Home » Language IDEs » Java Development Tools (JDT) » How to resolve a referenced type in a compilation unit
How to resolve a referenced type in a compilation unit [message #632056] Mon, 11 October 2010 07:47 Go to next message
I'm trying to find a clean way to resolve a referenced type in a compilation unit.
For example, given the following code :
package com.example.rs;
import javax.persistence.EntityManager;
@Path(CustomerResource.URI_BASE)
public class CustomerResource {
	private final org.slf4j.Logger logger = LoggerFactory.getLogger(CustomerResource.class);
	@PersistenceContext
	private EntityManager entityManager = null;
        public static final String URI_BASE = "/customers";
I would expect the following results :
  • resolveType(entityManager) -> IType(javax.persistence.EntityManager)
  • resolveType(org.slf4j.Logger logger) -> IType(org.slf4j.Logger logger)
  • resolveType(CustomerResource) -> IType(com.example.rs.CustomerResource)
For now, I managed to write a utility method that basically :
  • creates an AST Parser and parses the given IType (here, CustomerResouce)
  • retrieve the imports
  • iterates on the ImportDeclarations to match the Type without the package name (EntityManager, Logger, CustomerResource)
  • Returns the IType based on the fully qualified name
Is there somthing equivalent or better in the Eclipse AST/JDT APIs for such a need ?
Thank you in advance
Xavier
Re: How to resolve a referenced type in a compilation unit [message #632059 is a reply to message #632056] Mon, 11 October 2010 08:14 Go to previous messageGo to next message
Never mind, I found how to resolve my initial problem using a custom ASTVisitor and bindings.
The initial issue was to evaluate a given annotation attribute value on specific Types.
Using an ASTVisitor like this seems to do the underlying job:
	public boolean visit(TypeDeclaration node) {
		for(Object modifier : (List<?>)node.getStructuralProperty(TypeDeclaration.MODIFIERS2_PROPERTY)) {
			if(modifier instanceof Annotation) {
				IAnnotationBinding annotationBinding = ((Annotation)modifier).resolveAnnotationBinding();
				annotationBinding.getAllMemberValuePairs();
Xavier
Re: How to resolve a referenced type in a compilation unit [message #633023 is a reply to message #632059] Fri, 15 October 2010 02:50 Go to previous messageGo to next message
> specific Types. Using an ASTVisitor like this seems to do the underlying
> job:
> @Override
> (List<?> )node.getStructuralProperty(TypeDeclaration.MODIFIERS2_PROPE RTY)) {
It sounds like this might also be a problem you can solve with an
annotation processor. Doing it that way
(javax.lang.annotation.processing.Processor) will mean that you have a
standardized solution that can also run at the command line and that
does not depend on Eclipse.
Re: How to resolve a referenced type in a compilation unit [message #633259 is a reply to message #633023] Fri, 15 October 2010 17:30 Go to previous message
Some really insightful information here. Thanks a lot for sharing. It is well appreciated Smile
Previous Topic:How to cleanly get ICompilationUnit for StorageEditorInput?
Next Topic:Ant build on Run?
Current Time: Fri Jul 18 07:31:46 EDT 2025
Powered by FUDForum. Page generated in 0.07690 seconds
