Home » Archived » Buckminster » P2 located in SVN
P2 located in SVN [message #630207] Fri, 01 October 2010 03:30 Go to next message
Hello
My problem is, that buckminster can not finde my P2 repository on SVN. But if I try the same configurations for a local repository is it working.
The searchPath for Sources is also working with the SVN repository. Only searchPath internalBinaries is not working with SVN.
My RMAP:
<rm:rmap xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0" xmlns:rm="http://www.eclipse.org/buckminster/RMap-1.0">
  <rm:property key="build.type" mutable="true" value="N"/>
  <rm:locator pattern="^com\.csg.*" searchPathRef="internalBinaries" failOnError="false"/>
  <rm:locator pattern="^com\.csg.*" searchPathRef="sources"/>
  <rm:locator searchPathRef="externalBinaries"/>
  <rm:searchPath name="internalBinaries">
    <rm:provider componentTypes="eclipse.feature,osgi.bundle" readerType="p2" source="false" mutable="false">
      <rm:uri format="https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/p2/com.csg.crs.carat.p2.update"/>
    </rm:provider>
  </rm:searchPath>
  <rm:searchPath name="sources">
    <rm:provider componentTypes="buckminster,osgi.bundle" readerType="svn">
      <rm:uri format="https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/{0}">
        <bc:propertyRef key="buckminster.component"/>
      </rm:uri>
    </rm:provider>
    <rm:provider componentTypes="eclipse.feature" readerType="svn">
      <rm:uri format="https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/{0}-feature">
      </rm:uri>
    </rm:provider>
  </rm:searchPath>
  <rm:searchPath name="externalBinaries">
      <rm:uri format="http://download.eclipse.org/eclipse/updates/3.6"/>
    </rm:provider>
      <rm:uri format="http://download.eclipse.org/releases/helios"/>
    </rm:provider>
  </rm:searchPath>
</rm:rmap>
Are there some other configurations for a P2 repository?
Thank you & Cheers,
[Updated on: Fri, 01 October 2010 03:31] by Moderator
Re: P2 located in SVN [message #630222 is a reply to message #630207] Fri, 01 October 2010 04:22 Go to previous messageGo to next message
Only thing I can think of off hand is that you're using https. Sometimes
you need to confirm signatures to get the secure handshake going.
Perhaps that hasn't been done on the server where your Buckminster is
running.
What kind of errors do you see from the p2 provider?
- thomas
On 10/01/2010 09:30 AM, M. Stutz wrote:
> Hello
> My RMAP:
> <rm:uri
> format=" https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/p2/com.csg.crs.carat.p2.update"/>
> </rm:provider>
> </rm:searchPath>
> <rm:uri
> format=" https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/{0}">
> </rm:uri>
> </rm:provider>
> <rm:uri
> format=" https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/{0}-feature">
> </rm:uri>
> </rm:provider>
> </rm:searchPath>
> </rm:provider>
> </rm:provider>
> </rm:searchPath>
> </rm:rmap>
Re: P2 located in SVN [message #630224 is a reply to message #630222] Fri, 01 October 2010 04:44 Go to previous messageGo to next message
Thomas Hallgren wrote on Fri, 01 October 2010 04:22
running.
But for the sources (SVN) is it works, only for the P2 reopsitory not.
Or is there a diffrent connection?
The following errors are coming:
ERROR   [0002] : No suitable provider for component com.csg.crs.carat.dsl.display:eclipse.feature was found in resourceMap file:/C:/Data/projects/MDA/Developer/com.csg.crs.carat.developer.releng/developer.rmap
  ERROR   [0002] : No suitable provider for component com.csg.crs.carat.dsl.display:eclipse.feature was found in searchPath internalBinaries
    ERROR   [0002] : Rejecting provider p2(https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/p2/com.csg.crs.carat.p2.update[https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/p2/com.csg.crs.carat.p2.update]): No component match was found
      ERROR   No repository found at https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/p2/com.csg.crs.carat.p2.update/.
  ERROR   [0002] : No suitable provider for component com.csg.crs.carat.dsl.display:eclipse.feature was found in searchPath sources
    ERROR   [0002] : Rejecting provider svn(https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/{0}[https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/com.csg.crs.carat.dsl.display]): Components of type eclipse.feature are not supported
    ERROR   [0002] : Rejecting provider svn(https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/{0}-feature[https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/com.csg.crs.carat.dsl.display-feature]): No component match was found
Thank you & Cheers,
Re: P2 located in SVN [message #630237 is a reply to message #630224] Fri, 01 October 2010 05:33 Go to previous messageGo to next message
You're right. You already use https so that can't be the problem.
Are you able to access the file:
https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/p2/com.csg.crs.carat.p2.update/content.jar
If you are, can you unpack it and verify that it contains an IU with
id="com.csg.crs.carat.dsl.display.feature.group" ?
- thomas
>> Sometimes you need to confirm signatures to get the secure handshake
>> going. Perhaps that hasn't been done on the server where your
>> Buckminster is running.
> file:/C:/Data/projects/MDA/Developer/com.csg.crs.carat.devel oper.releng/developer.rmap
> internalBinaries
> p2( https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/p2/com.csg.crs.carat.p2.update[ https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/p2/com.csg.crs.carat.p2.update]):
> sources
> svn( https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/{0}[ https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/com.csg.crs.carat.dsl.display]):
> svn( https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/{0}-feature[ https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/com.csg.crs.carat.dsl.display-feature]):
> Thank you & Cheers,
Re: P2 located in SVN [message #630244 is a reply to message #630237] Fri, 01 October 2010 06:00 Go to previous messageGo to next message
Thomas Hallgren wrote on Fri, 01 October 2010 05:33
I use no content.jar, I use compositeArtifacts.xml and compositeContent.xml.
<?xml version='1.0' encoding='UTF-8'?>
<?compositeArtifactRepository version='1.0.0'?>
<repository name='"CARAT P2 Container"'
    type='org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository'
    version='1.0.0'>
  <properties size='1'>
    <property name='p2.timestamp' value='1243822502440'/>
  </properties>
  <children size='1'>
    <child location='https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/p2/com.csg.crs.carat.p2.update/site.p2'/>
  </children>
</repository>
<?compositeMetadataRepository version='1.0.0'?>
    type='org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository'
    version='1.0.0'>
    <property name='p2.timestamp' value='1243822502499'/>
  </properties>
  <children size='1'>
  </children>
</repository>
Re: P2 located in SVN [message #630276 is a reply to message #630244] Fri, 01 October 2010 06:34 Go to previous messageGo to next message
OK, so traverse the metadata composite children. Do you find the feature
IU in any of the repositories that it includes?
- thomas
> type='org.eclipse.equinox.internal.p2.artifact.repository.Co mpositeArtifactRepository'
> version='1.0.0'>
> </properties>
> <children size='1'>
> <child
> location=' https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/p2/com.csg.crs.carat.p2.update/site.p2'/>
> </children>
> </repository>
> type='org.eclipse.equinox.internal.p2.metadata.repository.Co mpositeMetadataRepository'
> version='1.0.0'>
> </properties>
> <children size='1'>
> <child
> </children>
> </repository>
> Cheers,
Re: P2 located in SVN [message #630294 is a reply to message #630276] Fri, 01 October 2010 09:13 Go to previous messageGo to next message
Thomas Hallgren wrote on Fri, 01 October 2010 06:34
Yes I find every thing. I use all the same configurations how local, only the url is not to a local directory but also to the SVN repository.
And in the SVN is the P2 repository also the same how local.
Re: P2 located in SVN [message #630366 is a reply to message #630294] Fri, 01 October 2010 14:17 Go to previous messageGo to next message
I cannot understand why p2 doesn't find it if you do. Can you paste the
IU descriptor here for reference?
If you view the composite repository in your IDE, does the feature show
up there?
- thomas
>> feature IU in any of the repositories that it includes?
> Cheers,
Re: P2 located in SVN [message #630557 is a reply to message #630366] Mon, 04 October 2010 03:18 Go to previous messageGo to next message
Thomas Hallgren wrote on Fri, 01 October 2010 14:17
Which file do you mean exactly?
If you view the composite repository in your IDE, does the feature show up there?
Yes, every thing is there. But it doesn't work also, if I try to import the P2 directly, with out the composite repository.
Thank you & Cheers,
Re: P2 located in SVN [message #630581 is a reply to message #630557] Mon, 04 October 2010 05:09 Go to previous messageGo to next message
>> the IU descriptor here for reference?
The IU descriptor XML element that you find in the p2 meta-data content.
>> show up there?
It works if you use the repository directly but not with the composite? If that's the case, that indicates a problem
with the composite.
I suggest you make the repository work flawlessly with the Eclipse IDE first, before you try to find problems in your RMAP.
- thomas
Re: P2 located in SVN [message #630588 is a reply to message #630581] Mon, 04 October 2010 05:59 Go to previous messageGo to next message
Thomas Hallgren wrote on Mon, 04 October 2010 05:09
The whole content.xml? (only because it is really big)
with the composite.
No, it works if I use a local repository. It works not, if I use a SVN repository. So I can use on SVN a Composite Repository or directly the P2 Repository, in both case is it not runnable.
Sorry for confusion.
Re: P2 located in SVN [message #630599 is a reply to message #630588] Mon, 04 October 2010 06:46 Go to previous messageGo to next message
No, just the descriptor of the failing IU.
>> composite? If that's the case, that indicates a problem with the
>> composite.
All I'm saying is that you should verify that the URL's you use in the RMAP to reach the repositories in question shows
the expected content in the IDE installer. If they don't, you have little chance of success using the same URL in an
RMAP. From what I recall, the problems occur when using https URL's and not local ones.
- thomas
Re: P2 located in SVN [message #630613 is a reply to message #630599] Mon, 04 October 2010 07:55 Go to previous messageGo to next message
Ok, you mean this UI descriptor, or?
  <?xml version="1.0" encoding="UTF-8" ?>
  <?metadataRepository version='1.1.0'?>
- <repository name="Site" type="org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository" version="1">
- <properties size="2">
  <property name="p2.timestamp" value="1285937176756" />
  <property name="p2.compressed" value="true" />
  </properties>
Is it possible that the descriptor type something like SVN instead of Local must be?
Thomas Hallgren wrote on Mon, 04 October 2010 06:46
Ok, I tried the URL with the IDE installer and it doesn't works.
Unable to read repository at https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/p2/com.csg.crs.carat.p2.update/content.xml.
Remote host closed connection during handshake
Why he search a content.xml, when there the compositeContent.xml is?
Thank you and Cheers,
[Updated on: Mon, 04 October 2010 08:04] by Moderator
Re: P2 located in SVN [message #630632 is a reply to message #630613] Mon, 04 October 2010 08:26 Go to previous messageGo to next message
> https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/p2/com.csg.crs.carat.p2.update/content.xml
p2 will search for content.jar, content.xml, compositeContent.jar, compositContent.xml, and site.xml. The message is
misleading, it probably means that it didn't find any of them.
-thomas
Re: P2 located in SVN [message #630633 is a reply to message #630632] Mon, 04 October 2010 08:50 Go to previous messageGo to next message
I searched for the "closed connection during handshake" problem - and
found this:
Explanation This exception occurs when you enable administrative,
application, and Java 2 security using the LDAP (Windows 2000 Active
Directory) user registry.
Possible causes
The SSL enabled option is checked on the Standalone LDAP registry
configuration panel.
The LDAP port number or host name are wrong. The LDAP server certificate
is wrong or expired on the LDAP server.
The certificate authority (CA) is not imported to WebSphere Application
Server, or it is wrong.
The Secure Sockets Layer (SSL) configuration is wrong.
There is a network problem.
Could that be applicable to your problem?
- henrik
> compositContent.xml, and site.xml. The message is misleading, it
> -thomas
Re: P2 located in SVN [message #630680 is a reply to message #630633] Mon, 04 October 2010 10:38 Go to previous message
Henrik Lindberg wrote on Mon, 04 October 2010 08:50
found this:
Possible causes
- henrik
Yes some thing like this can be applicable. We will try an other way with our p2 repositories. Without a direct connection to the SVN.
Thank you very much for your help,
Previous Topic:How to debug: "No component XXX is known to Buckminster"?
Next Topic:How to run junit tests on linux?
Current Time: Wed Jul 23 05:15:58 EDT 2025
Powered by FUDForum. Page generated in 0.11791 seconds
