Home » Archived » BIRT » BIRT Viewer 2.5.1 ISSUE(BIRT Viewer is running without producing results)
BIRT Viewer 2.5.1 ISSUE [message #629924] Wed, 29 September 2010 20:53 Go to next message
I'm new in BIRT. I created a couple of reports running fine from ECLIPSE (Helios)
When I try to run the same projects using BIRT VIEWER 2.5.1 on Apache/Tomcat 5.5.30 doesn`t work. I tested the BIRT VIEWER installation with the sample and runs fine. However, my own reports just display the popup window with the message "Processsing, please wait..." and never ends.
I don't know what kind of logs to check or how to troubleshoot the issue. One of the reports is a simple list with 5 columns an less than 200 records.
Thanks.
Re: BIRT Viewer 2.5.1 ISSUE [message #630094 is a reply to message #629924] Thu, 30 September 2010 11:41 Go to previous messageGo to next message
Helios contains BIRT 2.6. Can you download the 2.6 runtime and deploy
the viewer it contains to tomcat and give it a try?
Jason
> (Helios)
> 200 records.
> Thanks.
Re: BIRT Viewer 2.5.1 ISSUE [message #630109 is a reply to message #630094] Thu, 30 September 2010 12:25 Go to previous messageGo to next message
Hi Jason,
Thank you very much for your answer.
I tried with the version 2.6 of the runtime and I have the same symptom. Actually, it happens even with the test example.
I don't know if my issue is related to my OS. I am using Windows 7- 64 bits. Should I try a different Apache/Tomcat version?
Thanks again.
Juan Diego
Re: BIRT Viewer 2.5.1 ISSUE [message #630122 is a reply to message #630109] Thu, 30 September 2010 12:43 Go to previous messageGo to next message
Did you use the 2.6. or 2.6.1 runtime. I just tried the 2.6.1 runtime
with tomcat 5.5.20 with no issue. I have the same OS as you.
Jason
On 9/30/2010 12:25 PM, JuanD wrote:
> Hi Jason,
> Thanks again.
> Juan Diego
Re: BIRT Viewer 2.5.1 ISSUE [message #630123 is a reply to message #630122] Thu, 30 September 2010 13:04 Go to previous messageGo to next message
I tried 2.6.1. Should I try Apache 5.5.20?
Thanks a lot, again!
Re: BIRT Viewer 2.5.1 ISSUE [message #630128 is a reply to message #630123] Thu, 30 September 2010 13:11 Go to previous messageGo to next message
Are you getting anything in the \webapps\WebViewer\logs
directory?
I just tried tomcat 6.0.20 and had no issues.
Jason
Re: BIRT Viewer 2.5.1 ISSUE [message #630130 is a reply to message #630128] Thu, 30 September 2010 13:30 Go to previous messageGo to next message
The file ReportEngine_2010_09_30_13_27_30.log shows:
2010-09-30 13:29:23 org.eclipse.birt.report.engine.api.impl.RenderTask render
GRAVE: There is insufficient memory to execute this report.
It seems that this is the problem. How do I increase the available memory for BIRT?
Thanks.
Re: BIRT Viewer 2.5.1 ISSUE [message #630144 is a reply to message #630130] Thu, 30 September 2010 14:40 Go to previous messageGo to next message
Look in the catalina.bat file and edit the JAV_OPTS like below.
if not exist "%CATALINA_HOME%\bin\tomcat-juli.jar" goto noJuli
set JAVA_OPTS=%JAVA_OPTS% -XX:MaxPermSize=256m
:noJuli
Jason
> render
> memory for BIRT?
> Thanks.
Re: BIRT Viewer 2.5.1 ISSUE [message #630281 is a reply to message #630144] Fri, 01 October 2010 08:15 Go to previous messageGo to next message
Hi Jason,
I just looked at your last suggestion now. Unfortunately, I couldn't find the file catalilna.bat. Is it because my Apache is running as a service?
Thanks.
Juan Diego
Re: BIRT Viewer 2.5.1 ISSUE [message #630318 is a reply to message #630281] Fri, 01 October 2010 10:59 Go to previous messageGo to next message
There should be a tomcat5w.exe in the tomcat bin.
Run it and select the java tab and enter
in the Java Options box.
Jason
On 10/1/2010 8:15 AM, JuanD wrote:
> Hi Jason,
> service?
> Thanks.
> Juan Diego
Re: BIRT Viewer 2.5.1 ISSUE [message #630326 is a reply to message #630318] Fri, 01 October 2010 11:26 Go to previous messageGo to next message
Hi Jason,
Thanks. I found the .exe file but when I try to execute it I get "access denied" (or something like that, it is in French), "unable to open the service 'tomcat5'".
I tried stopping the service or having it up and didn't work. I am suppose to be the Administrator for the machine.
Sorry for bothering so much. I am a newby on Apache/Tomcat too.
Thanks again.
Juan Diego
Re: BIRT Viewer 2.5.1 ISSUE [message #630362 is a reply to message #630326] Fri, 01 October 2010 14:18 Go to previous messageGo to next message
Juan,
It sounds like you do not have admin rights on the machine. You could
always download tomcat zip file instead of service and run the bat file
to start it up.
Jason
On 10/1/2010 11:26 AM, JuanD wrote:
> Hi Jason,
> service 'tomcat5'".
> Thanks again.
> Juan Diego
Re: BIRT Viewer 2.5.1 ISSUE [message #630414 is a reply to message #630144] Fri, 01 October 2010 19:49 Go to previous message
Hi Jason,
Solved. Tomcat 5.5.31 installed just as a folder and starting thourg startup.bat. Modified catalina.bat according to your instructions.
I really appreciate your help. Thanks.
Juan Diego
Previous Topic:Error on setMax using DateTimeDataSet series
Next Topic:Custom number format - is there a description ?
Current Time: Fri Jul 25 21:28:53 EDT 2025
Powered by FUDForum. Page generated in 0.06174 seconds
