Home » Archived » BIRT » Scripted Datasources using BIRT Reporter plugin(Is there a more elegant method for BIRT viewer to luk my java classes than including in the scriptlib)
Scripted Datasources using BIRT Reporter plugin [message #630170] Thu, 30 September 2010 17:14 Go to next message
Hi Jason,
I was able to get my report running by placing my jar files in the scriptlib folder as you asked me to. However is there a more elegant solution for BIRT report plugin to look up my java classes. I will bebundling the solution inot an RCP app , In my case I want BIRT viewer to have acces to my whole persistance stack, which include a whole bunch of jars. One thing I tried to do is add
Eclipse-BuddyPolicy: registered
to the manifest file of my BIRT report viewer, and then added the following to the Manifest file of the plugin which has my java classes
Eclipse-RegisterBuddy: org.eclipse.birt.report.viewer.ViewerPlugin
I assumed that this will allow BIRT report to actually have access to my java class , but it did not work. Please advise me as to how to set my classloader on the BIRT report viewer.Your help is highly appreciated.
Re: Scripted Datasources using BIRT Reporter plugin [message #630303 is a reply to message #630170] Fri, 01 October 2010 09:53 Go to previous messageGo to next message
The problem is my application will be deployed as eclipse stand alone application, either as RCP or as eclipse plugin. In case of eclipse plugin I cannot bundle my persistance jars with the BIRT report viewer on every standalone machine. Is there any other way of sharing my java classes with the BIRT report viewer..?? Can I force BIRT report viewer to load up the class loader which has my java classes..Please help me on this one
Thanks in advance!!!
Re: Scripted Datasources using BIRT Reporter plugin [message #630317 is a reply to message #630170] Fri, 01 October 2010 10:44 Go to previous message
Rajesh,
There are some appContext settings that allow you to set the parent
classloader for the engine and to add to the classpath. If you are
using the viewer plugin in an RCP app this requires that you implement
the appcontext extension which is very easy. Take a look at this example:
RCP APP with BIRT and Scripted Datasource
http://www.birt-exchange.org/org/devshare/designing-birt-rep orts/889-rcp-app-with-birt-and-scripted-datasource/
Jason
On 9/30/2010 5:14 PM, Rajesh Indurthi wrote:
> Hi Jason,
> Eclipse-BuddyPolicy: registered to the manifest file of my BIRT report
Previous Topic:BIRT System Requirement
Next Topic:system requirment for BIRT
Current Time: Sat Jul 26 03:31:31 EDT 2025
Powered by FUDForum. Page generated in 0.04709 seconds
