Home » Eclipse Projects » Virgo » NoClassDefFoundError on Virgo Web Server M5
NoClassDefFoundError on Virgo Web Server M5 [message #631598] Fri, 08 October 2010 03:26 Go to next message
My bundle publish "javax.transaction.UserTransaction" using Atomikos 3.6.5. It works well on Virgo Web Server M4, but it failed on M5.
Is it a known issue due to the directory layout change in M5?
[2010-10-08 15:10:19.694] start-signalling-3 org.eclipse.virgo.medic.eventlog.default DE0006E Start failed for bundle 'org.planner.infrastructure.jtatransaction' version '1.0.0.201009211243'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'userTransactionService' defined in URL [ bundleentry://81.fwk12296027/META-INF/spring/module-context. xml]: Invocation of init method failed; nested exception is java.lang.NoClassDefFoundError: javax/transaction/TransactionManager
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.initializeBean(AbstractAutowireCapableBeanF actory.java:1401)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFac tory.java:512)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:450)
at org.springframework.beans.factory.support.AbstractBeanFactor y$1.getObject(AbstractBeanFactory.java:290)
at org.springframework.beans.factory.support.DefaultSingletonBe anRegistry.getSingleton(DefaultSingletonBeanRegistry.java:22 2)
at org.springframework.beans.factory.support.AbstractBeanFactor y.doGetBean(AbstractBeanFactory.java:287)
at org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:189)
at org.springframework.beans.factory.support.DefaultListableBea nFactory.preInstantiateSingletons(DefaultListableBeanFactory .java:557)
at org.springframework.context.support.AbstractApplicationConte xt.finishBeanFactoryInitialization(AbstractApplicationContex t.java:842)
at org.springframework.osgi.context.support.AbstractDelegatedEx ecutionApplicationContext.access$1600(AbstractDelegatedExecu tionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedEx ecutionApplicationContext$4.run(AbstractDelegatedExecutionAp plicationContext.java:355)
at org.springframework.osgi.util.internal.PrivilegedUtils.execu teWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedEx ecutionApplicationContext.completeRefresh(AbstractDelegatedE xecutionApplicationContext.java:320)
at org.springframework.osgi.extender.internal.dependencies.star tup.DependencyWaiterApplicationContextExecutor$CompleteRefre shTask.run(DependencyWaiterApplicationContextExecutor.java:1 32)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExec utor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.NoClassDefFoundError: javax/transaction/TransactionManager
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
at java.lang.Class.getMethod0(Class.java:2670)
at java.lang.Class.getMethod(Class.java:1603)
at org.springframework.beans.BeanUtils.findMethod(BeanUtils.jav a:162)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapa bleBeanFactory.java:1483)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.invokeInitMethods(AbstractAutowireCapableBe anFactory.java:1468)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.initializeBean(AbstractAutowireCapableBeanF actory.java:1398)
... 17 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoun dException: javax.transaction.TransactionManager in KernelBundleClassLoader: [bundle=com.atomikos.transactions-api_3.6.5]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.loadClass(KernelBundleClassLoader.java:139)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 25 common frames omitted
Caused by: java.lang.ClassNotFoundException: javax.transaction.TransactionManager
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:460)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.loadClass(KernelBundleClassLoader.java:135)
... 26 common frames omitted
Re: NoClassDefFoundError on Virgo Web Server M5 [message #631625 is a reply to message #631598] Fri, 08 October 2010 04:59 Go to previous messageGo to next message
M05 removed the javax.transaction bundle from the kernel, but it is in the web server. If you are running the web server, this is unexpected and you should raise a bug. If you are running the kernel, you need to add the bundle to repository/usr.
Please note that M06 is built and will be publicised later today. The only change is to revert the directory layout changes which solves a tooling problem but which shouldn't make any difference to your problem.
Re: NoClassDefFoundError on Virgo Web Server M5 [message #632243 is a reply to message #631625] Tue, 12 October 2010 05:19 Go to previous message
The issue is resolved. see https://bugs.eclipse.org/bugs/show_bug.cgi?id=327383
Previous Topic:GreenPages solution doesn't run on Virgo web server M06
Next Topic:Eclipse Virgo: the ideal OSGi server runtime?
Current Time: Wed Nov 05 03:10:28 EST 2025
Powered by FUDForum. Page generated in 0.03052 seconds
