Home » Modeling » Graphiti » PlatformGraphicsAlgorithm update and IGraphicsAlgorithmRenderer refresh
PlatformGraphicsAlgorithm update and IGraphicsAlgorithmRenderer refresh [message #629046] Sun, 26 September 2010 14:42 Go to next message
I've started to use PlatformGraphicsAlgorithms that I render through
IGraphicsAlgorithmRenderers with Draw2D IFigures. I can't use the
provided graphics algorithms, I have some specific needs. The rendering
is fine, but there is an issue with the refresh.
When the PlatformGraphicsAlgorithm is updated (following a change in its
bounds or in its IProperties), the corresponding IFigure is not
invalidated/repainted.
I think there is an issue in
PictogramElementDelegate.refreshFigureForGraphicsAlgorithm. The
PlatformGraphicsAlgorithm case is not handled.
Romain
Re: PlatformGraphicsAlgorithm update and IGraphicsAlgorithmRenderer refresh [message #629053 is a reply to message #629046] Sun, 26 September 2010 15:45 Go to previous messageGo to next message
In fact there are two things:
1- The refresh following a change in the bounds of GraphicsAlgorithm
figures is not handled in
PictogramElementDelegate.refreshFigureForGraphicsAlgorithm, in fact
there is no issue at this level.
But I don't understand that with standard GraphicsAlgorithms
(RoundedRectangle, Ellipe...) and corresponding GFShapes, the refresh is
perfect, and not with custom IFigures. Mainly when you start moving
several shapes and do undo/redo, although with simple drawings like
rectangles or ellipses. Do you have any idea? Did you notice such issue?
2- More a limitation: the IProperty collection is a way to store
graphical data in the PlatformGraphicsAlgorithm to be used by the
renderer. By this way, there is no need to extend the notational
metamodel for this purpose. But an update in these properties is not
handled and does not trigger any refresh of the renderer. Do you plan to
support this?
Romain
Le 26/09/2010 20:42, Romain Raugi a écrit :
> Best regards,
> Romain
Re: PlatformGraphicsAlgorithm update and IGraphicsAlgorithmRenderer refresh [message #630199 is a reply to message #629053] Fri, 01 October 2010 00:27 Go to previous message
Here are the bug reports, with the tutorial modified to add the usage of
GraphicsAlgorithmRenderers:
1- Refresh issues with IGraphicsAlgorithmRenderer (clearly a bug)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326730
2- GraphicsAlgorithm properties update and IGraphicsAlgorithmRenderer
repaint (enhancement)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326733
I've also reported a regression about the management of domain model
updates outside the editor: Exception when undoing a domain model update
done through EMF.Edit
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326731
Romain
> support this?
> Best regards,
> Romain
>> Hi,
>> Best regards,
>> Romain
Previous Topic:Graphiti has successfully passed its release review
Next Topic:Separator in Palette Compartment
Current Time: Tue Jul 29 02:55:19 EDT 2025
Powered by FUDForum. Page generated in 0.13831 seconds
