Home » Archived » BIRT » Updating Chart using a button click(Updating Chart using a button click)
Updating Chart using a button click [message #630116] Thu, 30 September 2010 12:47 Go to next message
Is it possible to update a chart from a button click? If so is there any sample code regarding this?
Re: Updating Chart using a button click [message #630126 is a reply to message #630116] Thu, 30 September 2010 13:08 Go to previous messageGo to next message
Can you give some more detail on how you are running the chart. In the
WebViewer? API? When you want it to update do you just want to re-run
the report and get the new data?
Jason
> Thanks
Re: Updating Chart using a button click [message #630131 is a reply to message #630126] Thu, 30 September 2010 13:35 Go to previous messageGo to next message
I am running via the API on an SWT application. I understand that the chart can be refreshed using a callback implementation by adding triggers. But is it possible to do this externally eg: draw a trendline via an SWT button action. If so how do I link the button action in order to refresh the chart after I draw the line?
Re: Updating Chart using a button click [message #630145 is a reply to message #630131] Thu, 30 September 2010 14:46 Go to previous messageGo to next message
If you checkout the org.eclipse.birt.chart.examples plugin it contains
several SWT example where an update button is used. Look at
SwtChartViewerSelector.java
SwtLiveChartViewer.java
SwtInteractivityViewer.java
Jason
Re: Updating Chart using a button click [message #630146 is a reply to message #630145] Thu, 30 September 2010 15:02 Go to previous message
Thanks Jason!
Previous Topic:How to use caching in BIRT Jsp Page
Next Topic:Error accesing java classes from a scripted dataset
Current Time: Wed Jul 23 14:08:41 EDT 2025
Powered by FUDForum. Page generated in 0.05477 seconds
