[CDO] Is it possible to implement ReadAccess and WriteAccess handlers in one class? [message #631170] |
Wed, 06 October 2010 09:03  |
while experimenting with my experimental CDO server I've found interesting thing. I'm using CDO code provided by Eclipse 3.6 Helios release. I'm trying to attempt implementing one access handler class for both read and write access handlers functionality. So my access handler class implements both IRepository.WriteAccessHandler, IRepository.ReadAccessHandler interfaces. What's strange is that WriteAccess handler methods are not called on my handler, although it's correctly registered and I work with transactions on the repository (it's reader functionality is well called). I also see debug output written into log from my debug write access handler which is registered before this handler. Even the more funny thing is that once I modify the handler in a way it does not implement IRepository.ReadAccessHandler interfaces then suddenly the CDO core upcalls its WriteAccess handler methods well. My guess is that this is an issue somewhere in CDO core, but still I'd like to be sure I have not made mistake anywhere nor made a bad assumption that I'm allowed to implement one access handler class for both reader and writer access handlers.
Karel
FUDForum. Page generated in 0.25994 seconds
