Home » Modeling » GMF (Graphical Modeling Framework) » Hide/Unhide a node(Hide/Unhide a node)
Hide/Unhide a node [message #630259] Fri, 01 October 2010 06:43 Go to next message
Hi All,
I am working on a GMF based RCP tool.
Now i have to hide a node and its child node when i double click on that node(can be triggered in any event)
I have installed a new edit policy as
installEditPolicy(EditPolicyRoles.OPEN_ROLE,
createOpenEditPolicy());
and inside the createOpenEditPolicy(), i have done the following,
private OpenEditPolicy createOpenEditPolicy() {
OpenEditPolicy policy = new OpenEditPolicy() {
protected Command getOpenCommand(Request request) {
IGraphicalEditPart ige = (IGraphicalEditPart) this
.getTargetEditPart(request);
View selectedView = ige.getPrimaryView();
selectedView.setVisible(false);
return null;
return policy;
But the node is hidden only if i refresh the diagram by adding a new node.
Kindly suggest where i went wrong, and let me know how to automatically refresh the diagram.
Jeno J
Re: Hide/Unhide a node [message #630467 is a reply to message #630259] Sat, 02 October 2010 20:29 Go to previous messageGo to next message
try casting (IGraphicalEditPart) this
.getTargetEditPart(request) to the specif editpart of your domain and after try:
editPart.getPrimaryShape().repaint();
If it not works, maybe you have a property in your figure that allows to set the visibility too.
Fernando
Re: Hide/Unhide a node [message #630555 is a reply to message #630467] Mon, 04 October 2010 02:07 Go to previous messageGo to next message
I just casted to the specific editpart and its working fine.
Thanks a lot for your help.
Jeno J.
Re: Hide/Unhide a node [message #630587 is a reply to message #630555] Mon, 04 October 2010 05:48 Go to previous message
Now the node is hidden, but the changes are not getting persisted in the diagram file.
It will be helpful if the changes are stored in a file so that we can restore the changes while closing and opening the diagram again.
Jeno J
Previous Topic:To change the icon for the diagram file
Next Topic:gmf as rcp : the common navigator introduces bugs
Current Time: Mon Jul 21 07:30:14 EDT 2025
Powered by FUDForum. Page generated in 0.21946 seconds
