Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [MWE2] Overview of existing MWE2 components and other documentation
[MWE2] Overview of existing MWE2 components and other documentation [message #632282] Tue, 12 October 2010 08:23 Go to next message
I'm wondering if there exists documentation about existing workflow
components for MWE2?
I've found so far components of Xtext, Xpand, Xtend and some MWE util
components (e.g., org.eclipse.emf.mwe.utils.Writer). But even for the
last one I haven't found any documentation about its attributes. Do you
know of other components, e.g., for ATL or other M2M- or
M2T-transformation tools?
I'm aware of the following documents:
- MWE2 documentation as part of the Xtext documentation: However, this
contains only a description of MWE2 itself, i.e. its syntax etc.
- http://wiki.eclipse.org/Modeling_Workflow_Engine_(MWE) -- which seems
to little bit abandoned (and most links do not work). Maybe this would
be a good place for a list of existing components.
- the Xtend and Xpand components are documented in the XPand help (using
XML syntax, however the newer MWE2 files as generated by Xtext use
non-XML syntax)
Is there more available?
Cheers
Jens
Re: [MWE2] Overview of existing MWE2 components and other documentation [message #632352 is a reply to message #632282] Tue, 12 October 2010 12:10 Go to previous messageGo to next message
- Open interface IWorkflowComponent
- Press F4 to view the type hierarchy
This reveals all known workflow components in the workspace. The attributes are then available by looking for set/add... methods.
Kind regards,
~Karsten
Re: [MWE2] Overview of existing MWE2 components and other documentation [message #632644 is a reply to message #632282] Wed, 13 October 2010 13:19 Go to previous message
Hi Jens,
I'm not aware of such a compilation. MWE2 ships with some useful library
components. However, as you already pointed out, there may exist other
components, e.g. as part of OCL, ATL or other projects. Those will not
be available in your IDE if you do not have the plug-ins installed (and
indexed by means of the JDT index).
Did you try to google for IWorkflowComponent?
Sebastian
Am 12.10.10 14:23, schrieb Jens v.P.:
> non-XML syntax)
> Cheers
> Jens
Previous Topic:[EMF Store] Querying capabilities
Next Topic:[TEXO] Annotation and XML attribute vs element
Current Time: Wed Jul 23 20:34:48 EDT 2025
Powered by FUDForum. Page generated in 0.19173 seconds
