Home » Archived » Buckminster » P2 Repository can not be found
P2 Repository can not be found [message #629666] |
Wed, 29 September 2010 04:10  |
Hi all
The Problem which I have is, that my P2 repository not can be found by Buckminster.
I have generated a P2 repository in Eclipse with buckminster and this should be imported with Buckminster in an other workspace in the target platform.
But Buckminster can not found this by the import, I have the following error:
ERROR [0002] : No suitable provider for component com.csg.crs.carat.toolsmith.site:eclipse.feature was found in resourceMap file:/C:/Data/projects/MDA/Developer/com.csg.crs.carat.developer.releng/developer.rmap
ERROR [0002] : No suitable provider for component com.csg.crs.carat.toolsmith.site:eclipse.feature was found in searchPath internalBinaries
ERROR [0002] : Resolution attempt ended with exception: Provider local(file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site.p2): Missing CSpec source required by component type eclipse.feature
ERROR Provider local(file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site.p2): Missing CSpec source required by component type eclipse.feature
ERROR [0002] : No suitable provider for component com.csg.crs.carat.toolsmith.site:eclipse.feature was found in searchPath sources
ERROR [0002] : Rejecting provider svn(https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/{0}[https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/com.csg.crs.carat.toolsmith.site]): Components of type eclipse.feature are not supported
ERROR [0002] : Rejecting provider svn(https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/{0}-feature[https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/Product/developer/com.csg.crs.carat.toolsmith.site-feature]): No component match was found
But if I try to install this P2 Repository over eclipse installer, is everything works...
RMAP:
<rm:rmap xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0" xmlns:rm="http://www.eclipse.org/buckminster/RMap-1.0">
<rm:property key="build.type" mutable="true" value="N"/>
<rm:locator pattern="^com\.csg.*" searchPathRef="internalBinaries" failOnError="false"/>
<rm:locator pattern="^com\.csg.*" searchPathRef="sources"/>
<rm:locator searchPathRef="externalBinaries"/>
<rm:searchPath name="internalBinaries">
<rm:provider componentTypes="eclipse.feature,osgi.bundle" readerType="p2" source="false" mutable="false">
<rm:uri format="file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site.p2"/> <!--My P2-->
</rm:provider>
</rm:searchPath>
<rm:searchPath name="sources">
</rm:searchPath>
<rm:searchPath name="externalBinaries">
</rm:searchPath>
</rm:rmap>
CSPEC:
<cs:cspec xmlns:cs="http://www.eclipse.org/buckminster/CSpec-1.0"
name="com.csg.crs.carat.developer.releng"
componentType="buckminster"
version="1.0.0.qualifier">
<cs:dependencies>
<cs:dependency name="com.csg.crs.carat.toolsmith.site" componentType="eclipse.feature"/> <!--My P2-->
<cs:dependency name="org.eclipse.equinox.executable" componentType="eclipse.feature"/>
<cs:dependency name="org.eclipse.platform" componentType="eclipse.feature"/>
<cs:dependency name="org.eclipse.emf" componentType="eclipse.feature"/>
<cs:dependency name="org.eclipse.emf.source" componentType="eclipse.feature"/>
<cs:dependency name="org.eclipse.xpand" componentType="eclipse.feature"/>
<cs:dependency name="org.eclipse.xpand.source" componentType="eclipse.feature"/>
</cs:dependencies>
</cs:cspec>
Knows some one, what I have done wrong?
And is it possible, to use a SVN URL / Location for the p2 repository?
Re: P2 Repository can not be found [message #629952 is a reply to message #629666] |
Thu, 30 September 2010 02:14   |
Are you using a 'local' reader to find your p2 repository? From the
looks of it, a local reader finds the directory and makes an attempt to
extract a feature in source form from that directory. That's not what
you want, is it?
If that's the case, then try using readerType="p2" instead.
Thomas Hallgren
On 09/29/2010 10:10 AM, M. Stutz wrote:
> Hi all
> Buckminster. I have generated a P2 repository in Eclipse with
> workspace in the target platform. But Buckminster can not found this by
> resourceMap
> file:/C:/Data/projects/MDA/Developer/com.csg.crs.carat.devel oper.releng/developer.rmap
> internalBinaries
> local( file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site .p2):
> ERROR Provider
> sources
> svn( https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/{0}[ https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/com.csg.crs.carat.toolsmith.site]):
> svn( https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/{0}-feature[ https://svn.rowini.net/svnrep/cana/trunk/SE_Implementation/P roduct/developer/com.csg.crs.carat.toolsmith.site-feature]):
> everything works...
> RMAP:
> <rm:uri
> format=" file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site .p2"/>
> <!--My P2-->
> </rm:provider>
> </rm:searchPath>
> </rm:searchPath>
> </rm:searchPath>
> </rm:rmap>
> CSPEC:
> <cs:dependencies>
> </cs:dependencies>
> </cs:cspec>
> Cheers,
Re: P2 Repository can not be found [message #629968 is a reply to message #629955] |
Thu, 30 September 2010 03:24   |
What kind of errors do you get when using p2 ?
An SVN repository can read source projects from SVN. It cannot read a p2
repository stored in SVN (well, it can read it but it doesn't understand
it's semantics). If you want to read p2 repositories that are checked
into an SVN repository, then you must use the p2 readerType and access
the SVN artifacts using a URL. http or https should be fine if your SVN
repo is set up to support that.
- thomas
On 09/30/2010 08:35 AM, M. Stutz wrote:
> Thomas Hallgren wrote on Thu, 30 September 2010 02:14
>> to extract a feature in source form from that directory. That's not
>> what you want, is it?
>> Regards,
>> Thomas Hallgren
> Yes you have right, that's not what I want. But I had also tried "p2"
> this is also not working. (And for my SVN Repository ha have also tried
> SVN)
> resourceMap
> internalBinaries
> p2( file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site .p2[ file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site .p2]):
> ERROR No repository found at
> file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site .p2/
> sources
> Thank you & Cheers,
Re: P2 Repository can not be found [message #629972 is a reply to message #629968] |
Thu, 30 September 2010 03:49   |
Thomas Hallgren wrote on Thu, 30 September 2010 03:24 | What kind of errors do you get when using p2 ?
I get this error:
ERROR [0002] : Rejecting provider p2(file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site.p2[file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site.p2]): No component match was found
ERROR No repository found at file://C:/Data/projects/MDA/com.csg.crs.carat.p2.update/site.p2/.
The path is the right one and the p2 repository has all featers. And over the Eclipse installer will be all found.
Perfect thank you, now I understand the principle of these rederTypes.
Thank you & Cheers,
[Updated on: Thu, 30 September 2010 03:49] by Moderator
Re: P2 Repository can not be found [message #629980 is a reply to message #629972] |
Thu, 30 September 2010 04:12   |
I see that your svn provider says "Components of type eclipse.feature
are not supported". Did you include 'eclipse.feature' in the
componentTypes attribute?
- thomas
>> p2 repository stored in SVN (well, it can read it but it doesn't
>> understand it's semantics). If you want to read p2 repositories that
>> are checked into an SVN repository, then you must use the p2
>> readerType and access the SVN artifacts using a URL. http or https
>> should be fine if your SVN repo is set up to support that.
> I get this error:
> resourceMap
> internalBinaries
> sources
> Perfect thank you, know I understand the principle of these rederTypes.
> Thank you & Cheers,
Current Time: Wed Jul 23 18:58:17 EDT 2025
Powered by FUDForum. Page generated in 0.05220 seconds
