Re: [Databinding] Soliciting feedback on my aggregation library [message #630504 is a reply to message #629012] |
Sun, 03 October 2010 08:57   |
Hi Anthony,
first of all, thanks a lot for your interest in databinding and for your
effort in designing your own code in such a way that it might be used to
extend the databinding framework itself!
I only had a look at your blog post for now and since I will be on
holiday for two weeks I might not get into having a closer look at the
actual implementation. However, at first sight, it seems to me that what
you're doing might be related to the following bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=300043
The bug proposes some sort of "reducer API" which I think could also be
used to implement the type of aggregations you are proposing (e.g. as a
special implementation of a ListReducer). There's a tentative patch by
Matthew Hall attached to the bug so you might want to have a look at it.
In any case, I will have a look at your implementation but I cannot
really guarantee that it will be before my holiday...
Ovidio
On 09/26/2010 02:51 AM, Anthony Juckel wrote:
> I've written a quick add-on to the Properties-based databinding API to
> allow for aggregate properties (e.g. sum, average, min, max). I'd
> appreciate feedback regarding it's general usability as well as API design.
> Quick blog post:
> http://sputteringdigitized.blogspot.com/2010/09/eclipse-data binding-aggregation.html
> Github project:
> http://github.com/ajuckel/net.juckel.rcp.databinding.aggrega te
> Anthony W. Juckel
Re: [Databinding] Soliciting feedback on my aggregation library [message #632188 is a reply to message #630504] |
Mon, 11 October 2010 22:40  |
I pushed a new branch (b300043) to github which updates my static
utility class AggregateProperties to use the IListReducer API proposed
in bug 300043. All my tests still pass, but I can't see an obvious way
to port the weighted average property (which reduces two IListProperties
into a single IValueProperty).
Also, I'd like to start looking into making simple indexer reducers also
allow setting the indexed value. As an example, I've got
AggregateProperties#nth(int,IListProperty), and feel that observed
values of that property should be assignable.
Do you feel this API will likely make it into Indigo?
FUDForum. Page generated in 0.02880 seconds
