Home » Modeling » UML2 » How to add child nodes using the reflective API of EMF?(How to add child nodes using the reflective API of EMF?)
How to add child nodes using the reflective API of EMF? [message #630716] Mon, 04 October 2010 12:41 Go to next message
Greetings!
I am able to add nodes to an EMF model generated from XSD:
EPackage ep = poClass.getEPackage();
EClass ctNew = (EClass) ep.getEClassifier("ChangeType");
EObject ctObject = ep.getEFactoryInstance().create(ctNew);
ctObject.eSet(ctObject.eClass().getEStructuralFeature("comment "), "...");
I am also able to add a node to a single-valued feature:
EClass cltNew = (EClass) ep.getEClassifier("ChangeLogType");
clt = ep.getEFactoryInstance().create(cltNew);
po.eSet(poClass.getEStructuralFeature("changeLog"), clt);
I can also obtain the list of change entries under the many-values change node:
EList<EObject> changes = clt.eClass().getEStructuralFeature("change").eContents();
Here is my problem:
changes.add(ctObject);
gives
Caused by: java.lang.UnsupportedOperationException
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.add(EContentsEList.java:779)
at java.util.AbstractSequentialList.add(Unknown Source)
at java.util.AbstractList.add(Unknown Source)
which I had planned to use as follows:
clt.eSet(clt.eClass().getEStructuralFeature("changeType"), changes);
Is there a way to add child nodes using the reflective API of EMF?
I need to avoid using specific types of the generated model in this section of code, since this code should be usable by multiple separate generated models.
Thanks in advance for any advice.
Adrian
Re: How to add child nodes using the reflective API of EMF? [message #630923 is a reply to message #630716] Tue, 05 October 2010 11:01 Go to previous messageGo to next message
Adrian,
Comments below.
Adrian wrote:
> Greetings!
> change node:
This list is a read only view of the containment of the changes
structure feature itself. That can't possibly be something you'd want
to modify.
> Here is my problem:
> gives
Use eGet to get a list and then modify that list directly.
> generated models.
> Adrian
Re: How to add child nodes using the reflective API of EMF? [message #631176 is a reply to message #630923] Wed, 06 October 2010 09:22 Go to previous messageGo to next message
Thanks for your help, Ed!
Following code works now, but gives me the ClassCastException shown below.
Would you have one more hint how I avoid that exception?
Thanks!
Adrian
EStructuralFeature cltFeature = poClass.getEStructuralFeature("changeLog");
EList<Object> changes = (EList<Object>) clt.eGet(clt.eClass().getEStructuralFeature("change"), true);
// FIXME causes ClassCast Exception, but adding a change actually works
clt.eSet(cltFeature, changes);
Caused by: java.lang.ClassCastException: org.eclipse.emf.ecore.util.FeatureMapUtil$FeatureEList cannot be cast to org.eclipse.emf.ecore.util.FeatureMap$Internal$Wrapper
at org.eclipse.emf.ecore.util.BasicFeatureMap.set(BasicFeatureM ap.java:2564)
at my.package.path.impl.ChangeLogTypeImpl.eSet(ChangeLogTypeImp l.java:136)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1081)
Re: How to add child nodes using the reflective API of EMF? [message #631304 is a reply to message #631176] Wed, 06 October 2010 18:11 Go to previous messageGo to next message
Adrian,
Comments below.
> below.
> Thanks!
> Adrian
You're already directly editing the state of the object
It's of course hard to give advice without knowing more about the model...
> ap.java:2564)
> l.java:136)
> tImpl.java:1081)
Re: How to add child nodes using the reflective API of EMF? [message #631428 is a reply to message #631304] Thu, 07 October 2010 10:16 Go to previous message
Thanks for your second followup, Ed!
I got this figured out now.
Instead of
I only need
((EList<EObject>) clt.eGet(clt.eClass().getEStructuralFeature("change"), true)).add(ctObject);
to add the ctObject node as an additional child at the end of the "change" feature list.
This works perfectly now.
Previously I incorrectly tried to eSet the "changeLog" parent node feature to the list of changes.
Thanks again,
Adrian
Previous Topic:modeling n-ary association
Next Topic:HOW to register UML resources?
Current Time: Sun Jul 27 03:43:11 EDT 2025
Powered by FUDForum. Page generated in 0.08653 seconds
