How to run junit tests on linux? [message #630507] |
Sun, 03 October 2010 10:47  |
Hi folks!
I"d like to run junit tests after build site.p2.zip.
Now I use buckminster on Hudson by Hudson Buckminster Plugin.
But ClassNotFoundException is occured when test runnning. The class 'org.eclipse.swt.SWTError' is not found.
How should I do the commands?
My buckminster commands are below.
importtargetdefinition -A '${WORKSPACE}junit.extensions.eclipse.quick.builder-feature/quick_junit_base.target'
import '${WORKSPACE}junit.extensions.eclipse.quick.builder-feature/quick_junit.cquery'
build
perform -D target.os=* -D target.ws=* -D target.arch=* junit.extensions.eclipse.quick.builder#site.p2.zip
junit -l 'junit.extensions.eclipse.quick.process.test/launch/ProcessAllTest.launch' -o '${WORKSPACE}test.xml' --flatXML
and stdout are below.
!SESSION 2010-10-03 22:40:41.119 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_18
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=ja_JP
Framework arguments: -version 3 -port 34742 -testLoaderClass org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader -loaderpluginname org.eclipse.jdt.junit4.runtime -classNames junit.extensions.eclipse.quick.process.internal.ProcessParserTest -application org.eclipse.pde.junit.runtime.coretestapplication -testpluginname junit.extensions.eclipse.quick.process
Command-line arguments: -os linux -ws gtk -arch x86 -consoleLog -version 3 -port 34742 -testLoaderClass org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader -loaderpluginname org.eclipse.jdt.junit4.runtime -classNames junit.extensions.eclipse.quick.process.internal.ProcessParserTest -application org.eclipse.pde.junit.runtime.coretestapplication -data /var/hudson/jobs/Quick JUnit CI/workspace/../junit-workspace -dev file:/var/hudson/jobs/Quick JUnit CI/workspace/.metadata/.plugins/org.eclipse.pde.core/pde-junit/dev.properties -os linux -ws gtk -arch x86 -consoleLog -testpluginname junit.extensions.eclipse.quick.process
!ENTRY org.eclipse.osgi 2 0 2010-10-03 22:40:43.979
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-10-03 22:40:43.979
!MESSAGE Bundle reference:file:/var/hudson/jobs/Quick JUnit CI/workspace/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.pde.ui_3.6.1.v20100810_r361.jar was not resolved.
!SUBENTRY 2 org.eclipse.pde.ui 2 0 2010-10-03 22:40:43.980
!MESSAGE Missing required bundle org.eclipse.jdt.junit_[3.2.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-10-03 22:40:43.980
!MESSAGE Bundle reference:file:/var/hudson/jobs/Quick JUnit CI/workspace/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.ant.ui_3.5.0.v20100427.jar was not resolved.
!SUBENTRY 2 org.eclipse.ant.ui 2 0 2010-10-03 22:40:43.981
!MESSAGE Missing required bundle org.eclipse.jdt.junit_[3.5.0,4.0.0).
!ENTRY org.eclipse.osgi 2 0 2010-10-03 22:40:43.984
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-10-03 22:40:43.985
!MESSAGE Bundle org.eclipse.ant.ui_3.5.0.v20100427 [18] was not resolved.
!SUBENTRY 2 org.eclipse.ant.ui 2 0 2010-10-03 22:40:43.985
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-10-03 22:40:43.986
!MESSAGE Bundle org.eclipse.pde.api.tools.ui_1.0.201.v20100820_r361 [128] was not resolved.
!SUBENTRY 2 org.eclipse.pde.api.tools.ui 2 0 2010-10-03 22:40:43.986
!MESSAGE Missing required bundle org.eclipse.pde.ui_[3.4.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-10-03 22:40:43.987
!MESSAGE Bundle org.eclipse.pde.ds.ui_1.0.100.v20100601 [133] was not resolved.
!SUBENTRY 2 org.eclipse.pde.ds.ui 2 0 2010-10-03 22:40:43.987
!MESSAGE Missing required bundle org.eclipse.pde.ui_[3.3.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-10-03 22:40:43.988
!MESSAGE Bundle org.eclipse.pde.ua.ui_1.0.100.v20100504 [138] was not resolved.
!SUBENTRY 2 org.eclipse.pde.ua.ui 2 0 2010-10-03 22:40:43.988
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-10-03 22:40:43.989
!MESSAGE Bundle org.eclipse.pde.ui_3.6.1.v20100810_r361 [139] was not resolved.
!SUBENTRY 2 org.eclipse.pde.ui 2 0 2010-10-03 22:40:43.990
!MESSAGE Missing required bundle org.eclipse.ant.ui_[3.1.0,4.0.0).
!SUBENTRY 2 org.eclipse.pde.ui 2 0 2010-10-03 22:40:43.991
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-10-03 22:40:43.992
!MESSAGE Bundle org.eclipse.pde.ui.templates_3.4.200.v20100601 [140] was not resolved.
!SUBENTRY 2 org.eclipse.pde.ui.templates 2 0 2010-10-03 22:40:43.992
!ENTRY org.eclipse.osgi 4 0 2010-10-03 22:40:44.038
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (170).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:156)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:751)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:417)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:265)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:106)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:453)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:457)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:634)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:580)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:550)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:481)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:469)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:149)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1197)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner$BundleClassLoader.findClass(RemotePluginTestRunner.java:38)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadClass(RemoteTestRunner.java:693)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadClasses(RemoteTestRunner.java:429)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:452)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:62)
at org.eclipse.pde.internal.junit.runtime.CoreTestApplication.run(CoreTestApplication.java:23)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2406)
at java.lang.Class.getConstructor0(Class.java:2716)
at java.lang.Class.newInstance0(Class.java:343)
at java.lang.Class.newInstance(Class.java:325)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:151)
... 78 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
... 84 more
Root exception:
FUDForum. Page generated in 0.25950 seconds
