Home » Language IDEs » PHP Development Tools (PDT) » xdebug problems
xdebug problems [message #629544] Tue, 28 September 2010 12:08 Go to next message
Hi, i've recently upgraded to PDT 2.2.0 ( helios win32 version) and have not been able to get xdebug working. I had previously been using xdebug with PDT 2.1.
I've done a complete reinstall of PDT 2.2.0 and created a new workspace. I've upated xdebug to the latest version of 2.1.0.
I'm trying to use xdebug with a remote server.
In the xdebug log I get a message such as this:
Log opened at 2010-09-28 15:09:23
-> <init xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" fileuri="file:///test/debug.php" language="PHP" protocol_version="1.0" appid="5259"><engine version="2.1.0"><![CDATA[Xdebug]]></engine><author><![CDATA[Derick Rethans]]></author><url><![CDATA[http://xdebug.org]]></url><copyright><![CDATA[Copyright (c) 2002-2010 by Derick Rethans]]></copyright></init>
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" status="stopping" reason="ok"></response>
Log closed at 2010-09-28 15:09:23
I don't really know what is causing xdebug to stop. Does anyone have any suggestions. I've tried changing the port several times in case there is a conflict but it doesn't seem to make any difference.
Max
Re: xdebug problems [message #629550 is a reply to message #629544] Tue, 28 September 2010 12:24 Go to previous messageGo to next message
Originally posted by: dkel50.hotremovemail.com
So from that log, all I can tell is that xdebug established a socket
with something. It sent the initial handshake. If PDT was communicating
with xdebug it would be sending commands to configure the debug env but
the log doesn't show this.
One possibility (if in fact it is communicating with PDT) is that PDT is
rejecting the socket. Have you got remote session initiation turned on
and you are trying to debug that way or are you creating a Web script
launch ?
Check you have xdebug installed in the correct manner for the version
and type of php you are using (check http://www.xdebug.org) for more info.
Dave
> with PDT 2.1.
> Max
Re: xdebug problems [message #629825 is a reply to message #629550] Wed, 29 September 2010 12:36 Go to previous message
Hi Dave, I couldn't tell much from that log either!
I was initiating a remote debug request from Firefox using the XDebug extension. The log at least told me that it had got the right file to debug, although the reason for stopping doesn't give much away.
Your prompt made me check my PDT options again, and sure enough I had "Accept remote session (JIT)" set to "off" instead of the required "any". With this changed it now seems to work fine.
Thanks for the suggestion, it helped me fix the problem.
Max
Previous Topic:Code completion in PHP
Next Topic:"Resource is out of sync", no Refresh on File menu
Current Time: Sun Jul 27 09:00:29 EDT 2025
Powered by FUDForum. Page generated in 0.04111 seconds
