Home » Modeling » UML2 » Problem applying stereotype
Problem applying stereotype [message #628619] Wed, 01 September 2010 10:03 Go to next message
I have a problem applying a stereotype to a Port, here's my code:
// port is the original Port
// portCopy is the copy of port
Profile prof = port.getModel().getAppliedProfile("MARTE::MARTE_DesignModel::HLAM ");
Stereotype stereo = prof.createOwnedStereotype("RtFeature", true);
portCopy.applyStereotype(prof.createOwnedStereotype("RtFeature ", true));
applyStereotype throws an IllegalArgument exception, what I'm doing wrong?
Thanks in advance
Re: Problem applying stereotype [message #628622 is a reply to message #628619] Wed, 01 September 2010 12:34 Go to previous message
Hi, 123star,
You are attempting to (repeatedly) create the RtFeature stereotype in
the HLAM profile. This has several problems:
- profiles are read-only from the perspective of the models that
apply them
- you wouldn't want to define the same stereotype multiple times,
anyways
- your new RtFeature stereotypes have no attributes and extend
no metaclasses, so you can't apply them to any elements
- you aren't creating a new Ecore definition of the profile that
would allow you to apply the newly-created RtFeature stereotypes
If the HLAM profile already has an RtFeature stereotype and it has an
Ecore definition, then you need only to accessing the existing
stereotype using the Profile::getOwnedStereotype(String) API instead of
createOwnedStereotype.
HTH,
Christian
On 01/09/10 10:03 AM, 123star wrote:
> Profile prof =
> Thanks in advance
Previous Topic:Problem applying stereotype
Next Topic:How to assign a value to a slot in an objectDiagram?
Current Time: Thu Jul 24 21:31:28 EDT 2025
Powered by FUDForum. Page generated in 0.24031 seconds
