Home » Modeling » EMF » Restriction Of Complex Types Not Validating(EMF does not appear to support Restriction Of Complex Types)
Restriction Of Complex Types Not Validating [message #629514] Tue, 28 September 2010 10:39 Go to next message
I have found an issue which seems to imply that EMF does not support Restrictions of Complex types in terms of validation.
Given the following schema:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns="http://example.com/ComplexRestriction" targetNamespace="http://example.com/ComplexRestriction">
    <!-- base type -->
    <xs:complexType name="BaseInfo">
        <xs:sequence>
            <xs:element name="numPosts" type="xs:integer" minOccurs="0" maxOccurs="1"/>
        </xs:sequence>
        <xs:attribute name="firstSubscribed" type="xs:date" use="optional"/>
        <xs:attribute name="mailReader" type="xs:string"/>
    </xs:complexType>
    <!-- derived type -->
    <xs:complexType name="RestrictedOne">
        <xs:complexContent>
            <xs:restriction base="BaseInfo">
                <xs:sequence>
                    <xs:element name="numPosts" type="xs:integer" minOccurs="1"/>
                </xs:sequence>
                <xs:attribute name="firstSubscribed" type="xs:date" use="required"/>
                <xs:attribute name="mailReader" type="xs:string" fixed="Microsoft Outlook"/>
            </xs:restriction>
        </xs:complexContent>
    </xs:complexType>
    <xs:complexType name="NoBaseRestricted">
        <xs:sequence>
        </xs:sequence>
    </xs:complexType>
</xs:schema>
Now if you try:
NoBaseRestricted noBaseRestricted = RestrictionFactory.eINSTANCE.createNoBaseRestricted();
noBaseRestricted.setMailReader("Thunderbird");
Diagnostician.INSTANCE.validate(noBaseRestricted );
Then you get an error as expected because "firstSubscribed" is not set.
However if you do the following:
RestrictedOne restrictedOne = RestrictionFactory.eINSTANCE.createRestrictedOne();
restrictedOne.setMailReader("Thunderbird");
Diagnostician.INSTANCE.validate(restrictedOne);
Then there is no failure on the validation as would be expected. (It should fail as firstSubscribed is still not set)
Is this a know issue for EMF?
Rob
Re: Restriction Of Complex Types Not Validating [message #629635 is a reply to message #629514] Tue, 28 September 2010 23:48 Go to previous messageGo to next message
Rob,
comments below.
Nope, it doesn't.
> <!-- base type -->
> <xs:sequence>
> maxOccurs="1"/>
> </xs:sequence>
> use="optional"/>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> minOccurs="1"/>
> </xs:sequence>
> use="required"/>
> </xs:restriction>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> use="required"/>
> </xs:complexType>
> </xs:schema>
> Now if you try:
Yes. There's support to address it in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=51210 but there never
seems enough time for that.
> Thanks
> Rob
Re: Restriction Of Complex Types Not Validating [message #629680 is a reply to message #629514] Wed, 29 September 2010 04:49 Go to previous message
Thanks for the confirmation Ed, it seems that 51210 is a pretty far reaching issue - I've seen that refered to before as the root cause of a seperate issue.
Rob
Previous Topic:How to filter out GMF references
Next Topic:[EMF] FeatureMap with EOpposites
Current Time: Sun Jul 20 20:41:40 EDT 2025
Powered by FUDForum. Page generated in 0.03366 seconds
