Home » Modeling » EMF » inheritance from own defined EDataType
inheritance from own defined EDataType [message #631360] Thu, 07 October 2010 04:54 Go to next message
I try to define a inheritance in class A from class B. Class B is a EDataType by my self.
See the class B from the ecore sniped
<eClassifiers xsi:type="ecore:EDataType" name="DefaultClient"
instanceClassName="de.bahntechnik.dd.util.net.http.DefaultClient "
serializable="false"/>
<eClassifiers xsi:type="ecore:EClass" name="OtClientIf"/>
Unfortunately I am not able to define a inheritance in class A from class B. I am using the ecore
diagram to design my model.
Is it not possible to do such kind of inheritance or what do I wrong?
BR, Martin
Re: inheritance from own defined EDataType [message #631368 is a reply to message #631360] Thu, 07 October 2010 05:46 Go to previous messageGo to next message
Hi Martin,
I fear it's only possible to define inheritance between EClasses.
Cheers
/Eike
http://www.esc-net.de
Am 07.10.2010 10:54, schrieb Martin Jacob:
> <eClassifiers xsi:type="ecore:EDataType" name="DefaultClient" instanceClassName="de.bahntechnik.dd.util.net.http.DefaultClient "
> Unfortunately I am not able to define a inheritance in class A from class B. I am using the ecore diagram to design my model.
> BR, Martin
Re: inheritance from own defined EDataType [message #631387 is a reply to message #631368] Thu, 07 October 2010 06:59 Go to previous messageGo to next message
Hi Eike,
thanks for the hint. I defined an EClass as follows:
<eClassifiers xsi:type="ecore:EClass" name="DefaultClient"
instanceClassName="de.bahntechnik.dd.util.net.http.DefaultClient "/>
Now I can use this EClass for inheritance but the generated code implements and not extends the
EClass from above:
public class DefaultClientImpl extends EObjectImpl implements DefaultClient {
How can I generate the code that DefaultClientImpl extends DefaultClient?
Martin
Eike Stepper wrote, On 07.10.2010 11:46:
> Hi Martin,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hi,
>> BR, Martin
Re: inheritance from own defined EDataType [message #631388 is a reply to message #631387] Thu, 07 October 2010 07:25 Go to previous messageGo to next message
Am 07.10.2010 12:59, schrieb Martin Jacob:
> Hi Eike,
> <eClassifiers xsi:type="ecore:EClass" name="DefaultClient" instanceClassName="de.bahntechnik.dd.util.net.http.DefaultClient "/>
> Now I can use this EClass for inheritance but the generated code implements and not extends the EClass from above:
I have no experience with EClasses who's objects are not instances of EObjectImpl ;-(
Cheers
/Eike
> Martin
>> Hi Martin,
>> Cheers
>> /Eike
>>> Hi,
>>> BR, Martin
Re: inheritance from own defined EDataType [message #631435 is a reply to message #631387] Thu, 07 October 2010 09:54 Go to previous messageGo to next message
Martin,
You should set abstract and interface to true on that EClass.
Martin Jacob wrote:
> Hi Eike,
> DefaultClient {
> DefaultClient?
> Martin
>> Hi Martin,
>> Cheers
>> /Eike
>>> Hi,
>>> BR, Martin
Re: inheritance from own defined EDataType [message #632204 is a reply to message #631435] Tue, 12 October 2010 01:58 Go to previous messageGo to next message
Hi Ed,
sorry for late reply but I was busy with other things.
I tried as u suggested and set the EClass to abstract and as interface:
abstract="true" interface="true"/>
From this class I derived class X:
<eClassifiers xsi:type="ecore:EClass" name="X" eSuperTypes="#//DefaultClient"/>
unfortunately the generated code was not able to compile. The problem is as follow in X.java:
public interface X extends EObject, DefaultClient: but DefaultClient is not a interface it is a class
Do u have any suggestion how to extend a existing class with a class in my ecore model?
Martin
Ed Merks wrote, On 07.10.2010 15:54:
> Martin,
> Martin Jacob wrote:
>> Hi Eike,
>> EClass from above:
>> Martin
>>> Hi Martin,
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> BR, Martin
Re: inheritance from own defined EDataType [message #632277 is a reply to message #632204] Tue, 12 October 2010 08:06 Go to previous message
Martin,
EClass instances must implement the EObject/InternalEObject interfaces
which they must do by extending some derivative of BasicEObjectImpl.
Therefore you can't just extend some existing plain old class.
Martin Jacob wrote:
> Hi Ed,
> in my ecore model?
> Martin
>> Martin,
>> Martin Jacob wrote:
>>> Hi Eike,
>>> EClass from above:
>>> DefaultClient {
>>> DefaultClient?
>>> Martin
>>>> Hi Martin,
>>>> Cheers
>>>> /Eike
>>>>> Hi,
>>>>> BR, Martin
Previous Topic:[CDO]LastCommitTime can not be saved
Next Topic:Bidirectional reference
Current Time: Sat Jul 26 03:20:52 EDT 2025
Powered by FUDForum. Page generated in 0.27781 seconds
