Home » Archived » BIRT » Custom table handler and JSF
Custom table handler and JSF [message #628923] Fri, 24 September 2010 13:55 Go to next message
I have a JSF 1.2 and I invoke my report from managed bean. My report contains custom handler:
public class MyTableHandler extends TableEventAdapter {
   public void onCreate(ITableInstance table, IReportContext   reportContext) {
   public void onPrepare(ITable table, IReportContext reportContext) {
   public void onRender(ITableInstance table, IReportContext reportContext) {
My question is : what is the best way to pass any object from managed bean (in my example there is a List<Employees> ) and get it in onCreate() method ? Is there any way to set this object to IReportContext ?
Kuba
Re: Custom table handler and JSF [message #628928 is a reply to message #628923] Fri, 24 September 2010 14:34 Go to previous messageGo to next message
Kuba,
Are you using the RE API? If so you could call
task.getAppContext().put("myobject", employeeobject);
Then in the table handler
reportContext.getAppContext().get("myobject");
Jason
On 9/24/2010 1:55 PM, Kuba P. wrote:
> Kuba
Re: Custom table handler and JSF [message #628936 is a reply to message #628928] Fri, 24 September 2010 15:33 Go to previous messageGo to next message
Thanks for fast replay. I have a birt viewer included in my JSF application. What is "task" object and how can I get in my managed bean ? Dou you have some more code ?
Kuba
[Updated on: Fri, 24 September 2010 15:34] by Moderator
Re: Custom table handler and JSF [message #628939 is a reply to message #628936] Fri, 24 September 2010 15:55 Go to previous messageGo to next message
Kuba,
task is the engine task used to run the report. I thought you were
using the RE API. If you are looking at the viewer have a look at this
page:
http://wiki.eclipse.org/Adding_an_Object_to_the_Application_ Context_for_the_Viewer_%28BIRT%29
Jason
On 9/24/2010 3:33 PM, Kuba P. wrote:
> Thanks got fast replay. I have a birt viewer included in my JSF
> Kuba
Re: Custom table handler and JSF [message #628978 is a reply to message #628923] Sat, 25 September 2010 05:18 Go to previous messageGo to next message
Solution you are refered is the same as I have currently. I set my variables to session in managed bean and get in my table handler inside onCreate() method. But I'm curious is there any method to pass my objects to scope shorter than session. e.g. request. I don't need longer life of these objects then report invocation.
Re: Custom table handler and JSF [message #629251 is a reply to message #628978] Mon, 27 September 2010 11:26 Go to previous messageGo to next message
You can always get the request object in script.
reportContext.getHttpServletRequest().getAttribute("myattribute ");
Jason
On 9/25/2010 5:18 AM, Kuba P. wrote:
Re: Custom table handler and JSF [message #629331 is a reply to message #629251] Mon, 27 September 2010 15:54 Go to previous messageGo to next message
I think this is solution I was looking for. Thanks for response - I'll try that.
Re: Custom table handler and JSF [message #629442 is a reply to message #629251] Tue, 28 September 2010 06:14 Go to previous messageGo to next message
this is my manged bean code
public class PageBean implements Serializable{
	private List<Employee> emp;
	@SuppressWarnings("unused")
	@PostConstruct
	private void init(){
		emp = EmployeeDAO.getEmployees();
	public void runReport(ActionEvent evt){
		String url = "/frameset?__report=WEB-INF/birt/DemoReport.rptdesign&__fittopage=true";
		FacesContext context = FacesContext.getCurrentInstance();
		HttpServletRequest  req  = (HttpServletRequest) context.getExternalContext().getRequest();
		HttpServletResponse resp = (HttpServletResponse)context.getExternalContext().getResponse();
		req.setAttribute("AppContextKey", "EmpList");
		req.setAttribute("AppContextValue", emp);
		try {
			req.getRequestDispatcher(url).forward(req, resp);
		} catch (ServletException e) {
			e.printStackTrace();
		} catch (IOException e) {
and this is my event handler class for Scripted Data Source
public class EmployeesTableHandler extends ScriptedDataSetEventAdapter {
	private List<Employee> employees;
	private int rows = 0;
	@SuppressWarnings("unchecked")
	public void beforeOpen(IDataSetInstance dataSet, IReportContext ctx){
		employees = (List<Employee>)ctx.getAppContext().get("EmpList");
	public boolean fetch(IDataSetInstance dataSet, IUpdatableDataSetRow row) {
		try {
			if(rows == employees.size()){
				return false;
			Employee emp = employees.get(rows);
			row.setColumnValue("FirstName", emp.getFirstName());
			row.setColumnValue("LastName",  emp.getLastName());
			row.setColumnValue("Age",       emp.getAge());
			rows++;
			return true;
		} catch (ScriptException e) {
			return false;
But
returns null for me
Folowing code works as expected
		employees = EmployeeDAO.getEmployees();
So, the problem is with requested params.
Kuba
[Updated on: Tue, 28 September 2010 06:19] by Moderator
Re: Custom table handler and JSF [message #629447 is a reply to message #629442] Tue, 28 September 2010 06:33 Go to previous messageGo to next message
Interested - when I used sesson instead of request
HttpSession session = (HttpSession)context.getExternalContext().getSession(false);
session.setAttribute("AppContextKey", "EmpList");
session.setAttribute("AppContextValue", emp);
everything works. Why request scope is not visible in my table handler ?
Kuba
Re: Custom table handler and JSF [message #629778 is a reply to message #629447] Wed, 29 September 2010 10:24 Go to previous message
Kuba,
As a test could you change your url
/frameset to /preivew and try the request object again?
Jason
> Kuba
Previous Topic:Report Engine Javadoc
Next Topic:BIRT Servlet embed report in some jsp
Current Time: Sat Jul 26 07:57:56 EDT 2025
Powered by FUDForum. Page generated in 0.07885 seconds
