Home » Archived » Buckminster » P2 located in SVN
P2 located in SVN [message #630207] |
Fri, 01 October 2010 03:30  |
Hello
My problem is, that buckminster can not finde my P2 repository on SVN. But if I try the same configurations for a local repository is it working.
The searchPath for Sources is also working with the SVN repository. Only searchPath internalBinaries is not working with SVN.
My RMAP:
<rm:rmap xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0" xmlns:rm="http://www.eclipse.org/buckminster/RMap-1.0">
<rm:property key="build.type" mutable="true" value="N"/>
<rm:locator pattern="^com\.csg.*" searchPathRef="internalBinaries" failOnError="false"/>
<rm:locator pattern="^com\.csg.*" searchPathRef="sources"/>
<rm:locator searchPathRef="externalBinaries"/>
<rm:searchPath name="internalBinaries">
<rm:provider componentTypes="eclipse.feature,osgi.bundle" readerType="p2" source="false" mutable="false">
<rm:uri format="https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/p2/com.csg.crs.carat.p2.update"/>
</rm:provider>
</rm:searchPath>
<rm:searchPath name="sources">
<rm:provider componentTypes="buckminster,osgi.bundle" readerType="svn">
<rm:uri format="https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/{0}">
<bc:propertyRef key="buckminster.component"/>
</rm:uri>
</rm:provider>
<rm:provider componentTypes="eclipse.feature" readerType="svn">
<rm:uri format="https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/{0}-feature">
</rm:uri>
</rm:provider>
</rm:searchPath>
<rm:searchPath name="externalBinaries">
<rm:uri format="http://download.eclipse.org/eclipse/updates/3.6"/>
</rm:provider>
<rm:uri format="http://download.eclipse.org/releases/helios"/>
</rm:provider>
</rm:searchPath>
</rm:rmap>
Are there some other configurations for a P2 repository?
Thank you & Cheers,
[Updated on: Fri, 01 October 2010 03:31] by Moderator
Re: P2 located in SVN [message #630581 is a reply to message #630557] |
Mon, 04 October 2010 05:09   |
On 10/04/2010 09:18 AM, M. Stutz wrote:
> Thomas Hallgren wrote on Fri, 01 October 2010 14:17
>> I cannot understand why p2 doesn't find it if you do. Can you paste
>> the IU descriptor here for reference?
The IU descriptor XML element that you find in the p2 meta-data content.
> Which file do you mean exactly?
>> If you view the composite repository in your IDE, does the feature
>> show up there?
> Yes, every thing is there. But it doesn't work also, if I try to import
> the P2 directly, with out the composite repository.
It works if you use the repository directly but not with the composite? If that's the case, that indicates a problem
with the composite.
I suggest you make the repository work flawlessly with the Eclipse IDE first, before you try to find problems in your RMAP.
- thomas
Re: P2 located in SVN [message #630588 is a reply to message #630581] |
Mon, 04 October 2010 05:59   |
Thomas Hallgren wrote on Mon, 04 October 2010 05:09 | On 10/04/2010 09:18 AM, M. Stutz wrote:
The whole content.xml? (only because it is really big)
with the composite.
No, it works if I use a local repository. It works not, if I use a SVN repository. So I can use on SVN a Composite Repository or directly the P2 Repository, in both case is it not runnable.
Sorry for confusion.
Re: P2 located in SVN [message #630599 is a reply to message #630588] |
Mon, 04 October 2010 06:46   |
No, just the descriptor of the failing IU.
>> composite? If that's the case, that indicates a problem with the
>> composite.
All I'm saying is that you should verify that the URL's you use in the RMAP to reach the repositories in question shows
the expected content in the IDE installer. If they don't, you have little chance of success using the same URL in an
RMAP. From what I recall, the problems occur when using https URL's and not local ones.
- thomas
Re: P2 located in SVN [message #630613 is a reply to message #630599] |
Mon, 04 October 2010 07:55   |
Ok, you mean this UI descriptor, or?
<?xml version="1.0" encoding="UTF-8" ?>
<?metadataRepository version='1.1.0'?>
- <repository name="Site" type="org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository" version="1">
- <properties size="2">
<property name="p2.timestamp" value="1285937176756" />
<property name="p2.compressed" value="true" />
</properties>
Is it possible that the descriptor type something like SVN instead of Local must be?
Thomas Hallgren wrote on Mon, 04 October 2010 06:46 |
Ok, I tried the URL with the IDE installer and it doesn't works.
Unable to read repository at https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/p2/com.csg.crs.carat.p2.update/content.xml.
Remote host closed connection during handshake
Why he search a content.xml, when there the compositeContent.xml is?
Thank you and Cheers,
[Updated on: Mon, 04 October 2010 08:04] by Moderator
Re: P2 located in SVN [message #630633 is a reply to message #630632] |
Mon, 04 October 2010 08:50   |
I searched for the "closed connection during handshake" problem - and
found this:
Explanation This exception occurs when you enable administrative,
application, and Java 2 security using the LDAP (Windows 2000 Active
Directory) user registry.
Possible causes
The SSL enabled option is checked on the Standalone LDAP registry
configuration panel.
The LDAP port number or host name are wrong. The LDAP server certificate
is wrong or expired on the LDAP server.
The certificate authority (CA) is not imported to WebSphere Application
Server, or it is wrong.
The Secure Sockets Layer (SSL) configuration is wrong.
There is a network problem.
Could that be applicable to your problem?
- henrik
>> https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/p2/com.csg.crs.carat.p2.update/content.xml
> p2 will search for content.jar, content.xml, compositeContent.jar,
> compositContent.xml, and site.xml. The message is misleading, it
> probably means that it didn't find any of them.
> -thomas
Re: P2 located in SVN [message #630680 is a reply to message #630633] |
Mon, 04 October 2010 10:38  |
Henrik Lindberg wrote on Mon, 04 October 2010 08:50 | I searched for the "closed connection during handshake" problem - and
found this:
Possible causes
- henrik
Yes some thing like this can be applicable. We will try an other way with our p2 repositories. Without a direct connection to the SVN.
Thank you very much for your help,
Current Time: Wed Jul 23 12:21:16 EDT 2025
Powered by FUDForum. Page generated in 0.15427 seconds
