Home » Modeling » Papyrus » Import model libraries and external profiles?(Import model libraries and external profiles?)
Import model libraries and external profiles? [message #631508] Thu, 07 October 2010 15:00 Go to next message
The very first two things I tried to do in Papyrus I couldn't do without manually editing the xmi.
I wanted to import an existing model library (i.e. JavaPrimitiveTypes) into a new model, there's no context menu item or dialog, or help on that topic. I'm used to Rational Software Modeler (context menu -> Import Model Library). I can create a new Papyrus model with the UMLPrimitiveTypes imported (standard model template) but that's it.
I also wanted to import an existing profile from the file system (profile does not exist in the workspace). We use maven and source control to update our profiles, and want to reference them in the model by pathmap, something like pathmap://M2_REPO/profileLocation. I can only import profiles that have been deployed to Eclipse or that exist in the workspace. I would want to select a profile from the file system and have Papyrus recognize that the directory location corresponds to an existing PATHMAP value (in preferences) and use that pathmap variable.
Re: Import model libraries and external profiles? [message #631599 is a reply to message #631508] Fri, 08 October 2010 03:33 Go to previous messageGo to next message
The import fucntionality has been done only few days Very Happy So I will be ok for the next release.
You idea of a pathmap for repository of profile or model is really interesting. I will discuss with my collegues in order to create a task.
Patrick
Re: Import model libraries and external profiles? [message #631610 is a reply to message #631508] Fri, 08 October 2010 04:10 Go to previous messageGo to next message
I have added a task thanks to remarks:
327307: [Papyrus preferences] add a model repository pathmap in the preference
https://bugs.eclipse.org/bugs/show_bug.cgi?id=327307
Re: Import model libraries and external profiles? [message #640626 is a reply to message #631610] Mon, 22 November 2010 11:10 Go to previous messageGo to next message
Sorry Patrick,
Do you mean is it not possible to relate two different models (I mean papyrus model not diagrams).
In this case are you sure it will be added in the next release? When will it be available?
I apologize for these questions but I am wondering about the possibility to adopt Papyrus for a quite big project and I may need to justify this choice with my collegues or at least provide reasonable explanation for those features which are not available.
Thank you in advance
Andrea
Re: Import model libraries and external profiles? [message #642657 is a reply to message #640626] Thu, 02 December 2010 03:46 Go to previous message
Hi Andrea,
Yes, it will be added in next release, which should be in 2-3 weeks. It is already available in the nightly builds of Papyrus.
Rémi
Previous Topic:Bug in drop comment?
Next Topic:Problem with Papyrus sources
Current Time: Mon Jul 21 06:13:54 EDT 2025
Powered by FUDForum. Page generated in 0.49970 seconds
