Home » Archived » BIRT » BIRT Servlet: The change of the location of the platform folder?
BIRT Servlet: The change of the location of the platform folder? [message #630554] Mon, 04 October 2010 02:07 Go to next message
Is it possible to change the location of the platform folder of the BIRT servlet?
Currently it seems to be hard coded to the
WEB-INF\platform\
Is it possible to change the location of the:
1) WEB-INF\platform\
2) WEB-INF\platform\plugins\
3) WEB-INF\platform\configuration\
folders outside of the war package.
BR,
Mika
[Updated on: Mon, 04 October 2010 03:27] by Moderator
Re: Change the location of the platform folder of the BIRT Servlet? [message #630709 is a reply to message #630554] Mon, 04 October 2010 11:29 Go to previous messageGo to next message
Currently this is hard coded in the viewer. You can check out the code
and change it or write your own servlet using the engine. The
configuration directory which is written to by osgi can be changed with
an osgi parameter in the config.ini. If you want to do this see this link:
http://www.birt-exchange.org/org/forum/index.php/topic/20613 -birt-26-and-ibm-websphere-can-not-startup-the-osgi-framewor k/page__gopid__68935&#entry68935
Jason
On 10/4/2010 2:07 AM, mika.tapanainen@digia.com wrote:
> Hello,
> servlet?
> WEB-INF\platform\
> BR,
> Mika
Re: Change the location of the platform folder of the BIRT Servlet? [message #631128 is a reply to message #630709] Wed, 06 October 2010 05:47 Go to previous messageGo to next message
I tried to use
osgi.install.area=file:/c:/birtRuntimePlugins2_6_1/
but it didn't work. There was an exception:
[5.10.2010 10:03:36:476 EEST] 0000003d SystemErr     R org.eclipse.birt.core.exception.BirtException: error.CannotStartupOSGIPlatform
[5.10.2010 10:03:36:492 EEST] 0000003d SystemErr     R        at org.eclipse.birt.core.framework.Platform.startup(Platform.java:92)
[5.10.2010 10:03:36:492 EEST] 0000003d SystemErr     R        at pdf.BirtEngine.getBirtEngine(BirtEngine.java:82)
[5.10.2010 10:03:36:492 EEST] 0000003d SystemErr     R        at pdf.PDFServlet.init(PDFServlet.java:275)
My servlet is based on the BIRT 2.5 example on the page:
http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1
Is it possible to have a plugins folder outside of the war package and use osgi.install.area or other configuration parameter?
BR,
Mika
Re: Change the location of the platform folder of the BIRT Servlet? [message #631204 is a reply to message #631128] Wed, 06 October 2010 10:55 Go to previous messageGo to next message
Mika,
In that example if you do not want to use the web-inf/platform folder do
not create the PlatformServletContext and set a birt home ie:
config.setEngineHome("c:/mybirtplugins");
//IPlatformContext context = new PlatformServletContext( sc );
//config.setPlatformContext( context );
Jason
On 10/6/2010 5:47 AM, mika.tapanainen@digia.com wrote:
> Hello,
> I tried to use
> org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:92)
> BR,
> Mika
Re: Change the location of the platform folder of the BIRT Servlet? [message #631384 is a reply to message #631204] Thu, 07 October 2010 07:10 Go to previous message
Thanks, this is working
Previous Topic:use Hibernate connection pool
Next Topic:Arabic fonts are not rendered
Current Time: Sat Jul 26 22:26:29 EDT 2025
Powered by FUDForum. Page generated in 0.04909 seconds
