Home » Eclipse Projects » Rich Client Platform (RCP) » org.mortbay.jetty.* dependencies for the help system
org.mortbay.jetty.* dependencies for the help system [message #631827] Fri, 08 October 2010 19:30 Go to next message
I am trying to set up a help system for my RCP app. I am using 3.5SR2 as my platform.
We have a custom target platform based on the RCP Runtime, Delta pack and EMF (among other things).
Following some docs I read, I added some dependencies for the help system, namely:
org.eclipse.help.ui
org.eclipse.help.webapp
org.eclipse.equinox.http.jetty
This set off a cascade of additional unsatisfied dependencies. Most I was able to get from the Eclipse platform plugins directory; a few others came from the plugins dir of the JEE eclipse version. However, the org.eclipse.equinox.http.jetty plugin has the following dependencies:
org.mortbay.component; version="[6.1.0,7.0.0]"
org.mortbay.jetty; version="[6.1.0,7.0.0]"
org.mortbay.jetty.bio; version="[6.1.0,7.0.0]"
org.mortbay.jetty.handler; version="[6.1.0,7.0.0]"
org.mortbay.jetty.nio; version="[6.1.0,7.0.0]"
org.mortbay.jetty.security; version="[6.1.0,7.0.0]"
org.mortbay.jetty.servlet; version="[6.1.0,7.0.0]"
org.mortbay.log; version="[6.1.0,7.0.0]"
I went to the jetty website and based on the docs it seems odd that the org.eclipse.equinox.http.jetty plugin would depend on org.mortbay.* bundles because the org.eclipse.equinox.* is the new naming convention and the org.mortbay.* is the old convention.
Regardless of that apparent inconsistency, can someone tell me where to get these plugins?
Or have I done this wrong? Is there some other way of setting up a help system in my RCP app that is less involved?
These apparent missing dependencies get reported when I validate my run configuration of my app.
Jon
Re: org.mortbay.jetty.* dependencies for the help system [message #632117 is a reply to message #631827] Mon, 11 October 2010 11:53 Go to previous messageGo to next message
So in doing more digging I found that I was wrong, those aren't actual plugin dependencies, those are package dependencies. I created a new RCP app using the mail template and the default target platform. and then used Lars Vogel's RCP help tutorial and it worked as expected.
By opening the plug-in manifest for the org.eclipse.equinox.http.jetty, I can see the required packages.
If I click on the "show the plug-in dependency hierarchy" link, it shows me where the majority of the packages are getting their dependencies. However, the list I previously posted aren't listed as satisfied nor are these marked as optional.
Have I missed something? These need to be satisfied in order for the app to start and the help to launch, right?
Again, my goal is to add the discreet list of dependencies to my target; unfortunately I can't add the whole SDK to our platform.
Jon
Re: org.mortbay.jetty.* dependencies for the help system [message #632120 is a reply to message #631827] Mon, 11 October 2010 11:58 Go to previous messageGo to next message
Aaaaand the answer is the
org.mortbay.jetty.server_6.1.15.v200905151201.jar
plugin . I basically began opening plugins from the plugin viewer and stumbled on this.
Re: org.mortbay.jetty.* dependencies for the help system [message #632136 is a reply to message #631827] Mon, 11 October 2010 13:11 Go to previous message
For anyone else who is looking, here is the complete list of plugins I had to add to my target platform to get the help working. This is for Galileo (3.5 SR2), so for other platforms the versions may vary:
javax.servlet.jsp_2.0.0.v200806031607.jar
javax.servlet_2.5.0.v200806031605.jar
org.apache.commons.el_1.0.0.v200806031608.jar
org.apache.commons.logging_1.0.4.v201005080501.jar
org.apache.jasper_5.5.17.v200903231320.jar
org.apache.lucene.analysis_1.9.1.v20080530-1600.jar
org.apache.lucene_1.9.1.v20080530-1600.jar
org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800.jar
org.eclipse.equinox.http.registry_1.0.200.v20090520-1800.jar
org.eclipse.equinox.http.servlet_1.0.200.v20090520-1800.jar
org.eclipse.equinox.jsp.jasper.registry_1.0.100.v20090520-18 00.jar
org.eclipse.equinox.jsp.jasper_1.0.200.v20090520-1800.jar
org.eclipse.help.base_3.4.0.v200906111540.jar
org.eclipse.help.ui_3.4.0.v20090528.jar
org.eclipse.help.webapp_3.4.0.v20090429_1800.jar
org.eclipse.osgi.services_3.2.0.v20090520-1800.jar
org.mortbay.jetty.util_6.1.15.v200905182336.jar
Again, this is only in the case where you are building your target platform from scratch. If you use the whole SDK or the default runtime, this is not applicable.
HTH,
Jon
Previous Topic:Remove view Title Image Completly
Next Topic:Extension-point schema 'kind="indentifier" - what's its purpose?
Current Time: Fri Sep 19 05:22:15 EDT 2025
Powered by FUDForum. Page generated in 0.09670 seconds
