Home » Archived » BIRT » encoding problem(problem with retrieving correct data from latin2 db table)
encoding problem [message #629038] Sun, 26 September 2010 12:35 Go to next message
I have a problem. DB tables in project are set to latin2 (ISO8859_2) encoding. I was trying to create Data Source in my report with jdbc, and I always get wrong chars. It is MySQL Datbase.
connection string:
jdbc:mysql://localhost/db?characterEncoding=ISO8859_2
even if I use other encodings I get the same Sad. I realy need some help, I've stuck on it for few days.
Re: encoding problem [message #629362 is a reply to message #629038] Mon, 27 September 2010 19:48 Go to previous messageGo to next message
Janusz
Can you open a bugzilla entry for this?
Jason
On 9/26/2010 12:35 PM, Janusz Paszynski wrote:
> Hello,
> connection string:
> even if I use other encodings I get the same :(. I realy need some help,
Re: encoding problem [message #630013 is a reply to message #629038] Thu, 30 September 2010 07:37 Go to previous message
I wasn't sure if it is bug, and in which project (Birt MySQL JDBC Connector).
I did made few more test and with url:
jdbc:mysql://localhost/db?characterEncoding=ISO8859_2&re sultsEncoding=ISO8859_2
I get all strings in different encoding than previously. I don't get proper chars (like ą, ć, ł) but '?' mostly. I think it is a problem with MySQL. Especially when I tried to check different encodings with simple Java Application with JDBC. In that case I always get '?' char instead of i.e. 'ą' or 'ł'.
Previous Topic:Embeding Generated reports to other web page
Next Topic:reset pagenumber on group without interval
Current Time: Sat Jul 26 11:43:27 EDT 2025
Powered by FUDForum. Page generated in 0.24510 seconds
