Home » Modeling » OCL » HOW TO PARSE UML2.1 class diagram with OCL?
HOW TO PARSE UML2.1 class diagram with OCL? [message #629068] Mon, 27 September 2010 00:09 Go to next message
I want to read UML2.1 class diagram with OCL(.txt)
it means need to read two files(class diagram is .uml,OCL use txt to write and name .ocl)
First ,i thought i could only read ocl file ,but it couldn't.
It must need class diagram?is it right?
my snippet code:
OCL< Package,Classifier,Operation,Property,EnumerationLiteral,Par ameter,State,CallOperationAction,SendSignalAction,Constraint ,Class,EObject > ocl;
org.eclipse.emf.common.util.URI uri = URI.createFileURI("Triangle.uml");
final ResourceSet set = new ResourceSetImpl();
Registry registry = set.getPackageRegistry();
UMLEnvironmentFactory umlEnv = new UMLEnvironmentFactory(registry ,set);
umlEnv.loadEnvironment(set.getResource(uri, true));
OCL ocl = OCL.newInstance(umlEnv);
FileInputStream in = null;
in = new FileInputStream("Triangle.ocl");
OCLInput document = new OCLInput(in);
List<Constraint> constraints = ocl.parse(document); //error?
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'Triangle.uml'; a registered resource factory is needed
Can someone help me to solve the problem?
Or some snippet code?
best regards
hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #629072 is a reply to message #629068] Mon, 27 September 2010 01:50 Go to previous messageGo to next message
Hi hutzu
You're nearly there, but this is a basic EMF problem, so you may want to
consider using Ecore in isolation for a little practice first.
When running within Eclipse, plugin registrations provide most of your
required environment automatically. When running standalone as you
appear to be you must define the environment yourself, so you need to
register a UMLResourceFactory to service uml files.
Invoking org.eclipse.ocl.uml.OCL.initialize(resourceSet) should solve
this and a number of similar problems. Read the Javadoc.
Ed Willink
On 27/09/2010 05:09, hutzu wrote:
> Hello,
> my snippet code:
> best regards
> hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #629640 is a reply to message #629072] Wed, 29 September 2010 01:15 Go to previous messageGo to next message
First,thanks for your answer about my qusetion! Ed Willink
but i still can't sovle my problem
in ecoure
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
but in UML:
its no UMLEnvironmentFactory.INSTANCE,
and i do not know how to register my .uml model...
that's my problem...
best regards
hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #629676 is a reply to message #629640] Wed, 29 September 2010 04:04 Go to previous messageGo to next message
Hi Hutzu
The Ecore and UML bindings of OCL are not quite the same; something
that I'm hoping to address for MDT/OCL 4.0.
The UML environment is more dynamic and so a static instance cannot
re-used. A UML environment is enhanced in an application-specific way by
profiles and so cannot be safely shared across applications.
You must create a new UMLEnvironmentFactory() for each distinct application.
Ed Willink
> in ecoure
> but in UML:
> best regards
> hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #630819 is a reply to message #629676] Tue, 05 October 2010 03:51 Go to previous messageGo to next message
Sorry , Ed Willink
i try to find the answer , but still can't .
You say i must create additional UMLEnvironmentFactory .
But how?
in UMLEnvironmentFactory only have some method .
like createEnvironment() , createEvaluationEnvironment() ,...
But i thought UML2 tool class diagram with OCL(.txt) should be the most popular!
why so few document and information about it?
can you show me some useful document , contain som snippet code?
thank a lot.
my snippet coee:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put (Resource.Factory.Registry.DEFAULT_EXTENSION,new UMLResourceFactoryImpl());
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
URI uri = URI.createFileURI(umlfile.getAbsolutePath());//umlfile is my class diagram
Resource resource = resourceSet.createResource(uri);
UMLEnvironmentFactory umlEnvFactory = new UMLEnvironmentFactory(resourceSet);
umlEnvFactory.loadEnvironment(resource);
OCL ocl = OCL.newInstance(umlEnvFactory);
in = new FileInputStream(oclfile);//my ocl file is .txt .
and i got
org.eclipse.ocl.SemanticException: Unable to find package:
it means my oclfile possible wrong?
and last i know my " List<Constraint> constraints = ocl.parse(document);"
ocl is null,
how to get an INSTANCE to it?
best regards
hutzu
[Updated on: Tue, 05 October 2010 04:16] by Moderator
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #630831 is a reply to message #630819] Tue, 05 October 2010 04:32 Go to previous messageGo to next message
Hi Hutzu
UMLEnvironmentFactory also has three constructors, including a no
argument one, so your original problem of 'no INSTANCE' was solved by
changing
to
ocl = OCL.newInstance(new UMLEnvironmentFactory());
Historically, MDT/OCL was for Ecore meta-models with a Java API. This
has grown to support UML meta-models, however the support for UML
throughout Eclipse is much more challenging.
Current work is providing a sensible user IDE, for which prototype
(Ecore-only) editors can be found in the additional MDT/OCL Examples
install. This should provide comprehensive Ecore an UML support fopr
Indigo, at which point we might also go for a major revision of the
documentation that has not always tracked all options.
In the mean-time you seem happy to try to use the Java API, so I suggest
that you import the tests plugin sources into your workspace.
Then by searching on all references to UMLEnvironmentFactory you will
find for instance that
org.eclipse.ocl.uml.tests.UMLEnvironmentTest.test_extensibil ity_156360()
has code that loads UML OCL.
Ed Willink
On 05/10/2010 08:51, hutzu wrote:
> Sorry , Ed Willink
> But how?
> popular!
> thank a lot.
> best regards
> hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #631315 is a reply to message #630831] Wed, 06 October 2010 23:17 Go to previous messageGo to next message
Tanks again!!!
I am already have a ecore parser with OCL ,so I always want to do little change to parser UML with OCL.
But so far , it seems more difficult than ecore .
In ecore:
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(
"ecore", new EcoreResourceFactoryImpl());
URI myEcoreURI = URI.createFileURI(file.getAbsolutePath()); //file is .ecore file.
Resource myEcoreResource = resourceSet.getResource(myEcoreURI, true);
i can easily get my resource.
But in UML:
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "uml", new UMLResourceFactoryImpl());
URI UMLuri = URI.createFileURI(umlfile.getAbsolutePath()); umlfile is .uml file.
***Resource resource = resourceSet.getResource(UMLuri, true);
I got exception about my resources...OH my goodness!
Exception in thread "main" java.lang.NoSuchMethodError: org.eclipse.emf.ecore.resource.URIConverter.createInputStrea m(Lorg/eclipse/emf/common/util/URI;Ljava/util/Map;)Ljava/io/ InputStream;
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2533)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2421)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
and i saw your code~, it really helps me a lot.
but in your code , in your method "public void test_linkNavigationInReverse_259630()"
UMLEnvironmentFactory factory = new UMLEnvironmentFactory(resourceSet);
OCL ocl = OCL.newInstance(factory);
EvaluationOptions
.setOption(ocl.getEvaluationEnvironment(),
UMLEvaluationOptions.EVALUATION_MODE,
EvaluationMode.INSTANCE_MODEL);
URI uri = getTestModelURI("/model/instances.uml");
Resource res = resourceSet.getResource(uri, true);
have you register your environment? how can you do like this.
it seems like my problem...
And what is the "resourceSet" here?
best regards
hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #631329 is a reply to message #631315] Thu, 07 October 2010 01:55 Go to previous messageGo to next message
Hi hutzu
This does not happen. It suggests a Java build inconsistency. I suggest
a full rebuilds, some cleans, Eclipse restarts and maybe some project
open/closes to ensure that things are correctly built.
Ed Willink
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #631970 is a reply to message #631329] Mon, 11 October 2010 01:51 Go to previous messageGo to next message
Thanks again!!!Ed Willink
it really work~
I really learn a lot from you!!
it really work~
My objective is to parse class diagram with OCL.
In ecore , first i need to parse ecore diagram to get "ArrayList<EPackageImpl> ".
shall i do the same thing in UML2 class diagram?
To write a parser to get ArrayList<EPackageImpl> , and then register the UML2
am i right?
best regards
hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #631976 is a reply to message #631970] Mon, 11 October 2010 02:24 Go to previous messageGo to next message
Hi hutzu
On 11/10/2010 06:51, hutzu wrote:
> Thanks again!!!Ed Willink it really work~
> it really work~
> UML2
> am i right?
I have no idea, because your questions don't actually make any sense.
Why would you parse an Ecore diagram, since any plausible Ecore Diagram
tool will give you an Ecore model and so a Collection<EPackage>?
.... then why would you write a parser for a UML2 calss diagram.
I thought you were trying to use OCL.
Ed Willink
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #632014 is a reply to message #631976] Mon, 11 October 2010 04:33 Go to previous messageGo to next message
Oh,sorry,Ed Willink
I should describe my question more specific.
First, i just want to "only" use OCL .
But my boss told me OCL is to enhace UML to define constraint more specific.
And before , we have finish using Ecore diagram with OCL.
Because OCL secification also need to get some invarient type information.
But now we try to use UML2 tool Class diagram with OCL to get our goal.
show some snippet code for you:
for (EPackageImpl next : list) {
EPackage.Registry.INSTANCE.put(next.getName(), next);
this our code had done before~if i want to get constraints.
It must to get EPackage.Registry first.
Or i would get exception....
So i thought it should be similar to UML.
Is my idea wrong?
best regards
hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #632031 is a reply to message #632014] Mon, 11 October 2010 05:33 Go to previous messageGo to next message
Hi hutzu
I still don't understand. I doubt your boss does either.
I recommend understanding what you can do, then trying to find out what
your boss really wants and coming up with a practical compromise.
Ed Willink
On 11/10/2010 09:33, hutzu wrote:
> Oh,sorry,Ed Willink I should describe my question more specific.
> specific.
> Is my idea wrong?
> best regards
> hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #632050 is a reply to message #632031] Mon, 11 October 2010 07:34 Go to previous messageGo to next message
My original purpose is to collect "constraints" from OCL.
But it seem must parse with UML class diagram?
because i need to know the attributes'data type(like Int,String...).
Or i can only parse OCL(write in .txt)only?
best regards
hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #632134 is a reply to message #632050] Mon, 11 October 2010 12:40 Go to previous messageGo to next message
Hi hutzu
This still makes no sense to me. Perhaps your usage of 'parse' is
different to mine.
Perhaps if you post a UML diagram and model, and explain what
information you are trying to obtain from where, it might be possible to
help.
Ed Willink
On 11/10/2010 12:34, hutzu wrote:
> best regards
> hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #632190 is a reply to message #632134] Mon, 11 October 2010 23:05 Go to previous messageGo to next message
Really appreciate for your help!
here are my example:
Triangle.ocl
https://docs.google.com/leaf?id=0Bx-ztbpViVdzZTQ2YTY1Y2MtNjY wNi00OThiLWE1ODQtNDc2MzE5ZGRkYWNm&hl=en
Triangle.uml(UML2.1 tool class diagram
https://docs.google.com/leaf?id=0Bx-ztbpViVdzOWRiZjRiOTItMjY zNS00YzEyLThkYzgtZjE3ZmFjNTc1MDA3&hl=en
All what i want is constraints"[context Triangle inv: self.sideA.+(self.sideB).>(self.sideC).and(self.sideB.+(self.sideC). >(self.sideA)).and(self.sideA.+(self.sideC).>(self.sideB))... "
And in uml i want to get the data type like sideA ,sideB,sideC are Integer.
So i try to use "org.eclipse.ocl.OCL " " parse" function
List<CT> parse(OCLInput input)
Parses an OCL document, returning the constraints parsed from it.
But i can't directly run this function.it's would have error message.
I thought the problem was it "must" to get the package registry.
So i just want to get the constraints from OCL , i can't only use OCL .
Because it should use with models(ecore or uml).
So i have to use UML.
best regards
hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #632198 is a reply to message #632190] Tue, 12 October 2010 00:52 Go to previous messageGo to next message
Hi hutzu
Those pages are not available.
I requested that you ATTACH.
Ed Willink
> here are my example: Triangle.ocl
> List<CT> parse(OCLInput input) Parses an OCL document, returning the
> best regards
> hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #632242 is a reply to message #632198] Tue, 12 October 2010 05:04 Go to previous messageGo to next message
OK, it's open now .
regards
hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #632736 is a reply to message #632242] Thu, 14 October 2010 02:23 Go to previous messageGo to next message
Hi Hutzu
Well there are still no attachments but the 1kB and 4kB google docs are
readable.
I still don't understand your questions, but looking at the documents,
your question might be "how do I use the OCL editor for them?", so I'll
answer that.
The Complete OCL editor does not yet support UML meta-models so you need
to use the UML editor to convert to Ecore, which applies name/style
corrections by default and produces a triangleuml.ecore and a
triangleuml package and leading lowerrcase on operations.
The editor supports an 'import' extension, so adding
import 'triangleuml.ecore'
enables the editor to see your model and report many erroprs until the
packagename is changed to 'triangleuml'. It now reports far fewer errors
and these go away when you change your 'constructor' spelling to match
the adjusted name.
The parser accessible using the org.eclipse.ocl.uml.OCL facade does
support UML meta-models, but does not (yet) support an import statement,
so your models should be useable unchanged; it is your responsibility to
load the UML package into the UMLEnvironment.
You may find the OCL Interpreter Tutorial in the OCL Developers Guide
acessible via Help Contents useful. Unfortunately it only covers Ecore.
However once you understnad it you should be able to step sideways to
the UML variant. I have added a comment to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=304642 to enciurage us to
improve the documentation here.
Ed Willink
On 12/10/2010 10:04, hutzu wrote:
> OK, it's open now .
> regards
> hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #633006 is a reply to message #632736] Thu, 14 October 2010 23:13 Go to previous messageGo to next message
Thabks a lot~Ed Willink
It seems UML with OCL is really tough...
I learned a lot during this period.
Maybe after i still needs your direction.
best regards
hutzu
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #1048498 is a reply to message #629068] Wed, 24 April 2013 10:55 Go to previous messageGo to next message
Hello,I want to do the same work as yours. But I do not know how to build a new eclipse project for this work? Can you tell me which kind of eclipse project I should build? Thank you.
if I build the new java project, I write some code in the main function. It can not identify the type e.g. OCL< Package,Classifier,Operation,Property,EnumerationLiteral,Par ameter,State,CallOperationAction,SendSignalAction,Constraint ,Class,EObject >
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #1048574 is a reply to message #1048498] Wed, 24 April 2013 13:07 Go to previous messageGo to next message
This is a very novice quiestion. You should gain much more familiarity
with the basics of Eclipse Java development before attempting something
hard.
If you use a Java project you are responsible for defining the classpath.
If you use a Plugin project, Eclipse will help you maintain the manifest.
Ed Willink
> ,Class,EObject >
Re: HOW TO PARSE UML2.1 class diagram with OCL? [message #1048807 is a reply to message #1048574] Wed, 24 April 2013 21:16 Go to previous message
Hi, I am glad to get your reply. You must be a eclipse expert. We want to consider the eclipse ocl as a standalone tool. We want to use a Java project. How can we configure the build path of eclipse ocl? Which jars should we configure? It confuses me so many days. Please provide some help. Thank you.
Xiang Qiu
Previous Topic:Need help in constraint syntax
Next Topic:Step for use the eclipse ocl as a standalone
Current Time: Wed Jul 23 20:36:55 EDT 2025
Powered by FUDForum. Page generated in 0.07576 seconds
