Home » Eclipse Projects » P2 » Need help to get started with p2
Need help to get started with p2 [message #629608] Tue, 28 September 2010 17:34 Go to next message
with all I read about p2, I think I have an idea of what this is all about.
However, I am missing a tutorial and at least one example about how to do things.
What I have in mind, and what should be possible with p2, is the following:
I am building an RCP application with an embedded sql database. The application will ship with an initial db-schema and some master data.
However, updates of the application might require (compatible) enhancements of the db-schema and modifications of the master data.
My idea is to describe these changes through one or more sql-scripts and to ship the application with an engine to execute such scripts.
Coming to p2: For all I understand, my application would need to provide a touchpoint that p2 can call such that the engine will execute the sql-script(s).
(1) Am I correct, i.e. can one in principle implement/provide such a touchpoint?
(2) If so, I would definitely need help about how to do it -- i.e. a tutorial, examples etc.
Any help is very wellcome.
Re: Need help to get started with p2 [message #629617 is a reply to message #629608] Tue, 28 September 2010 19:11 Go to previous message
> sql-script(s).
> touchpoint?
Yes.
Look at the existing p2 native touchpoint, and the associated actions
(the native actions themselves are quite simple, but shows the sort of
things you need to think about - install/uninstall, rollback etc.).
A description can be found on the wiki -
http://wiki.eclipse.org/Equinox/p2/Engine/Touchpoint_Instruc tions
I also have interest in being able to run SQL scripts as part of a p2
installation - email me if you are interested in collaborating.
- henrik
Previous Topic:Query Bundles.info for installed plugin and version
Next Topic:Listing of installed plug-ins/features in Eclipse via CLI
Current Time: Wed Jul 23 14:13:30 EDT 2025
Powered by FUDForum. Page generated in 0.03333 seconds
