Home » Eclipse Projects » Rich Client Platform (RCP) » ViewerSorter performance
ViewerSorter performance [message #628799] Fri, 24 September 2010 03:55 Go to next message
my tree viewer shows a relatively plain model (2000 elements in the same
node). When I use a ViewerSorter, the Display thread is blocked for
about 20s (!) before showing the sorted tree. Profiling does not reveal
anything special, most of the time is spent in some SWT internal stuff.
When I sort the elements in the IContentProvider instead, sorting time
drops below 3s. Still a lot but I can live with that.
Am I missing something?
Jan
Re: ViewerSorter performance [message #628800 is a reply to message #628799] Fri, 24 September 2010 04:05 Go to previous messageGo to next message
Are you setting the sorter after the setInput()? You could try turning
of redraw before setting the new sorter this might help.
Tom
Am 24.09.10 09:55, schrieb Jan Kšoehnlein:
> Regards
> Jan
Re: ViewerSorter performance [message #629418 is a reply to message #628800] Tue, 28 September 2010 04:27 Go to previous message
As sorting is usually triggered on/off, I set the viewer after setting
the input. In the meantime, I moved sorting into the content provider
which fits my needs.
Thanks for your help
Jan
Am 24.09.10 10:05, schrieb Tom Schindl:
> Tom
>> Hi,
>> Regards
>> Jan
Previous Topic:Serializing references to resources (files) in workspace
Next Topic:Standalone view placeholder - improper layout?
Current Time: Sun Aug 31 01:03:11 EDT 2025
Powered by FUDForum. Page generated in 0.11561 seconds
