Home » Modeling » EMF » [CDO]LastCommitTime can not be saved
[CDO]LastCommitTime can not be saved [message #632192] Tue, 12 October 2010 00:35 Go to next message
DBStore will save some properties to database when it "doDeactivate()". But
when CDO Server is shut down abnormally, the last commit time will not be
saved. This will cause OfflineClone can not sync properly after CDO Server
restart. How to solve this problem?
Re: [CDO]LastCommitTime can not be saved [message #632193 is a reply to message #632192] Tue, 12 October 2010 00:49 Go to previous messageGo to next message
Am 12.10.2010 06:35, schrieb lu.xingxiao:
> Hello,
> DBStore will save some properties to database when it "doDeactivate()". But when CDO Server is shut down abnormally, the last commit time will not be saved. This will cause OfflineClone can not sync properly after CDO Server restart. How to solve this problem?
I thought this problem has been solved right before Helios GA:
316867: Raw replication fails after recovering from non-graceful shutdown
https://bugs.eclipse.org/bugs/show_bug.cgi?id=316867
What version of CDO are you using?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO]LastCommitTime can not be saved [message #632194 is a reply to message #632192] Tue, 12 October 2010 00:53 Go to previous messageGo to next message
> Hello,
Can you try to set a breakpoint here: org.eclipse.emf.cdo.server.internal.db.DBStore.reStart()
And find out if the last lines are executed and what they're doing:
long lastCommitTime = DBUtil.selectMaximumLong(connection, CDODBSchema.COMMIT_INFOS_TIMESTAMP);
setLastCommitTime(lastCommitTime);
long lastNonLocalCommitTime = DBUtil.selectMaximumLong(connection, CDODBSchema.COMMIT_INFOS_TIMESTAMP,
CDOBranch.MAIN_BRANCH_ID + "<=" + CDODBSchema.COMMIT_INFOS_BRANCH);
setLastNonLocalCommitTime(lastNonLocalCommitTime);
Cheers
/Eike
Re: [CDO]LastCommitTime can not be saved [message #632203 is a reply to message #632194] Tue, 12 October 2010 01:38 Go to previous messageGo to next message
Thank you, Eike. I'm using CDO3.0.0v20100614-1654, I will update it.
>> Hello,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO]LastCommitTime can not be saved [message #632232 is a reply to message #632203] Tue, 12 October 2010 04:03 Go to previous message
Am 12.10.2010 07:38, schrieb lu.xingxiao:
Apologies, there was a wrong auto-comment on the bugzilla (as Pascal pointed out)!
Although 3.0 GA was on June 29, the final GA build was already on June 14, one
day before this fix was committed.
Hence this fix was first released with SR1.
Cheers
/Eike
>>> Hello,
>> Cheers
>> /Eike
Previous Topic:Fwd: Re: RCP & EMF Compare
Next Topic:inheritance from own defined EDataType
Current Time: Fri Jul 25 10:25:36 EDT 2025
Powered by FUDForum. Page generated in 0.28891 seconds
