Home » Eclipse Projects » Rich Client Platform (RCP) » org.eclipse.ant.core.antRunner application differences between 3.4.1 and 3.6.1
org.eclipse.ant.core.antRunner application differences between 3.4.1 and 3.6.1 [message #630171] Thu, 30 September 2010 17:15 Go to next message
Our project is attempting to upgrade from 3.4.1 to 3.6.1 and we used to automate our build process using the org.eclipse.ant.core.antRunner application. This build process in 3.4.1 used to generate a binary executable that you would run to launch the application. This executable does not get generated when ran in 3.6.1. Everything runs the same and generates the appropriate zip files with the plugins and features and what not but it is missing the executable to run the app. Just wondering if anyone knew what was up with that.
Max
Re: org.eclipse.ant.core.antRunner application differences between 3.4.1 and 3.6.1 [message #630936 is a reply to message #630171] Tue, 05 October 2010 10:42 Go to previous messageGo to next message
You should open a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=PDE& component=Build
Something that builds in 3.4.x should still build in 3.6.x. That being
said, there have been a number of changes, especially around build, p2,
runnable repos, etc.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: org.eclipse.ant.core.antRunner application differences between 3.4.1 and 3.6.1 [message #630947 is a reply to message #630936] Tue, 05 October 2010 11:47 Go to previous message
Thanks for the reply, turns out it was I didn't have the delta pack installed. Not sure why that wouldn't come with classic eclipse installation but that ended up solving my issue.
Max
Previous Topic:How to load icons?
Next Topic:[PDE] Export fails on 3.6.1, upgraded application hangs
Current Time: Sun Jul 27 08:19:35 EDT 2025
Powered by FUDForum. Page generated in 0.06300 seconds
