Home » Eclipse Projects » EclipseLink » Column "rowid" cannot be resolved
Column "rowid" cannot be resolved [message #628839] Fri, 24 September 2010 07:43 Go to next message
Is anybody know howto map Oralce ROWID?
I has received the error message:
Column "rowid" cannot be resolved on table "LOG"
when doing mapping like this:
@Entity
public class Log implements Serializable {
	private static final long serialVersionUID = 1L;
	@Id
	private ROWID rowid;
Re: Column "rowid" cannot be resolved [message #629243 is a reply to message #628839] Mon, 27 September 2010 11:13 Go to previous messageGo to next message
Include the SQL and exception stack. Is this on an insert? The column must be marked as read-only (insertable/updateable=false)
In general mapping or making the ROWID the Id is not a good idea. If you really don't have an Id the either generate one, or make all of the columns the Id.
Re: Column "rowid" cannot be resolved [message #630064 is a reply to message #629243] Thu, 30 September 2010 10:32 Go to previous message
Thank you James!
It's my mistake. JPA specification doesn't support ROWID type and EclipseLink doesn't have such extension.
So, I should make the generated @Id for JPA Entity class.
Sad
Previous Topic:GF 3.1 + EclipseLink 2.1.1 - Map/Hashmap not working properly with changetracking enabled
Next Topic:Getting Results and Count from NamedQuery
Current Time: Wed Jul 23 08:12:49 EDT 2025
Powered by FUDForum. Page generated in 0.03692 seconds
