Home » Language IDEs » PHP Development Tools (PDT) » wrong Design or Problem of PHP resp. PDT
wrong Design or Problem of PHP resp. PDT [message #560092] Tue, 21 September 2010 03:52 Go to next message
hi,
i have a question about auto-complete methods from return Objects.
to explain a little code.
class node {
	public $age = 10;
	public function __construct(/*int*/ $age){
		$this->age = $this->age + $age;
	public function getAge(){
		return $this->age;
class tree {
	public static function getNodes(/*int*/ $number){
		$nodes = array();
		for($i=0; $i<=$number; $i++){
			$nodes[] = new node($i);
		return $nodes;
$Tree = tree::getNodes(9);
foreach($Tree as $Node){
	echo 'Node age:'.$Node->getAge();
the auto-complete function does not work on the
$Node in the last for-each loop.
I think, it is because PDT don't know the elements in the Array.
If i return the object directly (also only one) the auto-complete function works correctly.
In Java there are Return Types and and everything is a Object.
There are no Problems with this.
Is the code above only a design error?
Is there a other method to code something like this?
Re: wrong Design or Problem of PHP resp. PDT [message #626140 is a reply to message #560092] Wed, 22 September 2010 08:24 Go to previous messageGo to next message
Add type comment.
	/* @var $Node node */
see also
Bug 170968 - Use PHPDoc hints for arrays of objects
Re: wrong Design or Problem of PHP resp. PDT [message #626262 is a reply to message #626140] Wed, 22 September 2010 09:14 Go to previous messageGo to next message
thank you,
this helps me a lot.
i have not found this answer somewhere.
Also it is a problem of PHP, because PHP dont understand return types.
in this case i should make this comment in all
loops.
adv. better:
class tree{
  public /* @return array node */ function getNodes(){
  ... return array...
or something like this.
perhaps in future versions of PHP.
Re: wrong Design or Problem of PHP resp. PDT [message #629015 is a reply to message #626262] Sat, 25 September 2010 22:06 Go to previous message
I've made a small helper plugin for Content Assist against object variable in 'foreach' block.
It makes possible to CA in some cases, ...
It works on PDT 2.2.1 (Helios SR1) and in 'foreach' block only.
http://sourceforge.jp/projects/pdt-tools/releases/49081/
(sorry, no release note in English)
Previous Topic:Incorrectly formatting source code
Next Topic:Displaying defines?
Current Time: Sat Jul 26 11:29:21 EDT 2025
Powered by FUDForum. Page generated in 0.23966 seconds
