Home » Eclipse Projects » P2 » Query Bundles.info for installed plugin and version
Query Bundles.info for installed plugin and version [message #629564] Tue, 28 September 2010 13:07 Go to next message
Originally posted by: MrBob.bob.bob
I'm looking for a simple way using P2 to query whether or not a plugin
is installed, AND if so, what its version is.
The code, will start with only a path to the bundles.info (this is the
one piece of information I have).
Is there a P2 util class to do this? Or can someone point me to some
starter code, or a class to use that will lead me to the right solution.
I suppose, the other option, is to write a little bit of custom java
code to open the file, and directly inspect for the information.
However.. I'd like to use existing API if possible.
Re: Query Bundles.info for installed plugin and version [message #629577 is a reply to message #629564] Tue, 28 September 2010 13:59 Go to previous messageGo to next message
There are predefined queries as well as a comprehensive query API
available in p2.
- henrik
> solution.
- henrik
Re: Query Bundles.info for installed plugin and version [message #629579 is a reply to message #629577] Tue, 28 September 2010 14:11 Go to previous messageGo to next message
Thanks for reply.
Any java package I should specifically start my look at? Is there a wiki
that maybe shows an example of how I might do a query?
> available in p2.
> - henrik
>> solution.
Re: Query Bundles.info for installed plugin and version [message #629613 is a reply to message #629577] Tue, 28 September 2010 18:29 Go to previous messageGo to next message
Thanks for reply.
> available in p2.
> - henrik
>> solution.
Re: Query Bundles.info for installed plugin and version [message #629614 is a reply to message #629579] Tue, 28 September 2010 18:44 Go to previous message
Sorry for the short answer earlier, I was on a handheld device and did
not have the URL's handly.
The query langugage is called "p2QL", and you can read about it here:
http://wiki.eclipse.org/Query_Language_for_p2
And here is a link to help for the query package:
http://help.eclipse.org/helios/ntopic/org.eclipse.platform.d oc.isv/reference/api/org/eclipse/equinox/p2/query/package-us e.html
And here is a link to help for some predefined queries in QueryUtil:
http://help.eclipse.org/helios/ntopic/org.eclipse.platform.d oc.isv/reference/api/org/eclipse/equinox/p2/query/QueryUtil. html
I hope that helps as starting points.
- henrik
On 9/28/10 8:11 PM, MrBob wrote:
> Thanks for reply.
>> available in p2.
>> - henrik
Previous Topic:Helios SR1 incompatible?
Next Topic:Need help to get started with p2
Current Time: Wed Jul 23 18:31:53 EDT 2025
Powered by FUDForum. Page generated in 0.03857 seconds
