Home » Archived » Buckminster » Force p2 materializer to always create and activate a new target platform
Force p2 materializer to always create and activate a new target platform [message #629567] Tue, 28 September 2010 13:59 Go to next message
is it somehow possible to force the p2 materializer in a .mspec to
always create a fresh target platform and set it to active irregardless
of the currently active TP?
Markus
Re: Force p2 materializer to always create and activate a new target platform [message #629575 is a reply to message #629567] Tue, 28 September 2010 14:29 Go to previous message
Hi Markus,
The easiest way to accomplish this is to create an empty directory and
then do setpref targetPlatformPath=<empty dir>. This ensures that you
have an empty, and active, target platform.
Combine that with an mspec that doesn't have an install location set and
it will default to the currently active target platform. Alternatively,
don't use an mspec at all and control what goes where using
source="true/false" in the RMAP providers. The result is the same, p2
materialized components end up in the active TP.
- thomas
On 09/28/2010 07:59 PM, Markus Alexander Kuppe wrote:
> Thanks
> Markus
Previous Topic:SWT P2 Repositories
Next Topic:How to setup local reader, getting message: missing CSpec source required by component type eclipse.
Current Time: Fri Jul 25 21:53:34 EDT 2025
Powered by FUDForum. Page generated in 0.24240 seconds
