Home » Archived » BIRT » Starting Issues(How to Load XML file into report writer)
Starting Issues [message #628775] Fri, 24 September 2010 01:45 Go to next message
Please help.
I can copy and paste the XML code from a report created in BIRT into a file, but how do you load an XML file into BIRT?
I have seen several examples of reports, but I do not know how to load them. In particular the examples supplied. I tried creating a new blank report and pasting the XML into the XML page but it did not work.
I have followed the tutorials and can create reports. I now need to get more complex and the examples are supposed to show more features, so I need to load them.
Re: Starting Issues [message #628897 is a reply to message #628775] Fri, 24 September 2010 12:12 Go to previous messageGo to next message
Chris,
I assume you mean copying report xml from messages and pasting them into
a report? Just create a new report and select the xml view. Paste over
the xml with the xml from the message.
When you do this sometimes you will get an error on the third line:
Build <2.5.2.v20100210-0630>
If you do just remove the build portion of the property.
Jason
On 9/24/2010 1:45 AM, Chris wrote:
> Please help.
> need to load them.
icon10.gif  Re: Starting Issues [message #629386 is a reply to message #628897] Tue, 28 September 2010 02:42 Go to previous message
Thanks Jason.
Previous Topic:How to increase Java heap space
Next Topic:Problem with Platform.startup and UNC paths
Current Time: Sat Jul 26 08:41:28 EDT 2025
Powered by FUDForum. Page generated in 0.04561 seconds
