Home » Modeling » Ecore Tools » [Teneo] No primary key in table for multi-valued string attribute
[Teneo] No primary key in table for multi-valued string attribute [message #605473] Tue, 21 September 2010 15:42 Go to next message
I have an EClass "A" containing a multivalued, EString attribute named "tags". Teneo/Hibernate generate a A_tags table with two columns: an A_tags_id with the A's id and the EString tag.
How can I make sure that this table has a primary key since this needs to be replicated by the underlying db configuration?
Re: [Teneo] No primary key in table for multi-valued string attribute [message #628837 is a reply to message #605473] Fri, 24 September 2010 07:33 Go to previous messageGo to next message
I found a Teneo property teneo.mapping.map_all_lists_as_idbag that seems relevant , but had no effect on my mappings. After a brief search through the source code, this property seems to be used only for EReference annotations, but in my case I have a multivalued EAttribute
It seems that I would like teneo to generate the following:
<class>
     <idbag name="dependentObjects" table="idbag_dependent_objects" lazy="false">
       <collection-id column="id" type="java.lang.String">
         <generator class="uuid"/>
       </collection-id>
       <key column="main_id" />
       <element type="java.lang.String" column="val"/>
     </idbag>
</class>
Instead of a simple bag with only a FK.
Is that supported? Any ideas on how to get a proper PK generated for this multivalued EAttribute table?
Re: [Teneo] No primary key in table for multi-valued string attribute [message #628855 is a reply to message #605473] Fri, 24 September 2010 09:12 Go to previous message
Thanks for listening Smile
I resolved the issue by adding an @IdBag(generator="uuid",type="java.lang.String") to my EAttribute.
Previous Topic:Add attribute/reference to diagram which is part of model
Next Topic:How to deploy a generated editor plug-in
Current Time: Sat Jul 26 06:50:18 EDT 2025
Powered by FUDForum. Page generated in 0.07162 seconds
