Internal exception with Highlight, 2.6.1 [message #632293] |
Tue, 12 October 2010 09:28  |
I have created some highlights on a crosstab cell:
data["fixhours_Group/priority_Group1/Month"] > 5 && data["priority"] == 'Priority 1' Is True
and 5 similar others. If I try to edit one of them by double-click I get:
An unexpected internal exception occurred. Please see log for detail.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID:org.eclipse.birt.report.designer.ui
Version:2.6.0.v20100531
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:Caused by java.lang.NullPointerException.
Happens in 2.5 too.
Lee
Re: Internal exception with Highlight, 2.6.1 [message #638526 is a reply to message #638411] |
Thu, 11 November 2010 09:55  |
Jonas,
can you open a bug for this?
Jason
On 11/11/2010 4:01 AM, Jonas Esser wrote:
> Hello,
> i have the same problem if i use the following condition:
> BirtComp.compareString(row["FIELD1"], row["FIELD2"]) Is True
> But if I replace "Is True" with "Equal to true" it is working without
> Exception:
> BirtComp.compareString(row["FIELD1"], row["FIELD2"]) Equal to true
> Here the Stacktrace from the eclipse log for the first condition:
> org.eclipse.birt.report.designer.core.runtime.GUIException: Caused by
> at
> org.eclipse.birt.report.designer.core.runtime.GUIException.c reateGUIException(GUIException.java:78)
> at
> org.eclipse.birt.report.designer.internal.ui.util.ExceptionH andler.handle(ExceptionHandler.java:169)
> at
> org.eclipse.birt.report.designer.internal.ui.util.ExceptionH andler.handle(ExceptionHandler.java:150)
> at
> org.eclipse.birt.report.designer.internal.ui.util.ExceptionH andler.handle(ExceptionHandler.java:89)
> at
> org.eclipse.birt.report.designer.ui.util.ExceptionUtil.handl e(ExceptionUtil.java:36)
> at
> org.eclipse.birt.report.designer.internal.ui.views.attribute s.provider.HighlightDescriptorProvider.edit(HighlightDescrip torProvider.java:377)
> at
> org.eclipse.birt.report.designer.internal.ui.views.attribute s.widget.PreviewPropertyDescriptor.handleEditEvent(PreviewPr opertyDescriptor.java:236)
> at
> org.eclipse.birt.report.designer.internal.ui.views.attribute s.widget.PreviewPropertyDescriptor$6.doubleClick(PreviewProp ertyDescriptor.java:190)
> at
> org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:824)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
> at
> org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:822)
> at
> org.eclipse.jface.viewers.StructuredViewer.handleDoubleSelec t(StructuredViewer.java:1113)
> at
> org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1225)
> at
> org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:238)
> at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:235)
> at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:296)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
> at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
> Caused by: java.lang.NullPointerException
> at
> org.eclipse.birt.report.designer.ui.dialogs.HighlightRuleBui lder.syncViewProperties(HighlightRuleBuilder.java:1279)
> at
> org.eclipse.birt.report.designer.ui.dialogs.HighlightRuleBui lder.createContents(HighlightRuleBuilder.java:514)
> at org.eclipse.jface.window.Window.create(Window.java:431)
> at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
> at
> org.eclipse.birt.report.designer.ui.dialogs.HighlightRuleBui lder.open(HighlightRuleBuilder.java:2491)
> at
> org.eclipse.birt.report.designer.internal.ui.views.attribute s.provider.HighlightDescriptorProvider.edit(HighlightDescrip torProvider.java:367)
> ... 37 more
> BIRT Engine OSGi Runtime SDK Feature
> 2.6.1.v20100617a-57B185wFfAqPz0Ef8mBsMkG-0hfS
> BIRT Framework 2.6.1.v20100709a-9iF7A8FGLY4z0pxX3ORrsdrp6JXb
> Best regards,
> Jonas
FUDForum. Page generated in 0.06600 seconds
