Home » Archived » BIRT » Table cell Word Wrap
Table cell Word Wrap [message #630269] Fri, 01 October 2010 07:29 Go to next message
Hi All
I am new to BIRT and just trying to get to to grips with it. I am using the 2.6.1 all in one package.
I have created a report and added a table. The columns attached to the table are pulled from a MySQL database.
The problem I have is that if string data is added to table cells, I cannot get the text to wrap onto a new line. If I set the report layout as 'Auto Layout', the table expands to the right to accommodate the long line but this doesn't render properly in PDF.
If I use 'Fixed Layout' the string returned just gets truncated at the right hand edge of the cell. I want it to wrap onto a new line if necessary.
I thought BIRT was based on a web paradigm?
I must be doing something really stupid and missed something obvious. Can anyone point me in the right direction? i can't seem to see a 'word wrap' property anywhere.
Lee
Re: Table cell Word Wrap [message #630282 is a reply to message #630269] Fri, 01 October 2010 08:17 Go to previous messageGo to next message
Well, no sooner have I posted the query, I now find the answer! A table cell or column can have a Text.Whitespace property. Mine was set to 'No wrapping', whereas if I set it to 'Normal' I get the result I want, including whet creating a PDF.
So, I guess I wonder why this property is not set to 'Normal' by default and how can I make it the default for all future tables?
Lee
Re: Table cell Word Wrap [message #630328 is a reply to message #630269] Fri, 01 October 2010 11:24 Go to previous messageGo to next message
Lee
You may want to look at this thread.
http://www.birt-exchange.org/org/forum/index.php/topic/19827 -how-do-i-use-word-wrap-in-report-design/page__s__ad0bb32bbb ac95aee7b5556149417a73
If the element is a data element you could enter an expression like:
function wrap(longStr,width){
length = longStr.length;
if(length <= width)
return longStr;
return (longStr.substring(0, width) + "\n" +
wrap(longStr.substring(width, length), width));
wrap("thisisatestofaverylongstringthatIdowanttowrap.", 6);
Just replace the wrap(str,size) with your data column
wrap( dataSetRow["mylongstring"], 6 );
If there is whitespace it should be autowrapping.
Jason
On 10/1/2010 7:29 AM, Sapphie wrote:
> Hi All
> necessary.
> Lee
Re: Table cell Word Wrap [message #630329 is a reply to message #630282] Fri, 01 October 2010 11:26 Go to previous messageGo to next message
Sorry I did not see your reply. The default style for a table cell
should be normal. Was this a new report?
Jason
> Thanks
> Lee
Re: Table cell Word Wrap [message #630330 is a reply to message #630329] Fri, 01 October 2010 11:40 Go to previous messageGo to next message
Thanks Jason.
It was for a new report but I had tinkered with it, changing column widths, changing from auto-format to fixed format and back again. Somewhere along the way this property got set to No Wrap.
Of course, it's entirely possible that I had set it that way myself but I don't remember doing so!!
I am also looking at how best to lay these reports out, when I want the option to be viewed on the web and to generate a nicely formatted PDF. Seems like 'Fixed layout' is the best choice in this scenario.
So far I am quite impressed with it though. We also use Oracle Discoverer ...
Lee
Re: Table cell Word Wrap [message #630363 is a reply to message #630330] Fri, 01 October 2010 14:19 Go to previous messageGo to next message
Lee,
Thanks for the thoughts. Fixed is generally the best approach when PDF
output is needed.
Jason
On 10/1/2010 11:40 AM, Sapphie wrote:
> Thanks Jason.
> Discoverer ...
> Lee
Re: Table cell Word Wrap [message #676004 is a reply to message #630328] Thu, 02 June 2011 07:07 Go to previous messageGo to next message
Hi Jason,
I checked the linked provided by you, where i am seeing the exception mentioned over there.
When i try to do 'export data' to CSV format, from this report [which is deployed under tomcat server], i am getting exception saying function wrap() is not defined.
However i did not see any exception, if i do export data from BIRT eclipse setup.
Any help !!
Re: Table cell Word Wrap [message #676051 is a reply to message #676004] Thu, 02 June 2011 10:54 Go to previous messageGo to next message
Where do you have the wordwrap function defined and where are you
calling it?
Jason
On 6/2/2011 7:07 AM, pratim wrote:
> Hi Jason,
> mentioned over there. When i try to do 'export data' to CSV format, from
> eclipse setup.
> Any help !!
Re: Table cell Word Wrap [message #1291173 is a reply to message #630330] Thu, 10 April 2014 15:40 Go to previous message
Hi Jason,
I'm still having trouble on Text Wrap for a dataset row field, where I could see Table Whitespace = Normal, Row Whitespace = Normal : Inherited ; Cell Whitespace = Normal : Inherited and Data Whitespace = Normal : Inherited
See attached document on difference.
PS: Our BIRT version is 2.5.1
Appreciate your help on this regard.
Previous Topic:run vs frameset output problem
Next Topic:bar chart with 2 y-axes
Current Time: Wed Jul 23 02:43:49 EDT 2025
Powered by FUDForum. Page generated in 0.09245 seconds
