Home » Modeling » EMF » [CDO] Import a fragmented model ?
[CDO] Import a fragmented model ? [message #631216] |
Wed, 06 October 2010 11:23  |
I have end-users that share a model with a SCM (e.g SVN) tool.
To be able to work as a team, they fragment the model to limit concurrent accesses on the same model elements to ease merge operations.
We are thinking moving on CDO, and I was thinking importing their model as is.
I've given it a try from the CDO session but when committing the resource that contains an element that is held by the first resource, I get an DanglingReferenceException.
Is there, out of the box (CDO 3), another way to import many resources ?
Stephane.
Re: [CDO] Import a fragmented model ? [message #631232 is a reply to message #631216] |
Wed, 06 October 2010 11:53   |
Hi Stephane,
comments below.
On 06.10.2010 17:23, Stéphane Fournier wrote:
> as is.
I'm not sure if this is what you mean. If I understand you correctly,
you have a model which is distributed among several resources.
CDO can store references to external resources (e.g., XMI files). To do
this, however, the resources must be contained in the same resourceSet.
If this is the case you should be able to commit your resources one by
one and thus migrate your model step by step.
Stefan
Re: [CDO] Import a fragmented model ? [message #631663 is a reply to message #631233] |
Fri, 08 October 2010 08:12   |
Hi Eike,
Sorry for the delay, I was very busy, I've only test your code right now.
It imports all resources with their content but once imported the link
between resources are lost and objects are duplicated.
Le me give you a schema of my input model.
Resource A contains :
- root object A
- contains object B (hosted in resource B), it's just a HREF to
another resource...
- root object A1
- contains object C (hosted in resource C) it's just a HREF to another
resource...
Resource B contains :
- root object B
Resource C contains :
- root object C
When imported in CDO I got 3 resources, great !
But :
CDO Resource A contains:
-root object A
- contains a local copy of B (OID 10).
- contains a local copy of C.
CDO Resource B contains :
- root object B (OID 50)
CDO Resource C contains :
- root object C
If I modify the local copy of B, object B contained in CDO resource B is
not modified. For sure their OID are different ones.
Any idea to fix that ?
Thanks for your help,
Stephane.
On 06/10/2010 17:55, Eike Stepper wrote:
> Hi Stephane,
> There's no way of importing (committing) models with dangling references.
> But you can import multiple resources in one commit operation with some
> code like this:
> Collection<Resource> resourcesToImport = null;
> CDOTransaction transaction = null;
> EcoreUtil.Copier copier = new EcoreUtil.Copier(); // A Copier for all roots
> for (Resource resourceToImport : resourcesToImport)
> Collection<EObject> copiedObjects =
> copier.copyAll(resourceToImport.getContents());
> String targetPath = resourceToImport.getURI().path();
> CDOResource cdoResource = transaction.createResource(targetPath);
> cdoResource.getContents().addAll(copiedObjects);
> copier.copyReferences();
> transaction.commit();
> I haven't tried it. Can you report how it works for you?
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> Am 06.10.2010 17:23, schrieb Stéphane Fournier:
>> Hi,
>> model as is.
>> Stephane.
Re: [CDO] Import a fragmented model ? [message #631673 is a reply to message #631663] |
Fri, 08 October 2010 08:38   |
Hi Stephane,
Can you provide me with a test case for our test framework that demonstrates that? You can use a bugzilla if you want...
Cheers
/Eike
Am 08.10.2010 14:12, schrieb Stephane Fournier:
> Hi Eike,
> It imports all resources with their content but once imported the link between resources are lost and objects are duplicated.
> - root object A
> - contains object B (hosted in resource B), it's just a HREF to another resource...
> - root object A1
> - contains object C (hosted in resource C) it's just a HREF to another resource...
> - root object B
> - root object C
> But :
> -root object A
> - root object C
> If I modify the local copy of B, object B contained in CDO resource B is not modified. For sure their OID are different ones.
> Stephane.
>> Hi Stephane,
>> code like this:
>> Cheers
>> /Eike
>>> Hi,
>>> model as is.
>>> Stephane.
Re: [CDO] Import a fragmented model ? [message #631679 is a reply to message #631673] |
Fri, 08 October 2010 08:56   |
Ok,
For sure I can give you a test case. We need to have a common model to
be able to load the model instance from your side.
Which model would you like me to use ? Is there such a model in CDO
tests, i can reuse to demonstrate that ?
Stephane.
On 08/10/2010 14:38, Eike Stepper wrote:
> Hi Stephane,
> Cheers
> /Eike
>> Hi Eike,
>> - root object A
>> another resource...
>> - root object A1
>> resource...
>> - root object B
>> - root object C
>> But :
>> -root object A
>> - root object C
>> Stephane.
>>> Hi Stephane,
>>> references.
>>> code like this:
>>> roots
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> operations.
>>>> model as is.
>>>> resources ?
>>>> Stephane.
Re: [CDO] Import a fragmented model ? [message #631684 is a reply to message #631679] |
Fri, 08 October 2010 09:22   |
Am 08.10.2010 14:56, schrieb Stephane Fournier:
> Ok,
> For sure I can give you a test case. We need to have a common model to be able to load the model instance from your side.
> Which model would you like me to use ? Is there such a model in CDO tests, i can reuse to demonstrate that ?
Sure, there are severals. You start with something like this:
public class MyTest extends AbstractCDOTest
public void testXyz() throws Exception
CDOSession session = openSession();
CDOTransaction transaction = session.openTransaction();
CDOResource resource = transaction.createResource("/test1");
Supplier supplier = getModel1Factory().createSupplier();
supplier.setName("Stepper");
resource.getContents().add(supplier);
Cheers
/Eike
> Stephane.
>> Hi Stephane,
>> Cheers
>> /Eike
>>> Hi Eike,
>>> - root object A
>>> another resource...
>>> - root object A1
>>> resource...
>>> - root object B
>>> - root object C
>>> But :
>>> -root object A
>>> - root object C
>>> Stephane.
>>>> Hi Stephane,
>>>> references.
>>>> code like this:
>>>> roots
>>>> Cheers
>>>> /Eike
>>>>> Hi,
>>>>> operations.
>>>>> model as is.
>>>>> resources ?
>>>>> Stephane.
Re: [CDO] Import a fragmented model ? [message #631851 is a reply to message #631741] |
Sat, 09 October 2010 01:06   |
Hi Stephane,
Your test case is based on two incorrect assumptions:
1) mainResource.getContents().remove(customer);
This is a no-op because mainResource contains a single Company object, no Customer. Unfortunately the silly Java Collection framework tends to silently ignbore this.
2) secondResource.getContents().add(customer);
This instead removes the customer implicitely from ((Company)mainResource.getContents().get(0)).getCustomers() because the customers reference in Company is a containment reference and the customer can not be contained by two containers at the same time.
It's best to proof such assertions in the code, then it becomes evident immediately. I've updated your test case as follows:
public void testImportControlledModel() throws Exception
Customer customer = getModel1Factory().createCustomer();
customer.setName("Stephane");
customer.setCity("Paris");
Company company = getModel1Factory().createCompany();
company.setName("THALES");
company.getCustomers().add(customer);
ResourceSet resourceSet = new ResourceSetImpl();
Map<String, Object> map = resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap();
map.put("xml", new XMLResourceFactoryImpl());
Resource mainResource = resourceSet.createResource(URI.createURI("main.xml"));
Resource secondResource = resourceSet.createResource(URI.createURI("second.xml"));
mainResource.getContents().add(company);
// At the moment customer is stored in mainResource.
// Remove it from mainResource to put it in secondResource (fake
// Control... EMF action).
boolean removed = mainResource.getContents().remove(customer);
assertEquals(true, removed); // FAILS!!!
// Add it to secondResource.
// At this point, we have 2 resources : mainResource that holds company
// which contains a customer stored in secondResource;
// right ?
assertEquals(customer, secondResource.getContents().get(0));
assertEquals(customer, ((Company)mainResource.getContents().get(0)).getCustomers(). get(0)); // FAILS!!!
// roots
for (Resource resourceToImport : resourceSet.getResources())
Collection<EObject> copiedObjects = copier.copyAll(resourceToImport.getContents());
// Now both resources are imported in the repository.
// Nevertheless, customer object is duplicated. The one held by the
// company is not the one contained directly by the secondResource.
// OIDs are different ones. Modifying the first has no effect on the one
// directly contained by the secondResource.
If I comment out the new assertions the test case passes for me, so I'm still unsure what your problem is about ;-)
Cheers
/Eike
Am 08.10.2010 17:17, schrieb Stephane Fournier:
> Please find attached the test case.
> At the moment, I don't file a bugzilla as I cannot run the test case. My env does not allow me to run it.
> Could you please let me, if you get the issue ?
> Stephane.
>>> Ok,
>> Cheers
>> /Eike
Re: [CDO] Import a fragmented model ? [message #631865 is a reply to message #631851] |
Sat, 09 October 2010 07:27   |
Hi Eike,
I tried to fake the ControlAction provided by EMF.Edit, it seems I failed.
As I told you, I can't run the test case so it is difficult to check if my problem is demonstrated.
On Monday, I will debug the behavior of the ControlAction that seems to run a RemoveCommand + AddCommand, that I tried to fake.
I will create real XML files for the Company, Customer, model from a generic EMF editor to get the 2 files. That's simpler. I will adapt the test case to load these files instead of creating objects.
The relationship between Company and Customer is a containment one, right. Hence a customer can be only contained by one container, right. Nevertheless, through EMF control mechanism the Customer objects can be stored in a different resource from the one that contains the Company. The customer's container is always the Company but its eResource is not null and refers to the second resource.
We will meet us in a week or two , so I would have the opportunity to show you the issue.
Stephane.
[Updated on: Sat, 09 October 2010 07:28] by Moderator
Re: [CDO] Import a fragmented model ? [message #632004 is a reply to message #631865] |
Mon, 11 October 2010 03:53  |
--------------080403050505060200050204
Hi Eike,
I re-generate the java code for model1 meta-model to enable containment
proxies genmodel property.
I've created a dummy model with generic EMF-based editor (see attachment
files).
There is a main model file that contains a company that contains 2
customers. Each one is stored in its own resource second.xml (and
third.xml).
I've updated the test case to load the main.xml rather than creating
objects...
Could you test that and let me know if you reproduce the issue ?
My issue is : when the model is imported in a CDO repo (I got 3 CDO
resources), both customers are duplicated.
Hence dealing with the ones contained by the company do not modify the
object contained by each customer's resource.
Stephane.
On 09/10/2010 13:27, Stéphane Fournier wrote:
> Hi Eike,
> test case to load these file instead of creating objects.
> right. Hence a customer can be only contained by a container, right.
> We will meet us in a week or two ;), so I would have the opportunity to
> show you the issue.
> Stephane.
Content-Type: text/xml;
name="third.xml"
filename="third.xml"
<?xml version="1.0" encoding="ASCII"?>
<model1:Customer xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:model1="http://www.eclipse.org/emf/CDO/tests/model1/1.0.0" name="Eike" city="Berlin"/>
name="main.xml"
filename="main.xml"
<model1:Company xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:model1="http://www.eclipse.org/emf/CDO/tests/model1/1.0.0" name="Acme">
<customers href="second.xml#/"/>
<customers href="third.xml#/"/>
</model1:Company>
name="second.xml"
filename="second.xml"
<model1:Customer xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:model1="http://www.eclipse.org/emf/CDO/tests/model1/1.0.0" name="Stephane" city="Paris"/>
name="MyTest.java"
filename="MyTest.java"
LyoqDQogKiANCiAqLw0KcGFja2FnZSBvcmcuY2RvLnRlc3Q7DQoNCmltcG9y dCBqYXZhLnV0
aWwuQ29sbGVjdGlvbjsNCg0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5jZG8u ZXJlc291cmNl
LkNET1Jlc291cmNlOw0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5jZG8uc2Vz c2lvbi5DRE9T
ZXNzaW9uOw0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5jZG8udGVzdHMuQWJz dHJhY3RDRE9U
ZXN0Ow0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5jZG8udHJhbnNhY3Rpb24u Q0RPVHJhbnNh
Y3Rpb247DQppbXBvcnQgb3JnLmVjbGlwc2UuZW1mLmNvbW1vbi51aS5kaWFs b2dzLlJlc291
cmNlRGlhbG9nOw0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5lY29yZS5FT2Jq ZWN0Ow0KaW1w
b3J0IG9yZy5lY2xpcHNlLmVtZi5lY29yZS5yZXNvdXJjZS5SZXNvdXJjZTsN CmltcG9ydCBv
cmcuZWNsaXBzZS5lbWYuZWNvcmUucmVzb3VyY2UuUmVzb3VyY2VTZXQ7DQpp bXBvcnQgb3Jn
LmVjbGlwc2UuZW1mLmVjb3JlLnJlc291cmNlLmltcGwuUmVzb3VyY2VTZXRJ bXBsOw0KaW1w
b3J0IG9yZy5lY2xpcHNlLmVtZi5lY29yZS51dGlsLkVjb3JlVXRpbDsNCmlt cG9ydCBvcmcu
ZWNsaXBzZS5qZmFjZS53aW5kb3cuV2luZG93Ow0KaW1wb3J0IG9yZy5lY2xp cHNlLnN3dC5T
V1Q7DQppbXBvcnQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuU2hlbGw7DQoN Ci8qKg0KICog
QGF1dGhvciBTdGVwaGFuZSBGb3Vybmllcg0KICovDQpwdWJsaWMgY2xhc3Mg TXlUZXN0IGV4
dGVuZHMgQWJzdHJhY3RDRE9UZXN0IHsNCglwdWJsaWMgdm9pZCB0ZXN0SW1w b3J0Q29udHJv
bGxlZE1vZGVsKCkgdGhyb3dzIEV4Y2VwdGlvbiB7DQoJCVJlc291cmNlU2V0 IHJlc291cmNl
U2V0ID0gbmV3IFJlc291cmNlU2V0SW1wbCgpOw0KDQoJCVJlc291cmNlRGlh bG9nIGRpYWxv
ZyA9IG5ldyBSZXNvdXJjZURpYWxvZyhuZXcgU2hlbGwoKSwNCgkJCQkiU2Vs ZWN0IGEgbW9k
ZWwiLCBTV1QuT1BFTik7DQoJCWlmIChXaW5kb3cuT0sgIT0gZGlhbG9nLm9w ZW4oKSkgew0K
CQkJcmV0dXJuOw0KCQl9DQoJCS8vIENyZWF0ZSBhIHN0YW5kYXJkIEVNRiBy ZXNvdXJjZQ0K
CQlSZXNvdXJjZSBtYWluUmVzb3VyY2UgPSByZXNvdXJjZVNldC5nZXRSZXNv dXJjZSgNCgkJ
CQlkaWFsb2cuZ2V0VVJJcygpLmdldCgwKSwgdHJ1ZSk7DQoJCS8vIE1ha2Ug c3VyZSBhbGwg
ZGVwZW5kZW50IHJlc291cmNlcyBhcmUgbG9hZGVkLg0KCQlFY29yZVV0aWwu cmVzb2x2ZUFs
bChtYWluUmVzb3VyY2UpOw0KCQlFY29yZVV0aWwucmVzb2x2ZUFsbChyZXNv dXJjZVNldCk7
DQoJCQ0KCQlDRE9TZXNzaW9uIHNlc3Npb24gPSBvcGVuU2Vzc2lvbigpOw0K CQlDRE9UcmFu
c2FjdGlvbiB0cmFuc2FjdGlvbiA9IHNlc3Npb24ub3BlblRyYW5zYWN0aW9u KCk7DQoNCgkJ
RWNvcmVVdGlsLkNvcGllciBjb3BpZXIgPSBuZXcgRWNvcmVVdGlsLkNvcGll cigpOyAvLyBB
IENvcGllciBmb3IgYWxsDQoJCQkJCQkJCQkJCQkJCQkvLyByb290cw0KCQlm b3IgKFJlc291
cmNlIHJlc291cmNlVG9JbXBvcnQgOiByZXNvdXJjZVNldC5nZXRSZXNvdXJj ZXMoKSkgew0K
CQkJLy8gT25seSBpbXBvcnQgb3VyIHhtbCBmaWxlcy4NCgkJCWlmIChyZXNv dXJjZVRvSW1w
b3J0LmdldFVSSSgpLnBhdGgoKS5lbmRzV2l0aCgieG1sIikpIHsNCgkJCQlD b2xsZWN0aW9u
PEVPYmplY3Q+IGNvcGllZE9iamVjdHMgPSBjb3BpZXINCgkJCQkJCS5jb3B5 QWxsKHJlc291
cmNlVG9JbXBvcnQuZ2V0Q29udGVudHMoKSk7DQoJCQkJU3RyaW5nIHRhcmdl dFBhdGggPSBy
ZXNvdXJjZVRvSW1wb3J0LmdldFVSSSgpLnBhdGgoKTsNCgkJCQlDRE9SZXNv dXJjZSBjZG9S
ZXNvdXJjZSA9IHRyYW5zYWN0aW9uDQoJCQkJCQkuY3JlYXRlUmVzb3VyY2Uo dGFyZ2V0UGF0
aCk7DQoJCQkJY2RvUmVzb3VyY2UuZ2V0Q29udGVudHMoKS5hZGRBbGwoY29w aWVkT2JqZWN0
cyk7DQoJCQl9DQoJCX0NCg0KCQljb3BpZXIuY29weVJlZmVyZW5jZXMoKTsN CgkJdHJhbnNh
Y3Rpb24uY29tbWl0KCk7DQoJCS8vIE5vdyBib3RoIHJlc291cmNlcyBhcmUg aW1wb3J0ZWQg
aW4gdGhlIHJlcG9zaXRvcnkuDQoJCS8vIE5ldmVydGhlbGVzcywgY3VzdG9t ZXIgb2JqZWN0
IGlzIGR1cGxpY2F0ZWQuIFRoZSBvbmUgaGVsZCBieSB0aGUNCgkJLy8gY29t cGFueSBpcyBu
b3QgdGhlIG9uZSBjb250YWluZWQgZGlyZWN0bHkgYnkgdGhlIHNlY29uZFJl c291cmNlLg0K
CQkvLyBPSURzIGFyZSBkaWZmZXJlbnQgb25lcy4gTW9kaWZ5aW5nIHRoZSBm aXJzdCBoYXMg
bm8gZWZmZWN0IG9uIHRoZSBvbmUNCgkJLy8gZGlyZWN0bHkgY29udGFpbmVk IGJ5IHRoZSBz
ZWNvbmRSZXNvdXJjZS4NCgl9DQp9DQo=
--------------080403050505060200050204--
Current Time: Fri Jul 25 22:14:56 EDT 2025
Powered by FUDForum. Page generated in 0.25622 seconds
