY</text-property>
</structure>
<structure>
<property name="columnName">SALESREPEMPLOYEENUMBER</property>
<text-property name="displayName">SALESREPEMPLOYEENUMBER</text-property>
</structure>
<structure>
<text-property name="displayName">CREDITLIMIT</text-property>
</structure>
<structure>
<text-property name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<text-property name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<text-property name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<text-property name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<text-property name="displayName">STATUS</text-property>
</structure>
<structure>
<text-property name="displayName">COMMENTS</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER_20</property>
</structure>
<structure>
</structure>
<structure>
<text-property name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<text-property name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<text-property name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<text-property name="displayName">ORDERLINENUMBER</text-property>
</structure>
<structure>
</structure>
<structure>
<text-property name="displayName">PRODUCTNAME</text-property>
</structure>
<structure>
<text-property name="displayName">PRODUCTLINE</text-property>
</structure>
<structure>
<text-property name="displayName">PRODUCTSCALE</text-property>
</structure>
<structure>
<text-property name="displayName">PRODUCTVENDOR</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTDESCRIPTION</property>
<text-property name="displayName">PRODUCTDESCRIPTION</text-property>
</structure>
<structure>
<text-property name="displayName">QUANTITYINSTOCK</text-property>
</structure>
<structure>
<text-property name="displayName">BUYPRICE</text-property>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTDESCRIPTION</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from
where
and
and
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:position>18</design:position>
<design:nativeData
Re: Internal exception with Highlight, 2.6.1 [message #633053 is a reply to message #632293] Fri, 15 October 2010 04:35 Go to previous messageGo to next message
Jason
I don't see an 'attachment' as such but the source of the report in XML and this gets truncated, so I can't see all of it.
Is this a forum setting? I have tried various browsers.
Sorry to be a nuisance!
Lee
Re: Internal exception with Highlight, 2.6.1 [message #633234 is a reply to message #633053] Fri, 15 October 2010 14:29 Go to previous messageGo to next message
Lee,
I just emailed it to you.
Jason
On 10/15/2010 4:35 AM, Sapphie wrote:
> Jason
> Lee
Re: Internal exception with Highlight, 2.6.1 [message #633397 is a reply to message #632293] Sun, 17 October 2010 08:44 Go to previous messageGo to next message
Hi Jason
Thanks, I got the file by email.
I get the same issue - when trying to open the highlight I get an exception.
I guess there is something odd about my local setup then?
Also, why do I see the XML source of attached report designs in the forum and not a link to download them?
Lee
Re: Internal exception with Highlight, 2.6.1 [message #633619 is a reply to message #633397] Mon, 18 October 2010 10:51 Go to previous messageGo to next message
Lee
Are you using the 2.6.1 all in one download?
Jason
On 10/17/2010 8:44 AM, Sapphie wrote:
> Hi Jason
> exception.
> Lee
Re: Internal exception with Highlight, 2.6.1 [message #638411 is a reply to message #632293] Thu, 11 November 2010 04:01 Go to previous messageGo to next message
i have the same problem if i use the following condition:
BirtComp.compareString(row["FIELD1"], row["FIELD2"]) Is True
But if I replace "Is True" with "Equal to true" it is working without Exception:
BirtComp.compareString(row["FIELD1"], row["FIELD2"]) Equal to true
Here the Stacktrace from the eclipse log for the first condition:
org.eclipse.birt.report.designer.core.runtime.GUIException: Caused by java.lang.NullPointerException.
	at org.eclipse.birt.report.designer.core.runtime.GUIException.createGUIException(GUIException.java:78)
	at org.eclipse.birt.report.designer.internal.ui.util.ExceptionHandler.handle(ExceptionHandler.java:169)
	at org.eclipse.birt.report.designer.internal.ui.util.ExceptionHandler.handle(ExceptionHandler.java:150)
	at org.eclipse.birt.report.designer.internal.ui.util.ExceptionHandler.handle(ExceptionHandler.java:89)
	at org.eclipse.birt.report.designer.ui.util.ExceptionUtil.handle(ExceptionUtil.java:36)
	at org.eclipse.birt.report.designer.internal.ui.views.attributes.provider.HighlightDescriptorProvider.edit(HighlightDescriptorProvider.java:377)
	at org.eclipse.birt.report.designer.internal.ui.views.attributes.widget.PreviewPropertyDescriptor.handleEditEvent(PreviewPropertyDescriptor.java:236)
	at org.eclipse.birt.report.designer.internal.ui.views.attributes.widget.PreviewPropertyDescriptor$6.doubleClick(PreviewPropertyDescriptor.java:190)
	at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:824)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:822)
	at org.eclipse.jface.viewers.StructuredViewer.handleDoubleSelect(StructuredViewer.java:1113)
	at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1225)
	at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:238)
	at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:235)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:296)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
	at org.eclipse.birt.report.designer.ui.dialogs.HighlightRuleBuilder.syncViewProperties(HighlightRuleBuilder.java:1279)
	at org.eclipse.birt.report.designer.ui.dialogs.HighlightRuleBuilder.createContents(HighlightRuleBuilder.java:514)
	at org.eclipse.jface.window.Window.create(Window.java:431)
	at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
	at org.eclipse.birt.report.designer.ui.dialogs.HighlightRuleBuilder.open(HighlightRuleBuilder.java:2491)
	at org.eclipse.birt.report.designer.internal.ui.views.attributes.provider.HighlightDescriptorProvider.edit(HighlightDescriptorProvider.java:367)
	... 37 more
BIRT Engine OSGi Runtime SDK Feature 2.6.1.v20100617a-57B185wFfAqPz0Ef8mBsMkG-0hfS
BIRT Framework 2.6.1.v20100709a-9iF7A8FGLY4z0pxX3ORrsdrp6JXb
Jonas
Re: Internal exception with Highlight, 2.6.1 [message #638526 is a reply to message #638411] Thu, 11 November 2010 09:55 Go to previous message
Jonas,
can you open a bug for this?
Jason
On 11/11/2010 4:01 AM, Jonas Esser wrote:
> Hello,
> Exception:
> at
> org.eclipse.birt.report.designer.core.runtime.GUIException.c reateGUIException(GUIException.java:78)
> at
> org.eclipse.birt.report.designer.internal.ui.util.ExceptionH andler.handle(ExceptionHandler.java:169)
> at
> org.eclipse.birt.report.designer.internal.ui.util.ExceptionH andler.handle(ExceptionHandler.java:150)
> at
> org.eclipse.birt.report.designer.internal.ui.util.ExceptionH andler.handle(ExceptionHandler.java:89)
> at
> org.eclipse.birt.report.designer.ui.util.ExceptionUtil.handl e(ExceptionUtil.java:36)
> at
> org.eclipse.birt.report.designer.internal.ui.views.attribute s.provider.HighlightDescriptorProvider.edit(HighlightDescrip torProvider.java:377)
> at
> org.eclipse.birt.report.designer.internal.ui.views.attribute s.widget.PreviewPropertyDescriptor.handleEditEvent(PreviewPr opertyDescriptor.java:236)
> at
> org.eclipse.birt.report.designer.internal.ui.views.attribute s.widget.PreviewPropertyDescriptor$6.doubleClick(PreviewProp ertyDescriptor.java:190)
> at
> org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:824)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
> at
> org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:822)
> at
> org.eclipse.jface.viewers.StructuredViewer.handleDoubleSelec t(StructuredViewer.java:1113)
> at
> org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1225)
> at
> org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:238)
> at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:235)
> at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:296)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> at
> org.eclipse.birt.report.designer.ui.dialogs.HighlightRuleBui lder.syncViewProperties(HighlightRuleBuilder.java:1279)
> at
> org.eclipse.birt.report.designer.ui.dialogs.HighlightRuleBui lder.createContents(HighlightRuleBuilder.java:514)
> at
> org.eclipse.birt.report.designer.ui.dialogs.HighlightRuleBui lder.open(HighlightRuleBuilder.java:2491)
> at
> org.eclipse.birt.report.designer.internal.ui.views.attribute s.provider.HighlightDescriptorProvider.edit(HighlightDescrip torProvider.java:367)
> ... 37 more
> Best regards,
> Jonas
Previous Topic:How to calculate sum of all childs in a group plus the parent data set
Next Topic:Split column
Current Time: Sat Jul 26 12:59:19 EDT 2025
Powered by FUDForum. Page generated in 0.06673 seconds
