Home » Archived » BIRT » Zoom capability(Zoom capability)
Zoom capability [message #630642] Mon, 04 October 2010 09:25 Go to next message
I am evaluating BIRT charts for our application, specifically zoom functionality.
1. I wanted to know if zoom in , zoom out is possible without explicitly changing the dataset . Does BIRT handle the dataset refresh if I just change the scale or do I need to update the dataset and pass it to the chart each time I rescale?
2.And how about the dataset refresh for Drill down functionality?
3. Does the chart API have support to
a.export the chart object to PDF
b.Print the chart object
If not what options would I have for Export/Print.
Thanks in advance
Re: Zoom capability [message #630712 is a reply to message #630642] Mon, 04 October 2010 12:30 Go to previous messageGo to next message
Are you using charts as part of a BIRT report or by just the Chart
Engine API. If you are using the api you should be able to rescale and
then re-run the chart. You can also do this in a report that contains a
chart using report parameters (if you need an example let me know). The
chart engine supports rendering to PDF as well. If you use the Birt
Viewer you can export the chart to pdf out of the box.
Jason
On 10/4/2010 9:25 AM, asadanandan@axiomainc.com wrote:
> Hello,
> functionality. 1. I wanted to know if zoom in , zoom out is possible
> 3. Does the chart API have support to a.export the chart object to PDF
> Thanks in advance
Re: Zoom capability [message #631261 is a reply to message #630712] Wed, 06 October 2010 13:54 Go to previous messageGo to next message
I am using just the Chart Engine API. Yes would you be able to give me an example? I am using it in SWT.
Would you also have an example to export the chart to PDF using the API?
Re: Zoom capability [message #631263 is a reply to message #630712] Wed, 06 October 2010 14:01 Go to previous messageGo to next message
No Message Body
Re: Zoom capability [message #631291 is a reply to message #631261] Wed, 06 October 2010 15:55 Go to previous messageGo to next message
Here is a snippet to use the pdf output for the chart engine api.
Make sure you have this
org.eclipse.birt.chart.device.pdf_2.5.1.v20090625 plugin in your plugins
Jason
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.image.BufferedImage;
import org.eclipse.birt.chart.api.ChartEngine;
import org.eclipse.birt.chart.device.EmptyUpdateNotifier;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.device.IDisplayServer;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.IGenerator;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.ActionType;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LegendItemType;
import org.eclipse.birt.chart.model.attribute.Position;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.TriggerCondition;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionI mpl;
import org.eclipse.birt.chart.model.attribute.impl.TooltipValueImpl ;
import org.eclipse.birt.chart.model.attribute.impl.URLValueImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.BaseSampleData;
import org.eclipse.birt.chart.model.data.DataFactory;
import org.eclipse.birt.chart.model.data.NumberDataSet;
import org.eclipse.birt.chart.model.data.OrthogonalSampleData;
import org.eclipse.birt.chart.model.data.SampleData;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.TextDataSet;
import org.eclipse.birt.chart.model.data.Trigger;
import org.eclipse.birt.chart.model.data.impl.ActionImpl;
import org.eclipse.birt.chart.model.data.impl.NumberDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.data.impl.TextDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.TriggerImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.core.framework.PlatformConfig;
//import org.eclipse.swt.dnd.Clipboard;
//import org.eclipse.swt.widgets.Display;
* Test decription:
* </p>
* Chart script: BeforeDrawLegendItem()
* </p>
public class StandaloneChartPDF {
private static String OUTPUT = "output/Standalone.pdf"; //$NON-NLS-1$
* Comment for <code>serialVersionUID</code>
private static final long serialVersionUID = 1L;
* A chart model instance
private Chart cm = null;
* The swing rendering device
private IDeviceRenderer dRenderer = null;
private IDisplayServer dServer = null;
private GeneratedChartState gcs = null;
* execute application
* @param args
new StandaloneChartPDF();
System.out.println("Finished");
* Constructor
public StandaloneChartPDF() {
PlatformConfig pf = new PlatformConfig();
pf.setBIRTHome("C:/birt/birt-runtime-2_5_1/birt-runtime-2_5_1/ReportEngine ");
ChartEngine ce = ChartEngine.instance(pf);
//Returns a singleton instance of the Generator
IGenerator gr = ce.getGenerator();
//make sure to org.eclipse.birt.chart.device.pdf_2.5.1.v20090625 in
your plugins
try {
//device renderers for dv.SWT, dv.PNG, dv.JPG
//dv.PDF, dv.SVG, dv.SWING, dv.PNG24, div.BMP
dRenderer = ce.getRenderer("dv.PDF");
dServer = dRenderer.getDisplayServer();
} catch (Exception ex) {
ex.printStackTrace();
cm = StandaloneChart.createStackedBar();
BufferedImage img = new BufferedImage(600, 600,
BufferedImage.TYPE_INT_ARGB);
Graphics g = img.getGraphics();
Graphics2D g2d = (Graphics2D) g;
//Look at IDeviceRenderer.java for all properties
//like DPI_RESOLUTION
//FILE_IDENTIFIER
//FORMAT_IDENTIFIER
//UPDATE_NOTIFIER
dRenderer.setProperty(IDeviceRenderer.GRAPHICS_CONTEXT, g2d);
dRenderer.setProperty(IDeviceRenderer.FILE_IDENTIFIER, OUTPUT);
//$NON-NLS-1$
//Set the bounds for the entire chart
Bounds bo = BoundsImpl.create(0, 0, 600, 600);
bo.scale(72d / dRenderer.getDisplayServer().getDpiResolution());
try {
gcs = gr.build(dServer, cm, bo, null, null, null);
//gcs.getRunTimeContext().setActionRenderer( new MyActionRenderer());
dRenderer.setProperty(IDeviceRenderer.UPDATE_NOTIFIER,
new EmptyUpdateNotifier(cm, gcs.getChartModel()));
gr.render(dRenderer, gcs);
} catch (Exception e) {
e.printStackTrace();
public static final Chart createStackedBar()
ChartWithAxes cwaBar = ChartWithAxesImpl.create();
cwaBar.setType("Bar Chart"); //$NON-NLS-1$
cwaBar.setSubType("Stacked"); //$NON-NLS-1$
// Plot
cwaBar.getBlock().setBackground(ColorDefinitionImpl.WHITE()) ;
cwaBar.getBlock().getOutline().setVisible(true);
Plot p = cwaBar.getPlot();
p.getClientArea().setBackground(ColorDefinitionImpl.create(2 55,
255,
225));
// Title
cwaBar.getTitle()
.getLabel()
.getCaption()
.setValue("Stacked Bar Chart"); //$NON-NLS-1$
// Legend
Legend lg = cwaBar.getLegend();
lg.setItemType(LegendItemType.CATEGORIES_LITERAL);
//Add Script
cwaBar
.setScript("function beforeGeneration( cm, icsc )"
+ " {importPackage(Packages.org.eclipse.birt.chart.model.attribu te); "
importPackage(Packages.org.eclipse.birt.chart.model.attribut e.impl); "
+ " cm.getLegend().getOutline( ).setStyle(
LineStyle.DASH_DOTTED_LITERAL );"
+ " cm.getLegend().getOutline( ).setColor(
ColorDefinitionImpl.GREEN() );"
+ " cm.getLegend().getOutline( ).setVisible( true );} ");
// X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes()[0];
xAxisPrimary.setType(AxisType.TEXT_LITERAL);
xAxisPrimary.getMajorGrid().setTickStyle(TickStyle.BELOW_LIT ERAL);
xAxisPrimary.getOrigin().setType(IntersectionType.MIN_LITERA L);
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis(xAxisPrimary);
yAxisPrimary.getMajorGrid().setTickStyle(TickStyle.LEFT_LITE RAL);
yAxisPrimary.setType(AxisType.LINEAR_LITERAL);
yAxisPrimary.setLabelPosition(Position.RIGHT_LITERAL);
yAxisPrimary.getLabel().getCaption().getFont().setRotation(4 5);
// Data Set
TextDataSet categoryValues = TextDataSetImpl.create(new String[] {
"Item 1a", "Item 2", "Item 3", "Item 4", "Item 5" }); //$NON-NLS-1$
//$NON-NLS-2$ //$NON-NLS-3$ //$NON-NLS-4$ //$NON-NLS-5$
NumberDataSet orthoValues1 = NumberDataSetImpl.create(new double[] {
25, 35, 15, 5, 20
NumberDataSet orthoValues2 = NumberDataSetImpl.create(new double[] {
5, 10, 25, 10, 5
SampleData sd = DataFactory.eINSTANCE.createSampleData();
BaseSampleData sdBase = DataFactory.eINSTANCE.createBaseSampleData();
sdBase.setDataSetRepresentation("");//$NON-NLS-1$
sd.getBaseSampleData().add(sdBase);
OrthogonalSampleData sdOrthogonal1 = DataFactory.eINSTANCE
.createOrthogonalSampleData();
sdOrthogonal1.setDataSetRepresentation("");//$NON-NLS-1$
sdOrthogonal1.setSeriesDefinitionIndex(0);
sd.getOrthogonalSampleData().add(sdOrthogonal1);
OrthogonalSampleData sdOrthogonal2 = DataFactory.eINSTANCE
sdOrthogonal2.setDataSetRepresentation("");//$NON-NLS-1$
sdOrthogonal2.setSeriesDefinitionIndex(1);
sd.getOrthogonalSampleData().add(sdOrthogonal2);
cwaBar.setSampleData(sd);
// X-Series
Series seCategory = SeriesImpl.create();
seCategory.setDataSet(categoryValues);
SeriesDefinition sdX = SeriesDefinitionImpl.create();
xAxisPrimary.getSeriesDefinitions().add(sdX);
sdX.getSeries().add(seCategory);
sdX.getSeriesPalette().shift(0);
// Y-Series
BarSeries bs1 = (BarSeries) BarSeriesImpl.create();
bs1.setDataSet(orthoValues1);
bs1.setStacked(true);
bs1.getLabel().setVisible(true);
bs1.setLabelPosition(Position.INSIDE_LITERAL);
bs1.setRiserOutline(ColorDefinitionImpl.TRANSPARENT());
BarSeries bs2 = (BarSeries) BarSeriesImpl.create();
bs2.setDataSet(orthoValues2);
bs2.setStacked(true);
bs2.setRiserOutline(ColorDefinitionImpl.TRANSPARENT());
bs2.getLabel().setVisible(true);
bs2.setLabelPosition(Position.INSIDE_LITERAL);
Trigger tr1 = TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create(200, "test + dph.getDisplayValue()")));
Trigger tr2 = TriggerImpl.create(TriggerCondition.ONCLICK_LITERAL,
ActionImpl.create(ActionType.URL_REDIRECT_LITERAL, URLValueImpl
.create("https://www.google.com", null, "component",
"value", "")));
//Trigger tr3 =
TooltipValueImpl.create(200, null)));
bs1.getTriggers().add(tr1);
bs1.getTriggers().add(tr2);
SeriesDefinition sdY = SeriesDefinitionImpl.create();
sdY.getSeriesPalette().shift(0);
yAxisPrimary.getSeriesDefinitions().add(sdY);
sdY.getSeries().add(bs1);
sdY.getSeries().add(bs2);
return cwaBar;
> Thanks
Re: Zoom capability [message #631303 is a reply to message #631291] Wed, 06 October 2010 18:03 Go to previous messageGo to next message
Jason,
I am getting the following exception when I run this. I have org.eclipse.birt.chart.device.extension and
org.eclipse.birt.chart.engine.extension
in my plugins.
Caused by: org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.birt.chart.device.pdf" was unable to instantiate class "org.eclipse.birt.chart.device.pdf.PDFRendererImpl".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:188)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:904)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 55)
at org.eclipse.birt.core.framework.eclipse.EclipseConfiguration Element.createExecutableExtension(EclipseConfigurationElemen t.java:35)
... 32 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/birt/chart/device/util/ICharacterEncoderAdapter
at org.eclipse.birt.chart.device.pdf.PDFRendererImpl.init(PDFRe ndererImpl.java:61)
at org.eclipse.birt.chart.device.swing.SwingRendererImpl.<init >(SwingRendererImpl.java:126)
Re: Zoom capability [message #631409 is a reply to message #631303] Thu, 07 October 2010 09:30 Go to previous messageGo to next message
Did you copy org.eclipse.birt.chart.device.pdf_2.5.1.v20090625 from the
chart engine download to your birt runtime
Jason
On 10/6/2010 6:03 PM, asadanandan@axiomainc.com wrote:
> Jason,
> in my plugins.
> ... 32 more
> ndererImpl.java:61)
Re: Zoom capability [message #631412 is a reply to message #631409] Thu, 07 October 2010 09:39 Go to previous messageGo to next message
Jason,
Yes I did as you mentioned in your previous email.
And set the BIRT home:
pf.setBIRTHome("C:/Program Files/Helios-BIRT/eclipse ");
[Updated on: Thu, 07 October 2010 09:41] by Moderator
Re: Zoom capability [message #631414 is a reply to message #631412] Thu, 07 October 2010 09:40 Go to previous messageGo to next message
Does it have any other dependencies which I need to add to my plugins folder?
Re: Zoom capability [message #631421 is a reply to message #631414] Thu, 07 October 2010 09:51 Go to previous messageGo to next message
What are you using as your build path (classpath)?
Jason
> folder?
Re: Zoom capability [message #631445 is a reply to message #631414] Thu, 07 October 2010 10:23 Go to previous message
What I did to get it to work was to copy the plugin
(org.eclipse.birt.chart.device.pdf) from the chart download
(birt-charts-2_5_1\ChartRuntime\eclipse\plugins) to the plugins folder
of my birt runtime and then added one extra lib to my build path.
birt-charts-2_5_1\DeploymentRuntime\ChartEngine\org.apache.x erces_2.9.0.v200909240008.jar
Jason
> folder?
Previous Topic:Arabic fonts are not rendered
Next Topic:turning filters on and off
Current Time: Wed Jul 23 11:55:30 EDT 2025
Powered by FUDForum. Page generated in 0.23588 seconds
